  3. Should I modifymy IDE once I am changing from Arduino Nano to ProMini ?
7 Posts 4 Posters 2.5k Views 2 Watching
  • mehrdad.silataniM
    mehrdad.silataniM
    mehrdad.silatani
    wrote on last edited by mehrdad.silatani
    I ran into a confusing problem. So the story is;
    I made an IDE which combines the DHT, LDR and a RELAY "mysensor" libraries together in one single code. Then I uploaded it to my Arduino Nano for testing, everything went smoothly and fine and I got all the readings on my HA.
    The problem started once I uploaded the same code to my Arduino Pro mini (I changed the board and port before uploading), and then for some reason, it keeps telling "It failed to read temp/hum from DHT". Believe me I doubled checked pin numbers, wires, and everything I still get the same error. Even when I changed to another Promini, I got the same error. And to add to my confusion, without changing anything, once I put the Nano back on, everything started to work and it could read data from DHT !
    So now I have two questions in my head;
    1. Is it possible that some "mysensors" libraries are incompatible with certain boards ?
    2. Simply, is there any difference between pin D3 on a Promini and a Nano ? (maybe ProMini can't provide the current required by DHT ... ?)
    Would really appreciate any suggestion,
    Cheers,
    Mehrdad
    • scalzS
      scalzS
      wrote on last edited by scalz
      Hello.
      1. Mysensors is compatible with nano, mini pro, no problem
      2. No difference..and atmel can go up to 40mA max but 20mA is recommanded.
      So, perhaps a bad quality wire?? Have you tried to run your mini pro with the example sketch from the dht lib?
      mehrdad.silataniM 1 Reply Last reply
      • mehrdad.silataniM mehrdad.silatani
        Cheers,
        Mehrdad
        @mehrdad.silatani - how are you powering your node? The Nano uses 5v and if you use a 3.3v pro mini with batteries that drops below 3.3v the DHT22 will not work.
        Its not about the IDE/Sketch or board. I think its a power issue of some sort.
        • scalzS scalz
          Hello.
          mehrdad.silataniM
          mehrdad.silataniM
          mehrdad.silatani
          @scalz Thank you for your reply.
          Not a chance that it is the bad quality wire, cause Nano works on the very same wiring.
          Following your suggestion, I tested the Pro mini with the example sketch of dht lib. I get a weired outputs on my serial port (baud rate is matching to the defined rate on sketch, I even tried all other baud rates anyway ...)
          0_1474574981524_upload-81d68cc8-d35f-42fc-ae02-d1e1ea3999e7
          • sundberg84S sundberg84
            mehrdad.silataniM
            mehrdad.silataniM
            mehrdad.silatani
            @sundberg84 The whole system is currently working on 5V adapter which is fed to the RAW port of Promini and then I am powering the sensor from "Vcc" port.
            Anyway, I checked the voltage across the DHT11 sensor and my voltmeter shows 4.98 V. So I dont think the power is the problem ...I think this has been flagged before by other people as well, See-> (https://forum.mysensors.org/topic/1894/pro-mini-is-giving-a-frequent-time-out-on-dth11-read-out/9)
            I even tried two different Pro mini boards ! still no luck !
            • mehrdad.silataniM
              mehrdad.silataniM
              mehrdad.silatani
              Ok out of curiosity, i changed my processor from "5V 16Mhz" to "3.3V 8Mhz" and then everything started to work all of a sudden !
              How can you tell what processor is used on your board ? I checked my order, and I am confident that I ordered the 5V 16MHz version ... so I guess I've been sent the wrong devices !
                @mehrdad.silatani here are some suggestions: http://arduino.stackexchange.com/questions/8511/how-to-identify-arduino-mini-pro-5v-vs-3-3v
                One of them is basically what you did, load a sketch and see if all timings are off by 2x. But always try with 3.3V since 5V can damage a board built for 3.3V.
