  2. Announcements
  3. 💬 Security & Signing
137 Posts 20 Posters 47.5k Views 19 Watching
  • pepsonP pepson
    @anticimex
    What you mean white list?
    Before adding all security my nodes and gateway works perfect.
    AnticimexA
    AnticimexA
    Anticimex
    @pepson you define whitelisting so I presume you use it. But I don't see your gw flags specifying it so of course it does not work. So get rid of that flag from your config unless you know what it mean so that you set it up properly.
    pepsonP 1 Reply Last reply
    • AnticimexA Anticimex
      pepsonP
      pepsonP
      pepson
      @anticimex
      What flag i must remove ?
      This :
      #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0X2C,0X61,0X17,0X2E,0XEE,0XDD,0XCC,0XBB,0XAA}}} // got from gateway setup
      But on GW i setup this:
      sudo mysgw --set-soft-serial-key=2C61172EEEDDCCBBAA && sudo mysgw --set-aes-key=9D2AD43CF909875C4C77111111111111 && sudo mysgw --set-soft-hmac-key=A2A64C48EA6765C5DAEFA12A1E41E2F038515A9CAED9FED73D11111111111111
      AnticimexA 1 Reply Last reply
      • pepsonP pepson
        @anticimex
        This :
        AnticimexA
        AnticimexA
        Anticimex
        @pepson please just read the documentation. And more importantly, follow it.
        Isn't it obvious that it is the flag that mention whitelisting that is supposed to be removed unless you intend to use whitelisting, in which case you ought to know how to set it up properly at both ends?
          pepsonP
          pepsonP
          pepson
          wrote on last edited by pepson
          #84
          @anticimex
          Sorry i dont undestand
          • pepsonP pepson
            @anticimex
            AnticimexA
            AnticimexA
            Anticimex
            @pepson https://www.mysensors.org/apidocs/group__MySigninggrpPub.html
            Note that it is the documentation for the latest release (simple password flags work differently compared to previous releases, see release notes for the latest release).
            • pepsonP
              pepsonP
              pepson
              HI
              i don as describe...
              1. install gateway on raspberry with this configuration:
                ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw --my-gateway=ethernet --my-port=5003 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-signing=software --my-signing-request-signatures --my-signing-weak_security --my-signing-debug
              and then generate serial, aes and hmac
              pi@raspberrypi:~/MySensors $ sudo mysgw --gen-soft-serial-key
              SOFT_SERIAL | 8FC828503E6EB14C5D
              The next line is intended to be used in SecurityPersonalizer.ino:
              #define MY_SOFT_SERIAL 0X8F,0XC8,0X28,0X50,0X3E,0X6E,0XB1,0X4C,0X5D
              To use this key, run mysgw with:
              --set-soft-serial-key=8FC828503E6EB14C5D
              pi@raspberrypi:~/MySensors $ sudo mysgw --gen-soft-hmac-key
              SOFT_HMAC_KEY | 0D682ED05106E5F361C64288D68AAE1B34F5FFB62B4E39773C9D92DED04B6514
              #define MY_SOFT_HMAC_KEY 0XD,0X68,0X2E,0XD0,0X51,0X6,0XE5,0XF3,0X61,0XC6,0X42,0X88,0XD6,0X8A,0XAE,0X1B,0X34,0XF5,0XFF,0XB6,0X2B,0X4E,0X39,0X77,0X3C,0X9D,0X92,0XDE,0XD0,0X4B,0X65,0X14
              --set-soft-hmac-key=0D682ED05106E5F361C64288D68AAE1B34F5FFB62B4E39773C9D92DED04B6514
              pi@raspberrypi:~/MySensors $ sudo mysgw --gen-aes-key
              AES_KEY | 8FDB1EE8D0351CFF874D337731BF37AE
              #define MY_AES_KEY 0X8F,0XDB,0X1E,0XE8,0XD0,0X35,0X1C,0XFF,0X87,0X4D,0X33,0X77,0X31,0XBF,0X37,0XAE
              --set-aes-key=8FDB1EE8D0351CFF874D337731BF37AE
              and setup it on my gateway
              sudo mysgw --set-soft-serial-key=8FC828503E6EB14C5D && sudo mysgw --set-aes-key=8FDB1EE8D0351CFF874D337731BF37AE && sudo mysgw --set-soft-hmac-key=0D682ED05106E5F361C64288D68AAE1B34F5FFB62B4E39773C9D92DED04B6514
              all is ok to this moment
              Then
              1. clear eeprom in node Arduino pro mini with this sketch:
                https://github.com/sineverba/domoraspi/tree/master/utils/sketches
              2. write sketch security with setup my serial, aes and hmac
              at the top setup...
