  2. Announcements
  3. 💬 Infrared Sender and Receiver
45 Posts 26 Posters 25.0k Views 26 Watching
  • Talat KeleşT Talat Keleş
    @Reza said:
    is this a learning mode module ?
    how use this module for learn my ir codes ?
    This node decodes IR remote codes, print protocol and hex value to serial monitor and send it to gateway. Then controller can do logic on that to do some stuff.
    The sample code also receive on/off command from controller and emits IR signal depending on it.
    I use this node to turn on/off sony sound system (15bit sony protocol) and benq projector (NEC protocol) together beside htpc(via wol). Openhab rule send 8byte IR codes as V_IR_Send to node and node emits the required IR codes.
    ramoncarranzaR
    ramoncarranzaR
    ramoncarranza
    @Talat-Keleş
    Hi, I am having an issue compiling the sketch and was wondering if you had any input or could help me out, This is what I get back when I try to compile;
    0_1483733093476_upload-fba9c55f-1a02-4b17-b7ff-bc75aadb47d1
    Talat KeleşT P 2 Replies Last reply
    • ramoncarranzaR ramoncarranza
      @Talat-Keleş
      Talat KeleşT
      Talat KeleşT
      Talat Keleş
      wrote on last edited by Talat Keleş
      #22
      @ramoncarranza
      Compiler complains about not understanding decode_type_t. It should be defined in .h file or maybe you defined it in sketch but there is a problem definetly.
      Can you post whole sketch and IR library and error message if any other so we can check and test.
      By the way, I installed IRremote.h (v2.1.0) via library manager, and default sketch compiled without error on IDE 1.6.5 win7 and IDE 1.6.10 linux mint 17.
      • tmn103T
        tmn103T
        tmn103
        Re: 💬 Infrared Sender and Receiver
        How do you enter the raw IR codes, i.e. those that aren't covered in the sketch? I have one through the receiver in the format - 23784 1800 -800 950 -1700 1800 -850 900 -850 950 -1700 1800 -850 900 -850 900 -850 950 -800 950 -850 900
          @Talat-Keleş
          P
          P
          pete1450
          @ramoncarranza When I went and looked where the library manager installed the IRremote lib(for me C:\Users\User\Documents\Arduino\libraries), it had given it an odd name like arduino_294267. I renamed it to IRremote and the issue went away.
          • H
            H
            hashem25
            I am confused i see the decode in my com monitor and i see the ir node in my domoticz but there is no data???
            • W
              W
              wilson64
              Can I use MQTT & Node Red to make this work, if yes can somebody show me how
              • Mitja BlazinsekM
                Mitja BlazinsekM
                Mitja Blazinsek
                ok i record ir code 240E4F17 from my AC remote hov can i sent this code from my controler to IR node and request from node to sent that code (on/off) AC i was trying with raw mesage but i dot know what to send (Type/ Sub type , Acknowledge/ Payload)
                • dbemowskD
                  dbemowskD
                  So, I am thinking of building this and I noticed that the documentation says that you may need a mega to do this. Is a mega required, or will the code work with a nano or an uno?
                  • N
                    N
                    Newzwaver
                    Hi Running this code I get the following errors anyone know why?
