  2. Announcements
  3. šŸ’¬ Security & Signing
137 Posts 20 Posters 47.5k Views 19 Watching
  • AnticimexA Anticimex
    @sineverba why did you delete them? There is nothing secret about them. They are sent over your radio link so they are to be considered very public, or signing wouldn't be useful, would it? ;)
    sineverba
    @Anticimex
    I understand :)
    The last thing: what's the sense of this message:
    Skipping security for command 3 type 17
    Thank you!
    AnticimexA 1 Reply Last reply
    • S sineverba
      @Anticimex
      I understand :)
      Thank you!
      AnticimexA
      AnticimexA
      Anticimex
      #42
      @sineverba it means that message is not signed. Because it is of a type not suitable for signing. Typically an ack or a handshake message. You can look the type up in the api specification. In this case it is a handshake message (a nonce reply to be precise).
      • S
        sindrome73
        Hello!! I'm also trying to implement SOFT Signature, but because of my poor English I have many problems !!
        Someone could post the socket of a node + a working MQTT gateway.
        So you can study the code and understand how it works !!!
        Thanks 1000 in advance to who can help me
        • S sindrome73
          AnticimexA
          AnticimexA
          Anticimex
          @sindrome73 There is no difference for a MQTT gw than from other GW:s. There are code examples in the documentation. See this post and follow the Doxygen links.
          • S
            sindrome73
            As I said, my English is not good and therefore it is difficult for me to follow the discussions.
            That's why I was asking for a snapshot already done, in order to study the code and understand how to solve ....
            Ā  If anyone can help me ????
            • S sindrome73
              AnticimexA
              AnticimexA
              Anticimex
              @sindrome73 I am afraid it will be difficult to help if you can't read the code. There is code in the documentation, and you ask for code? There is also a sequence of steps required to do personalization, so you have to be able to understand english to some extent, or find someone who can translate for you.
              If it helps, I have pasted the code here in case you for some reason can't find it (I assume you use a official 2.0 release):
              How to use this
              Before we begin with the details, I just want to emphasize that signing is completely optional and not enabled by default. If you do want the additional security layer signing provides, you pick the backend of your choise in your sketch. Currently, two compatible backends are supported; MY_SIGNING_ATSHA204 (hardware backed) and MY_SIGNING_SOFT (software backed). You can either enable these globally in MyConfig.h or in your sketch for sketch specific/local use.
              Firstly, you need to make sure to pick a backend to use as described above.
              //#define MY_SIGNING_SOFT
              #define MY_SIGNING_ATSHA204
              Make sure to set the define before the inclusion of MySensors.h. It is legal to mix hardware- and software-based backends in a network. They work together.
              You also need to decide if the node (or gateway) in question require and verify signatures in addition to calculating them. This has to be set by at least one of the node in a "pair" or nobody will actually start calculating a signature for a message. Just set the flag MY_SIGNING_REQUEST_SIGNATURES and the node will inform the gateway that it expects the gateway to sign all messages sent to the node. If this is set in a gateway, it will NOT force all nodes to sign messages to it. It will only require signatures from nodes that in turn require signatures. If it is desired that the gateway should require signatures from all nodes, MY_SIGNING_GW_REQUEST_SIGNATURES_FROM_ALL can be set in the gateway sketch.
              If you want to have two nodes communicate securely directly with each other, the nodes that require signatures must send a presentation message to all nodes it expect signed messages from (only the gateway is informed automatically). See signerPresentation().
              A node can have three "states" with respect to signing:
              Node does not support signing in any way (neither MY_SIGNING_ATSHA204 nor MY_SIGNING_SOFT is set)
              Node does support signing but don't require messages sent to it to be signed (MY_SIGNING_REQUEST_SIGNATURES is not set)
              Node does support signing and require messages sent to it to be signed (MY_SIGNING_REQUEST_SIGNATURES is set)
              Secondly, you need to verify the configuration for the backend.
              For hardware backed signing it is the pin the device is connected to. In MyConfig.h there are defaults which you might need to adjust to match your personal build. The setting is defined using MY_SIGNING_ATSHA204_PIN and the default is to use pin A3.
              Similar to picking your backend, this can also be set in your sketch:
              #define MY_SIGNING_ATSHA204_PIN 4
              For the software backed signingbackend, an unconnected analog pin is required to set a random seed for the pseudo-random generator. It is important that the pin is floating, or the output of the pseudo-random generator will be predictable, and thus compromise the signatures. The setting is defined using MY_SIGNING_SOFT_RANDOMSEED_PIN and the default is to use pin A7. The same configuration possibilities exist as with the other configuration options.
              Thirdly, if you use the software backend, you need to personalize the node (see personalization).
              #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
              An example of a node that require signatures is available in SecureActuator.ino.
              • S
                sineverba
                I image not, but... the pin need to be to same in every node?
                And.. will the library auto manage the PIN (in this case the #7) rendering it floating or need to explicity set it as INPUT on sketch?