              /************************************ User defined key data ***************************************/
              /** @brief The user-defined HMAC key to use unless @ref GENERATE_HMAC_KEY is set */
              //#define MY_HMAC_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
              #define MY_HMAC_KEY 0XD,0X68,0X2E,0XD0,0X51,0X6,0XE5,0XF3,0X61,0XC6,0X42,0X88,0XD6,0X8A,0XAE,0X1B,0X34,0XF5,0XFF,0XB6,0X2B,0X4E,0X39,0X77,0X3C,0X9D,0X92,0XDE,0XD0,0X4B,0X65,0X14
              /** @brief The user-defined AES key to store in EEPROM unless @ref GENERATE_AES_KEY is set */
              //#define MY_AES_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
              /** @brief The user-defined soft serial to use for soft signing unless @ref GENERATE_SOFT_SERIAL is set */
              /***************************** Flags for guided personalization flow ******************************/
              1. then write my sketch relay with added at the top this info:
              #define MY_SIGNING_SOFT
              #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
              #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0X8F,0XC8,0X28,0X50,0X3E,0X6E,0XB1,0X4C,0X5D}}} // got from gateway setup
              and now on my Home assistant in file
              /home/homeassistant/.homeassistant/mysensors.json
              found my node but wthout full information like name....
              "0": {
              "battery_level": 0,
              "sketch_name": null,
              "sketch_version": null,
              "children": {},
              "type": 18,
              "protocol_version": "2.2.0",
              "sensor_id": 0
              "33": {
              "battery_level": 0,
              "sketch_version": "1.0",
              "children": {
              "1": {
              "type": 3,
              "id": 1,
              "values": {
              "2": "1"
              "description": ""
              "type": 17,
              "sensor_id": 33
              and in Home Assistant is not show in devices this node. Not found it.
              What i done wrong ?
              AnticimexA S 2 Replies Last reply
              • pepsonP pepson
                HI
                Then
                at the top setup...
                "0": {
                "battery_level": 0,
                "children": {},
                "type": 18,
                "sensor_id": 0
                "33": {
                "battery_level": 0,
                "children": {
                "1": {
                "type": 3,
                "id": 1,
                "values": {
                "2": "1"
                "description": ""
                "type": 17,
                "sensor_id": 33
                What i done wrong ?
                AnticimexA
                AnticimexA
                Anticimex
                @pepson said in 💬 Security & Signing:
                How many times do I need to tell you to get rid of the whitelisting flag?
                  pepsonP
                  pepsonP
                  pepson
                  @anticimex
                  Ok read... but...
                  when i use MY_SIGNING_NODE_WHITELISTING i must on node in sketch add serial number my gateway and also serial number for node. But from where i can get serial number for my arduino pro mini ? I dont know...becasue i don use ATSHA204 but i use only soft signing....
                  S 1 Reply Last reply
                  • pepsonP pepson
                    @anticimex
                    Ok read... but...
                    sineverba
                    @pepson This is the serial OF GATEWAY. Not your Arduino. You need to put serial of GATEWAY.
                    Please, first of all, DONT' USE WHITELISTING. And pay attention: if you enabled it, remove it and:
                    1 - clear eeprom
                    2 - flash eeprom with keyes
                    3 - reload sketch (without whitelisting)
                    • pepsonP pepson
                      HI
                      Then
                      at the top setup...
                      "0": {
                      "battery_level": 0,
                      "children": {},
                      "type": 18,
                      "sensor_id": 0
                      "33": {
                      "battery_level": 0,
                      "children": {
                      "1": {
                      "type": 3,
                      "id": 1,
                      "values": {
                      "2": "1"
                      "description": ""
                      "type": 17,
                      "sensor_id": 33
                      What i done wrong ?
                      sineverba
                      wrote on last edited by sineverba
                      #90
                      @pepson Don't need all copy and paste, enough link :).