                    Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Nano, ATmega328"
                    Build options changed, rebuilding all
                    Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
                    Using library MySensors in folder: C:\Users\Audrey\Documents\libraries\MySensors
                    Using library Robot IR Remote in folder: C:\Program Files (x86)\Arduino\libraries\RobotIRremote
                    C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Users\Audrey\Documents\libraries\MySensors -IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src C:\Users\Audrey\AppData\Local\Temp\build2205553450015260610.tmp\IRSendRec.cpp -o C:\Users\Audrey\AppData\Local\Temp\build2205553450015260610.tmp\IRSendRec.cpp.o
                    IRSendRec.ino:95:5: error: 'decode_type_t' does not name a type
                    IRSendRec.ino:114:1: error: 'IRsend' does not name a type
                    IRSendRec.ino:135:1: error: too many initializers for 'IRCode::<anonymous struct>'
                    IRSendRec.ino: In function 'byte lookUpPresetCode(decode_results*)':
                    IRSendRec.ino:246:38: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:256:38: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino: In function 'bool storeRCCode(byte)':
                    IRSendRec.ino:300:30: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:302:49: error: 'class decode_results' has no member named 'address'
                    IRSendRec.ino: In function 'void sendRCCode(byte)':
                    IRSendRec.ino:322:39: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:84:38: note: in definition of macro 'Type2String'
                    IRSendRec.ino:84:50: note: in definition of macro 'Type2String'
                    IRSendRec.ino:323:18: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:328:10: error: 'irsend' was not declared in this scope
                    IRSendRec.ino:331:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:338:10: error: 'irsend' was not declared in this scope
                    IRSendRec.ino:341:23: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:342:8: error: 'irsend' was not declared in this scope
                    IRSendRec.ino:344:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:345:8: error: 'irsend' was not declared in this scope
                    IRSendRec.ino:347:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:348:8: error: 'irsend' was not declared in this scope
                    IRSendRec.ino:352:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:353:8: error: 'irsend' was not declared in this scope
                    IRSendRec.ino:355:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:355:32: error: 'SAMSUNG' was not declared in this scope
                    IRSendRec.ino:356:8: error: 'irsend' was not declared in this scope
                    IRSendRec.ino:358:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:358:32: error: 'WHYNTER' was not declared in this scope
                    IRSendRec.ino:359:8: error: 'irsend' was not declared in this scope
                    IRSendRec.ino:361:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:361:32: error: 'AIWA_RC_T501' was not declared in this scope
                    IRSendRec.ino:362:8: error: 'irsend' was not declared in this scope
                    IRSendRec.ino:364:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:364:32: error: 'LG' was not declared in this scope
                    IRSendRec.ino:364:48: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:364:75: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:368:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:372:12: error: 'irsend' was not declared in this scope
                    IRSendRec.ino:375:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:376:8: error: 'irsend' was not declared in this scope
                    IRSendRec.ino:380:24: error: 'struct IRCode::<anonymous>' has no member named 'type'
                    IRSendRec.ino:380:32: error: 'DENON' was not declared in this scope
                    IRSendRec.ino:381:8: error: 'irsend' was not declared in this scope
                    IRSendRec.ino: In function 'void dump(decode_results*)':
                    IRSendRec.ino:403:29: error: 'class decode_results' has no member named 'address'
                    • N Newzwaver
                      @Newzwaver see @pete1450's post above (5 posts above yours).
                      • korttomaK
                        korttomaK
                        korttoma
                        Trying to compile the Infrared Sender and Receiver sketch to be used on a WeMos D1 Mini Pro (ESP8266) but I get the following error:
                        Seems like the saving/reading to/from Eeprom is handled differently when it comes to ESP8266.
                        So what do I need to change in order to get the sketch to compile?
                        Sketch:
                         * Version 1.0 - Changed for MySensors usage by Bart Eversdijk
                         * Version 1.1 - Added option to record manual presets up to 240
                         * Version 2.0 - Migrated to MySensrors version 2.0
                         * IRrecord: record and play back IR signals as a minimal
                         * An IR detector/demodulator must be connected to the input RECV_PIN.
                         * An IR LED must be connected to the output PWM pin 3.
                         * The logic is:
                         * If a V_IR_RECORD is received the node enters in record mode and once a valid IR message has been received
                         * it is stored in EEPROM. The first byte of the V_IR_RECORD message will be used as preset ID
                         * If a V_IR_SEND the IR message beloning to the preset number of the first message byte is broadcasted
                         * Version 0.11 September, 2009
                         * Copyright 2009 Ken Shirriff
                         * http://arcfn.com
                        // Enable debug prints
                        #define MY_NODE_ID      5
                        //#include <IRremote.h>  // https://github.com/z3t0/Arduino-IRremote/releases
                        // OR install IRRemote via "Sketch" -> "Include Library" -> "Manage Labraries..."
                        // Search for IRRemote b shirif and press the install button
                        #include <IRremoteESP8266.h>  // From https://github.com/markszabo/IRremoteESP8266/
                        #include <IRsend.h>  // Needed if you want to send IR commands.