                Thank you!
                AnticimexA mfalkviddM 2 Replies Last reply
                • S sineverba
                  Thank you!
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @sineverba It is assumed that you do any configurations in your sketch, before including MySensors.h so no, it does not need to be the same on every node. It just need to be left unconnected. And yes, the library takes care of the rest.
                  • S sineverba
                    Thank you!
                    The pin does not need to be the same.
                    The library will set it to the required mode, there is no need to do anything in the sketch.
                    • pepsonP
                      pepsonP
                      pepson
                      Hi
                      I have a gateway mysensors on my RPI3 with radio RFM69HW. Is any chance to build gateway on RPI3 but also with chip ATSHA204A ? And how build it...
                      • pepsonP pepson
                        Hi
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @pepson the driver has not been designed with rPi in mind. And you'd probably be better off with an I2C variant for rPi. But we currently don't offer a driver for that so you'd have to write it yourself.
                        But, for a gw, you typically keep those secured physically, so using a atsha device is less important, compared to "roaming" nodes.
                        pepsonP 1 Reply Last reply
                          pepsonP
                          pepsonP
                          pepson
                          @anticimex
                          I don't understand. I want secure my nodes... By Atsha204a. How I can secure it by other solution.
                          • pepsonP pepson
                            @anticimex
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @pepson I have implemented a sw emulator for the atsha which offers compatible security infrastructure but without readout protection. Readout protection is needed if someone steals your node and extracts your hmac key. Your gw won't typically be stolen, so it don't need readout protection and can rely on the soft signing option which is compatible with nodes using atsha204a personalized with the same hmac key. The rPi port support the atsha204a emulator so you can use that to secure nodes that has a real atsha204a device.
                              pepsonP
                              pepsonP
                              pepson
                              @anticimex
                              Can you show me full manual how implement it on Gateway on RPI and how add this to sketch on nodes ? Please...
                              If you can describe me very good. I am begginer...
                              • pepsonP pepson
                                @anticimex
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @pepson you have the links to the documentation in the article this thread is commenting on. At the very top.
                                  pepsonP
                                  pepsonP
                                  pepson
                                  @anticimex
                                  But please show me as you have to have example...
                                  AnticimexA S 2 Replies Last reply
                                  • pepsonP pepson
                                    @anticimex
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @pepson I don't run on raspberry pi so I don't. But the documentation does have specific configuration examples for raspberry pi, so you have all information needed listed there in "how to use this" section.
                                    • pepsonP pepson
                                      @anticimex
                                      sineverba
                                      @pepson see here for 2.2.0 and on left menu for 2.3.0
                                      https://github.com/sineverba/domapi/wiki/MySensors-2.2.0-Security-and-signin
                                      • S sineverba
                                        pepsonP
                                        pepsonP
                                        pepson
                                        wrote on last edited by pepson
                                        #59
                                        @sineverba
                                        Very very good manuals...
                                        But i dont understand what i must type number in this placeand how get it ? It is MAC number network from RPI ?:
                                        #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0Xaa,0Xbb,0Xcc,0XF9,0X82,0XB2,0X50,0XF2,0XAB}}} // got from gateway setup
                                        And what is diffrent with MySensors 2.3.0 ?
                                        I must do all point from MySensors 2.2.0 and additional point for 2.3.0 ?
                                        After got your ./configure instruction, type
                                        sudo nano /etc/mysensors.conf
                                        And add your KEYs to the specific section on bottom of the file.
                                        To get your first KEYs follow guide for 2.2.0
                                        And in version 2.3.0 i must do this under building gateway ?
                                        And add serial,HMAC,AES in this place in mysensors.conf
                                        Software signing settings
                                        Note: The gateway must have been built with signing
                                        support to use the options below.
                                        To generate a HMAC key run mysgw with: --gen-soft-hmac-key
                                        copy the new key in the line below and uncomment it.
                                        #soft_hmac_key=
                                        To generate a serial key run mysgw with: --gen-soft-serial-key
                                        #soft_serial_key=
                                        Encryption settings
                                        Note: The gateway must have been built with encryption
                                        To generate a AES key run mysgw with: --gen-aes-key
                                        #aes_key=
                                        and then build gateway ?
                                        S 1 Reply Last reply
                                        • pepsonP pepson
                                          @sineverba
                                          #soft_hmac_key=
                                          #soft_serial_key=
                                          Encryption settings
                                          #aes_key=
                                          sineverba
                                          @pepson You use RFM69(H/W/HW). So I. My hint is remain with 2.2.0. I got so many issues with 2.3.0 and RFM that I reverted to 2.2.0 in 1 minute.
                                          HMAC is not LAN MAC, is HMAC got from MYsensors gateway. Same for other 2 keyes.
                                          I think that in long explain on my guide you have all info to get your keyes. I follow my same guide everytime I need to reinstall mysensors / domoticz / an entire PI. It is fully tested :)
                                          With your input, this post could be even better šŸ’—