                      Btw, before move to Home Assistant, where is the output of debug of MySensors?
                      sudo mysgw -d
                      Of course, you need before stop service.
                      Resetting the node, what you get in debug?
                      When ALL ok, move to HomeAssistant.
                      And remember, after check that debug is ok...
                      sudo make install && sudo systemctl enable mysgw.service && sudo systemctl start mysgw.service
                      • pepsonP
                        pepsonP
                        pepson
                        In my first time I use only serial number gateway in flag whitelistening and also not working.
                        • pepsonP pepson
                          sineverba
                          @pepson Last time. Please.
                          REMOVE
                          WHITELISTING
                          FROM
                          YOUR
                          SKETCH
                          Clear EEPROM and paste here output of debug. No other.
                          • S sineverba
                            REMOVE
                            WHITELISTING
                            FROM
                            YOUR
                            SKETCH
                            pepsonP
                            pepsonP
                            pepson
                            @sineverba
                            OK wait for info
                            • pepsonP pepson
                              @sineverba
                              OK wait for info
                              pepsonP
                              pepsonP
                              pepson
                              #94
                              @pepson
                              Ok i removed Whitelisting and switch is show in Hoem Assistant and works.
                              pi@raspberrypi:~/MySensors $ sudo ./bin/mysgw -d
                              mysgw: Starting gateway...
                              mysgw: Protocol version - 2.2.0
                              mysgw: MCO:BGN:INIT GW,CP=RPNGLS--,VER=2.2.0
                              mysgw: SGN:PER:OK
                              mysgw: SGN:INI:BND OK
                              mysgw: TSF:LRT:OK
                              mysgw: TSM:INIT
                              mysgw: TSF:WUR:MS=0
                              mysgw: TSM:INIT:TSP OK
                              mysgw: TSM:INIT:GW MODE
                              mysgw: MCO:REG:NOT NEEDED
                              mysgw: Listening for connections on 0.0.0.0:5003
                              mysgw: MCO:BGN:STP
                              mysgw: MCO:BGN:INIT OK,TSP=1
                              mysgw: TSF:MSG:READ,3-3-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
                              mysgw: !SGN:VER:NSG
                              mysgw: !TSF:MSG:SIGN VERIFY FAIL
                              mysgw: TSF:MSG:READ,33-33-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                              mysgw: SGN:SKP:MSG CMD=3,TYPE=16
                              mysgw: SGN:SKP:MSG CMD=3,TYPE=17
                              mysgw: TSF:MSG:SEND,0-0-33-33,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                              mysgw: SGN:NCE:XMT,TO=0
                              mysgw: TSF:MSG:READ,33-33-0,s=255,c=3,t=1,pt=0,l=0,sg=1:
                              mysgw: SGN:BND:NONCE=44E4127024F4EB1003DCBF3701D8469E4664CC454E2A20A257AAAAAAAAAAAAAA
                              mysgw: SGN:BND:HMAC=E1EE2D4046FEF0AEC323AA737A8367A2F290CCEFB7A4663448AD0B155FFD5A74
                              mysgw: SGN:VER:OK
                              mysgw: TSF:MSG:READ,33-33-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                              mysgw: TSF:MSG:READ,33-33-0,s=1,c=1,t=2,pt=1,l=1,sg=1:0
                              mysgw: SGN:BND:NONCE=4AD7D9430FA96BBD0B18D4F57480F009BE31C6F3821F182766AAAAAAAAAAAAAA
                              mysgw: SGN:BND:HMAC=3AADB41A42B91C0B2137BE2C2C76F57E3ADB7082F3669DECCA85B993C955D36E
                              mysgw: SGN:VER:OK
                              mysgw: TSF:MSG:READ,33-33-0,s=1,c=1,t=2,pt=1,l=1,sg=1:1
                              mysgw: SGN:BND:NONCE=B272E537F5C6DAF21A0C5042078EFCFD3A02B5C61F698792AAAAAAAAAAAAAAAA
                              mysgw: SGN:BND:HMAC=5AF82BD16724069A436E0735229D32F532108A45407EF0DE7CABDADA1F7E39A0
                              mysgw: SGN:VER:OK
                              mysgw: !SGN:VER:NSG
                              mysgw: SGN:BND:NONCE=61F78D66E675349B8A63B1370E81D2D1AB44BC1D0BB1F988D6AAAAAAAAAAAAAA