                        #include <IRrecv.h>  // Needed if you want to receive IR commands.
                        #include <IRutils.h>
                        // Define IR pins
                        uint16_t SEND_PIN = D1; //an IR LED is connected to D1
                        uint16_t RECV_PIN = D4; //an IR detector/demodulator is connected to D4
                        // Arduino pin to connect the IR receiver to
                        //int RECV_PIN     = 8;
                        //int SEND_PIN     = 3;
                        #define CHILD_ID  2
                        #define MY_RAWBUF  50
                        const char * TYPE2STRING[] = {
                            "UNKONWN",
                            "RC5",
                            "RC6",
                            "NEC",
                            "Sony",
                            "Panasonic",
                            "JVC",
                            "SAMSUNG",
                            "Whynter",
                            "AIWA RC T501",
                            "LG",
                            "Sanyo",
                            "Mitsubishi",
                            "Dish",
                            "Sharp",
                            "Denon"
                        #define Type2String(x)   TYPE2STRING[x < 0 ? 0 : x]
                        #define AddrTxt          F(" addres: 0x")
                        #define ValueTxt         F(" value: 0x")
                        #define NATxt            F(" - not implemented/found")
                        // Raw or unknown codes requires an Arduino with a larger memory like a MEGA and some changes to store in EEPROM (now max 255 bytes)
                        // #define IR_SUPPORT_UNKNOWN_CODES
                        typedef union
                          struct
                            decode_type_t type;            // The type of code
                            uint32_t      value;           // The data bits if type is not raw
                            uint8_t      len;             // The length of the code in bits
                            uint8_t      address;         // Used by Panasonic & Sharp [16-bits]
                          } code;
                        #ifdef IR_SUPPORT_UNKNOWN_CODES
                          struct
                            uint16_t  codes[MY_RAWBUF];
                            byte          count;           // The number of interval samples
                          } raw;
                        } IRCode;
                        #define           MAX_STORED_IR_CODES     10
                        IRCode            StoredIRCodes[MAX_STORED_IR_CODES];
                        IRrecv            irrecv(RECV_PIN);
                        IRsend            irsend(SEND_PIN);
                        decode_results    ircode;
                        #define           NO_PROG_MODE 0xFF
                        byte              progModeId       = NO_PROG_MODE;
                        // Manual Preset IR values -- these are working demo values
                        // VERA call: luup.call_action("urn:schemas-arduino-cc:serviceId:ArduinoIr1", "SendIrCode", {Index=15}, <device number>)
                        // One can add up to 240 preset codes (if your memory lasts) to see to correct data connect the Arduino with this plug in and
                        // look at the serial monitor while pressing the desired RC button
                        IRCode PresetIRCodes[] = {
                            { { RC5, 0x01,       12, 0 }},  // 11 - RC5 key "1"
                            { { RC5, 0x02,       12, 0 }},  // 12 - RC5 key "2"
                            { { RC5, 0x03,       12, 0 }},  // 13 - RC5 key "3"
                            { { NEC, 0xFF30CF,   32, 0 }},  // 14 - NEC key "1"
                            { { NEC, 0xFF18E7,   32, 0 }},  // 15 - NEC key "2"
                            { { NEC, 0xFF7A85,   32, 0 }},  // 16 - NEC key "3"
                            { { NEC, 0xFF10EF,   32, 0 }},  // 17 - NEC key "4"
                            { { NEC, 0xFF38C7,   32, 0 }},  // 18 - NEC key "5"
                            { { RC6, 0x800F2401, 36, 0 }},  // 19 - RC6 key "1" MicroSoft Mulitmedia RC
                            { { RC6, 0x800F2402, 36, 0 }}   // 20 - RC6 key "2" MicroSoft Mulitmedia RC
                        #define MAX_PRESET_IR_CODES  (sizeof(PresetIRCodes)/sizeof(IRCode))
                        #define MAX_IR_CODES (MAX_STORED_IR_CODES + MAX_PRESET_IR_CODES)
                        MyMessage msgIrReceive(CHILD_ID, V_IR_RECEIVE);
                        MyMessage msgIrRecord(CHILD_ID, V_IR_RECORD);
                          // Tell MYS Controller that we're NOT recording
                          send(msgIrRecord.set(0));
                          Serial.println(F("Recall EEPROM settings"));
                          recallEeprom(sizeof(StoredIRCodes), (byte *)&StoredIRCodes);
                          // Start the ir receiver
                          irrecv.enableIRIn();
                          Serial.println(F("Init done..."));
                        void presentation ()
                          sendSketchInfo("IR Rec/Playback", "2.0");
                          // Register a sensors to gw. Use binary light for test purposes.
