  3. Ethernet gateway with ENC28J60 radio fail
2 Posts 2 Posters 1.3k Views 3 Watching
    A Former User
    Hi, i hope some one can help here.
    Im trying to build a ethernet gate way, and i have the ENC28J60 module. First i tried following the wiring on this page in the ENC28J60 section.
    https://www.mysensors.org/build/ethernet_gateway
    And did by splitting my cables to get on pin out to both the ethernet module and the radio. I upload the sketch from there, but i got a radio fail. I tried unplugging the ethernet module, and then the radio worked.
    I then tried to do the wiring from the W5100 section and i then modified the sketch using som code from the W5100 sketch, to get the new pins in. So the sketch looked like.
     * Version 1.0 - Henrik EKblad
     * Contribution by Tomas Hozza <thozza@gmail.com>
     * LED purposes:
    #define MY_SOFTSPI
    #define MY_RF24_CE_PIN 5
    #define MY_RF24_CS_PIN 6
    #define MY_GATEWAY_ENC28J60
    // Gateway IP address
    #define MY_IP_ADDRESS 192,168,178,66
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
    #include <UIPEthernet.h>
    But im still getting a radio fail. I have also tried swapping the radio out, with one that i know for surtane is working.
    Hope some one can help.
    • peterjacksonP
      peterjacksonP
      peterjackson
      This is quite old - but I found this while having the same issues. Solved by moving the NRF24 pins around like this:
      // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
      // When ENC28J60 is connected, move SCK, MI and MO pins and enable SPI
      #define MY_SOFTSPI
      #define MY_SOFT_SPI_SCK_PIN 7
      #define MY_SOFT_SPI_MISO_PIN 8
      #define MY_SOFT_SPI_MOSI_PIN 9
      And of course move the radio pins around.