                              mysgw: SGN:BND:HMAC=04EEE2B60E0C71CC092E13C68C07F3088D66F264A826C23426053C17C2353DED
                              mysgw: SGN:VER:OK
                              mysgw: SGN:BND:NONCE=627FAEEEFFFD6E55F371C07A54F785FDA3EE52EBD4092E0CE9AAAAAAAAAAAAAA
                              mysgw: SGN:BND:HMAC=65503227CDB04C1A2DCB03D0E5BAFD35A4EBA956E8EBA917B2DF40FB09520092
                              mysgw: SGN:VER:OK
                              mysgw: !SGN:BND:VER ONGOING
                              mysgw: !SGN:VER:FAIL
                              mysgw: SGN:BND:NONCE=32CE07784E14ED2B6D455C2C5C4D83E025185970838C0B743AAAAAAAAAAAAAAA
                              mysgw: SGN:BND:HMAC=F04885315D93DB7FC95F3B190D68009055495ECEE698E0ADF6F50292157A8927
                              mysgw: SGN:VER:OK
                              mysgw: SGN:BND:NONCE=3DAAB19C10BB3CB8A08CDAACED4BFB385F1EB22AA9F926F940AAAAAAAAAAAAAA
                              mysgw: SGN:BND:HMAC=392AB4EAFDE59AC0CC9BE6EE667FC33A69A33E86AD5CB3EC49C6C114722941F5
                              mysgw: SGN:VER:OK
                              mysgw: SGN:BND:NONCE=CF101801DA5324E2F66C3B9350E8FC2BCCBD337E3F588EBE2FAAAAAAAAAAAAAA
                              mysgw: SGN:BND:HMAC=53795E79C8FE9D599D1A88363F7E2BA607ADBB265E4E99356886B65C3D0A06D0
                              mysgw: SGN:VER:OK
                              mysgw: !SGN:VER:NSG
                              • pepsonP pepson
                                @pepson
                                mysgw: SGN:PER:OK
                                mysgw: TSF:LRT:OK
                                mysgw: TSM:INIT
                                mysgw: TSF:WUR:MS=0
                                mysgw: MCO:BGN:STP
                                mysgw: !SGN:VER:NSG
                                mysgw: SGN:VER:OK
                                mysgw: SGN:VER:OK
                                mysgw: SGN:VER:OK
                                mysgw: !SGN:VER:NSG
                                mysgw: SGN:VER:OK
                                mysgw: SGN:VER:OK
                                mysgw: SGN:VER:OK
                                mysgw: SGN:VER:OK
                                mysgw: SGN:VER:OK
                                mysgw: !SGN:VER:NSG
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @pepson your gw is configured to require signing from all nodes.
                                Your node 33 is set up to use signing. Your node 3 is not. Hence messages from node 3 will be rejected by the GW.
                                Either set up all nodes to use signing or set up weak security on the GW to only require signing from nodes that require it in turn.
                                This is documented behaviour. Please read the documentation. That is what it is for.
                                • pepsonP
                                  pepsonP
                                  pepson
                                  But still I don't know how use white listening...?
                                  • pepsonP pepson
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @pepson I suggest you avoid it. It require good tracking of all serials in your network and is part of the more advanced security mechanisms. And I suspect you will get issues when you add new nodes to your network as you cannot get it to work with just two nodes (you still have not enabled it on your gw). So just avoid whitelisting all together.
                                      pepsonP
                                      pepsonP
                                      pepson
                                      #98
                                      @anticimex
                                      OK but how I can get serial from my Node on Arduino Pro Mini?
                                      And when I want use chip AtSHA204A what I must change on my GW and on Node?
                                      Can I build GW on Rpi with this chip AtSHA204A?
                                      • pepsonP pepson
                                        @anticimex
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @pepson Please. Read. The. Documentation.
                                        And no, atsha204a is not supported on rPi. Nor does it need to be.
                                          pepsonP
                                          pepsonP
                                          pepson
                                          @anticimex
                                          But still I don't know how read serial number from Node on Arduino Mini Pro when I want use White Listening...