                          present(CHILD_ID, S_IR);
                          if (irrecv.decode(&ircode)) {
                              dump(&ircode);
                              if (progModeId != NO_PROG_MODE) {
                                 // If we are in PROG mode (Recording) store the new IR code and end PROG mode
                                 if (storeRCCode(progModeId)) {
                                    Serial.println(F("Stored "));
                                    // If sucessfull RC decode and storage --> also update the EEPROM
                                    storeEeprom(sizeof(StoredIRCodes), (byte *)&StoredIRCodes);
                                    // Tell MYS Controller that we're done recording
                              } else {
                                 // If we are in Playback mode just tell the MYS Controller we did receive an IR code
                                 if (ircode.decode_type != UNKNOWN) {
                                     if (ircode.value != REPEAT) {
                                       // Look if we found a stored preset 0 => not found
                                       byte num = lookUpPresetCode(&ircode);
                                       if (num) {
                                           // Send IR decode result to the MYS Controller
                                           Serial.print(F("Found code for preset #"));
                                           Serial.println(num);
                                           send(msgIrReceive.set(num));
                            // Wait a while before receive next IR-code (also block MySensors receiver so it will not interfere with a new message)
                            delay(500);
                            // Start receiving again
                            irrecv.resume();
                            //Serial.print(F("New message: "));
                            //Serial.println(message.type);
                           if (message.type == V_IR_RECORD) { // IR_RECORD V_VAR1
                              // Get IR record requets for index : paramvalue
                              progModeId = message.getByte() % MAX_STORED_IR_CODES;
                              // Tell MYS Controller that we're now in recording mode
                              send(msgIrRecord.set(1));
                              Serial.print(F("Record new IR for: "));
                              Serial.println(progModeId);
                           if (message.type == V_IR_SEND) {
                              // Send an IR code from offset: paramvalue - no check for legal value
                              Serial.print(F("Send IR preset: "));
                              byte code = message.getByte() % MAX_IR_CODES;
                              if (code == 0) {
                                code = MAX_IR_CODES;
                              Serial.print(code);
                              sendRCCode(code);
                           // Start receiving ir again...
                        byte lookUpPresetCode (decode_results *ircode)
                            // Get rit of the RC5/6 toggle bit when looking up
                            if (ircode->decode_type == RC5)  {
                                ircode->value = ircode->value & 0x7FF;
                            if (ircode->decode_type == RC6)  {
                                ircode->value = ircode->value & 0xFFFF7FFF;
                            for (byte index = 0; index < MAX_STORED_IR_CODES; index++)
                              if ( StoredIRCodes[index].code.type  == ircode->decode_type &&
                                   StoredIRCodes[index].code.value == ircode->value       &&
                                   StoredIRCodes[index].code.len   == ircode->bits)      {
                                  // The preset number starts with 1 so the last is stored as 0 -> fix this when looking up the correct index
                                  return (index == 0) ? MAX_STORED_IR_CODES : index;
                            for (byte index = 0; index < MAX_PRESET_IR_CODES; index++)
                              if ( PresetIRCodes[index].code.type  == ircode->decode_type &&
                                   PresetIRCodes[index].code.value == ircode->value       &&
                                   PresetIRCodes[index].code.len   == ircode->bits)      {
                                  return ((index == 0) ? MAX_PRESET_IR_CODES : index) + MAX_STORED_IR_CODES;
                            // not found so return 0
                            return 0;
                        // Stores the code for later playback
                        bool storeRCCode(byte index) {
                          if (ircode.decode_type == UNKNOWN) {
                              Serial.println(F("Received unknown code, saving as raw"));
                              // To store raw codes:
                              // Drop first value (gap)
                              // As of v1.3 of IRLib global values are already in microseconds rather than ticks
                              // They have also been adjusted for overreporting/underreporting of marks and spaces
                              byte rawCount = min(ircode.rawlen - 1, MY_RAWBUF);
                              for (int i = 1; i <= rawCount; i++) {
                                StoredIRCodes[index].raw.codes[i - 1] = ircode.rawbuf[i]; // Drop the first value
                              return true;
                        #else
                              return false;
                           if (ircode.value == REPEAT) {
                               // Don't record a NEC repeat value as that's useless.
                               Serial.println(F("repeat; ignoring."));
                               return false;
                           // Get rit of the toggle bit when storing RC5/6
                           if (ircode.decode_type == RC5)  {
                                ircode.value = ircode.value & 0x07FF;
                           if (ircode.decode_type == RC6)  {
                                ircode.value = ircode.value & 0xFFFF7FFF;
                           StoredIRCodes[index].code.type      = ircode.decode_type;
                           StoredIRCodes[index].code.value     = ircode.value;
                           StoredIRCodes[index].code.address   = ircode.address;      // Used by Panasonic & Sharp [16-bits]
                           StoredIRCodes[index].code.len       = ircode.bits;
                           Serial.print(F(" value: 0x"));
                           //Serial.println(ircode.value, HEX);
                           return true;
                        void sendRCCode(byte index) {
                           IRCode *pIr = ((index <= MAX_STORED_IR_CODES) ? &StoredIRCodes[index % MAX_STORED_IR_CODES] : &PresetIRCodes[index - MAX_STORED_IR_CODES - 1]);
                           if(pIr->code.type == UNKNOWN) {
                              // Assume 38 KHz
                              irsend.sendRaw(pIr->raw.codes, pIr->raw.count, 38);
                              Serial.println(F("Sent raw"));
                              return;
                           Serial.print(F(" - sent "));
                           Serial.print(Type2String(pIr->code.type));
                           if (pIr->code.type == RC5) {
                               // For RC5 and RC6 there is a toggle bit for each succesor IR code sent alway toggle this bit, needs to repeat the command 3 times with 100 mS pause
                               pIr->code.value ^= 0x0800;
                               for (byte i=0; i < 3; i++) {
                                 if (i > 0) { delay(100); }
                                 irsend.sendRC5(pIr->code.value, pIr->code.len);
                            else if (pIr->code.type == RC6) {
                               if (pIr->code.len == 20) {
                                      pIr->code.value ^= 0x10000;
                                 irsend.sendRC6(pIr->code.value, pIr->code.len);
                           else if (pIr->code.type == NEC) {
                               irsend.sendNEC(pIr->code.value, pIr->code.len);
                            else if (pIr->code.type == SONY) {
                               irsend.sendSony(pIr->code.value, pIr->code.len);
                            else if (pIr->code.type == PANASONIC) {
                               irsend.sendPanasonic(pIr->code.address, pIr->code.value);
                               Serial.print(AddrTxt);
                               Serial.println(pIr->code.address, HEX);
                            else if (pIr->code.type == JVC) {
                               irsend.sendJVC(pIr->code.value, pIr->code.len, false);
                            else if (pIr->code.type == SAMSUNG) {
                               irsend.sendSAMSUNG(pIr->code.value, pIr->code.len);
                            else if (pIr->code.type == WHYNTER) {
                               irsend.sendWhynter(pIr->code.value, pIr->code.len);
                            else if (pIr->code.type == AIWA_RC_T501) {
                               irsend.sendAiwaRCT501(pIr->code.value);
                            else if (pIr->code.type == LG || pIr->code.type == SANYO || pIr->code.type == MITSUBISHI) {
                               Serial.println(NATxt);
                               return;
                            else if (pIr->code.type == DISH) {
                              // need to repeat the command 4 times with 100 mS pause
                              for (byte i=0; i < 4; i++) {
                                   irsend.sendDISH(pIr->code.value, pIr->code.len);
                            else if (pIr->code.type == SHARP) {
                               irsend.sendSharp(pIr->code.address, pIr->code.value);
                            else if (pIr->code.type == DENON) {
                               irsend.sendDenon(pIr->code.value, pIr->code.len);
                            else {
                              // No valid IR type, found it does not make sense to broadcast
                              return;
                            Serial.print(" ");
                            Serial.println(pIr->code.value, HEX);
                        // Dumps out the decode_results structure.
                        void dump(decode_results *results) {
                            int count = results->rawlen;
                            Serial.print(F("Received : "));
                            Serial.print(results->decode_type, DEC);
                            Serial.print(F(" "));
                            Serial.print(Type2String(results->decode_type));
                            if (results->decode_type == PANASONIC) {
                              Serial.print(results->address,HEX);
                              Serial.print(ValueTxt);
                            //Serial.print(results->value, HEX);
                            Serial.print(F(" ("));
                            Serial.print(results->bits, DEC);
                            Serial.println(F(" bits)"));
                            if (results->decode_type == UNKNOWN) {
                              Serial.print(F("Raw ("));
                              Serial.print(count, DEC);
                              Serial.print(F("): "));
                              for (int i = 0; i < count; i++) {
                                if ((i % 2) == 1) {
                                  Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
                                else {
                                  Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
                                Serial.print(" ");
                              Serial.println("");
                        // Store IR record struct in EEPROM
                        void storeEeprom(byte len, byte *buf)
                            saveState(0, len);
                            for (byte i = 1; i < min(len, 100); i++, buf++)
                               saveState(i, *buf);
                        void recallEeprom(byte len, byte *buf)
                            if (loadState(0) != len)
                               Serial.print(F("Corrupt EEPROM preset values and Clear EEPROM"));
                                   *buf = 0;
                                   storeEeprom(len, buf);
                               return;
                               *buf = loadState(i);
                        Error:
                        C:\Users\Tomas\Documents\Arduino\WeMosIRRemote\WeMosIRRemote.ino: In function 'void storeEeprom(byte, byte*)':
                        WeMosIRRemote:444: error: 'min' was not declared in this scope
                        C:\Users\Tomas\Documents\Arduino\WeMosIRRemote\WeMosIRRemote.ino:444:38: note: suggested alternative:
                        In file included from c:\users\tomas\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\char_traits.h:39:0,
                                         from c:\users\tomas\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\string:40,
                                         from c:\users\tomas\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\stdexcept:39,
                                         from c:\users\tomas\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\array:38,
                                         from c:\users\tomas\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\tuple:39,
                                         from c:\users\tomas\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\functional:55,
                                         from C:\Users\Tomas\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/Schedule.h:4,
                                         from C:\Users\Tomas\Documents\Arduino\libraries\MySensors/core/MyMainESP8266.cpp:22,
                                         from C:\Users\Tomas\Documents\Arduino\libraries\MySensors/MySensors.h:340,
                                         from C:\Users\Tomas\Documents\Arduino\WeMosIRRemote\WeMosIRRemote.ino:54:
                        c:\users\tomas\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:239:5: note:   'std::min'
                             min(const _Tp& __a, const _Tp& __b, _Compare __comp)
                        C:\Users\Tomas\Documents\Arduino\WeMosIRRemote\WeMosIRRemote.ino: In function 'void recallEeprom(byte, byte*)':
                        WeMosIRRemote:455: error: 'min' was not declared in this scope
                        C:\Users\Tomas\Documents\Arduino\WeMosIRRemote\WeMosIRRemote.ino:455:41: note: suggested alternative:
                        WeMosIRRemote:462: error: 'min' was not declared in this scope
                        C:\Users\Tomas\Documents\Arduino\WeMosIRRemote\WeMosIRRemote.ino:462:38: note: suggested alternative:
                        exit status 1
                        • Tomas
                        • P
                          P
                          pjjarzembowski
                          This sketch does't work. I have tried it with arduino nano and arduino mega. It works only as a ir reader with monitor.
                          • P
                            P
                            pjjarzembowski
                            In this code domoticz says that there is a problem with presenting the child. I have change the code in order to present it properly in domoticz.
                            //MyMessage msgIrReceive(CHILD_ID, V_IR_RECEIVE);
                            //MyMessage msgIrRecord(CHILD_ID, V_IR_RECORD);
                            MyMessage msgIrReceive(CHILD_ID, S_IR);
                            MyMessage msgIrRecord(CHILD_ID, S_IR);
                            All dependencys of V_IR_RECEIVE and V_IR_RECORD should also be changed. Just search the code for V_IR_RECEIVE and V_IR_RECORD, then replace it with S_IR.
                              Mash
                              I am having trouble doing IRSensor with domoticz.
                              After pouring the scketch into the arduino, saved my codes and
                              to check that it worked well with MYSController, here's what
                              I obey when I activate the device under Domoticz:
                              "error sending command to the switch, please verify device/hardware"
                              My material in place:
                              Domoticz V. 3.8153 sur Raspberry PI 3
                              Gateway USB MySensor V. 2.1.1 on Arduino Nano
                              IRSensor V. 2.0.0 on Arduino Nano
                              For information in the domoticz log:
                              -The node is well detected
                              2017-12-28 09:07:12.553 MySensors: Node: 7, Sketch Name: IR Rec/Playback
                              2017-12-28 09:07:12.554 MySensors: Node: 7, Sketch Version: 2.0
                              -When I send a pre-recorded order with the remote control
                              2017-12-28 09:07:59.346 (MySensor) Light/Switch (IR Command)
                              -When I activate the device in Domoticz
                              2017-12-28 09:08:29.835 User: Admin initiated a switch command (149/IR Command/Off)
                              2017-12-28 09:08:29.836 Error: MySensors: Light command received for unknown node_id: 6
                              Someone would have any idea?
                              Thanks for your help.
                              Mash
                              sorry for my English
                              • M Mash
                                Mash
                                @mash please don't post the same question in multiple places. Posting in multiple places will divide the discussion, causing people to waste their time.
                                If anyone has any ideas on how to help @mash, do not reply here. Reply in https://forum.mysensors.org/topic/8793/problem-with-irsensor-and-domoticz instead.
                                  Mash
                                  sorry, forgave me I would not do it again
                                  • C
                                    C
                                    czosnekltd
                                    Hello
                                    Using the example sketch from the main thread, I managed to program a few pilot buttons in the domotic. (IR codes are of course entered in the section: IRCode PresetIRCodes [] = (...).
                                    I would, however, "upload" a few IR codes to Domoticz, which would control my TV and AV via the IR diode from the Domoticz level.
                                    In this example, there is the sendRCCode () function, which, in theory, sends an IR code (previously uploaded to Domoticz) via IR diode, if of course it will get
                                    message.type == V_IR_SEND.
                                    I added an additional declaration:
                                    MyMessage msgIrSend (CHILD_ID, V_IR_SEND);
                                    but in Domoticz there was no additional Device that would be responsible for sending IR codes.
                                    I think I probably need to do an additional Dummy Switch, which will send an IR signal transmission command to the gateway / node using JSON.
                                    I'm thinking about it for a long time and I have no idea how to do it in DOMOTICZ.
                                    Please help me how to do it.
                                    • C
                                      C
                                      CV8R
                                      Hi All, has anyone had any success porting this IR sketch example to work with the IRremoteESP8266 library? I am not getting much further than @korttoma.
                                      Thanks CV8R.
                                      • C
                                        C
                                        catchra
                                        wrote on last edited by catchra
                                        #39
                                        Hi everyone I am trying to setup a node to control my A/C unit and am having some trouble.
                                        I am using these libraries
                                        MySensors at version 2.3.2
                                        IRremote at version 2.2.3
                                        My hardware is
                                        Arduino mega 2560
                                        Nrf24
                                        The problem is if i press a button on the remote i get this on the console
                                        Received : -1 UNKONWN B5E9B811 (32 bits)
                                        Raw (38): -17746 8350 -4250 500 -1600 550 -1550 550 -1550 550 -500 450 -1650 550 -600 500 -1550 500 -1550 600 -4100 550 -1550 600 -1500 500 -550 600 -1500 550 -550 550 -500 550 -500 550 -500 650
                                        So i uncommitted this
                                        to this
                                        but now if i compile the code i get this error
                                        exit status 1
                                        'recallEeprom' was not declared in this scope
                                        this is the full sketch
                                        #define MY_RADIO_RF24
                                        #define MY_RF24_DATARATE RF24_1MBPS
                                        #define MY_RF24_CE_PIN 9
                                        #define MY_RF24_CS_PIN 10
                                        int RECV_PIN     = 8;
                                        #define CHILD_ID  2
                                        		"UNKONWN",
                                        		"RC5",
                                        		"RC6",
                                        		"NEC",
                                        		"Sony",
                                        		"Panasonic",
                                        		"JVC",
                                        		"SAMSUNG",
                                        		"Whynter",
                                        		"AIWA RC T501",
                                        		"LG",
                                        		"Sanyo",
                                        		"Mitsubishi",
                                        		"Dish",
                                        		"Sharp",
                                        		"Denon"
                                        typedef union
                                          struct
                                            unsigned long value;           // The data bits if type is not raw
                                            int           len;             // The length of the code in bits
                                            unsigned int  address;         // Used by Panasonic & Sharp [16-bits]
                                          } code;
                                          struct
                                            unsigned int  codes[MY_RAWBUF];
                                          } raw;
                                        } IRCode;
                                        IRsend            irsend;
                                              dump(&ircode);
                                              } else {
                                                       if (num) {
                                            delay(500);
                                            irrecv.resume();
                                              if (code == 0) {
                                              Serial.print(code);
                                              sendRCCode(code);
                                            return 0;
                                              return true;
                                        #else
                                              return false;
                                               return false;
                                           return true;
                                              // Assume 38 KHz
                                              return;
                                               return;
                                            else {
                                              return;
                                            Serial.print(" ");
                                                if ((i % 2) == 1) {
                                                else {
                                                Serial.print(" ");
                                              Serial.println("");
                                            saveState(0, len);
                                               saveState(i, *buf);
                                                   *buf = 0;
                                               return;
                                        • C catchra
                                          My hardware is
                                          Arduino mega 2560
                                          Nrf24
                                          to this
                                          exit status 1
                                          int RECV_PIN     = 8;
                                          #define CHILD_ID  2
                                          		"UNKONWN",
                                          		"RC5",
                                          		"RC6",
                                          		"NEC",
                                          		"Sony",
                                          		"Panasonic",
                                          		"JVC",
                                          		"SAMSUNG",
                                          		"Whynter",
                                          		"AIWA RC T501",
                                          		"LG",
                                          		"Sanyo",
                                          		"Mitsubishi",
                                          		"Dish",
                                          		"Sharp",
                                          		"Denon"
                                          typedef union
                                            struct
                                            } code;
                                            struct
                                            } raw;
                                          } IRCode;
                                          IRsend            irsend;
                                                dump(&ircode);
                                                } else {
                                                         if (num) {
                                              delay(500);
                                              irrecv.resume();
                                                if (code == 0) {
                                                Serial.print(code);
                                                sendRCCode(code);
                                              return 0;
                                                return true;
                                          #else
                                                return false;
                                                 return false;
                                             return true;
                                                // Assume 38 KHz
                                                return;
                                                 return;
                                              else {
                                                return;
                                              Serial.print(" ");
                                                  if ((i % 2) == 1) {
                                                  else {
                                                  Serial.print(" ");
                                                Serial.println("");
                                              saveState(0, len);
                                                 saveState(i, *buf);
                                                     *buf = 0;
                                                 return;
                                          @catchra in bool storeRCCode(byte index) you need to change
                                          #else
                                              return false;
                                          to
                                          #else
                                              return false;
                                          The clue was in the verification output:
                                          C:\Users\Micke\AppData\Local\Temp\arduino_modified_sketch_286541\sketch_may25a.ino: In function 'bool storeRCCode(byte)':
                                          sketch_may25a:271:31: error: a function-definition is not allowed here before '{' token
                                          sketch_may25a:424:3: error: expected '}' at end of input
                                          C:\Users\Micke\AppData\Local\Temp\arduino_modified_sketch_286541\sketch_may25a.ino:424:3: warning: control reaches end of non-void function [-Wreturn-type]
                                          Also, pressing ctrl+t to auto-format the sketch can help a lot.
