  3. Domoticz
  4. Using the "Selector switch" in Domoticz (tutorial)
8 Posts 5 Posters 32.4k Views 11 Watching
  • AWIA
    AWIA
    AWI
    wrote on last edited by AWI
    Domoticz features a special switch type named "Selector switch" . This switch type can serve many MySensors purposes. In this walk through it is used for selecting different light patterns in my Wall mounted 'mood light'.
    A "button set"
    0_1474613749068_upload-5c2bdf83-e135-4b01-a842-f8bf16b2c468
    or "select menu"
    0_1474613812167_upload-ff85302a-8b41-4033-8654-f3d85a0a2351
    Essentially it is (or can be) a switch which controls another device. In this case I use it to control a dimmer. Let's start.
    1. Create a virtual hardware device (if you have not already done so before)
    0_1474614096927_upload-fdbc81ca-84db-4f95-8a4c-36d9434bde72
    1. Create a new "Virtual Sensor" with type "Selector Switch" by pressing the "Create Virtual Sensors" button.
      0_1474614259118_upload-dfadaa31-681c-4100-9f65-7e9b77705850
      you can also use the "Manual Light/Switch" button in the "Switches" tab.
      0_1474614203400_upload-fc866b82-9544-43ac-ad46-280721ae59eb
    This will create a new Virtual selector switch.
    0_1474614396110_upload-9189aef8-4502-43ce-bbb5-386dc84d6cb1
    I will use this to control a dimmer device which output is used to set the light patterns in the mood light
    0_1474614481046_upload-803f08fb-dda1-4142-8677-d9fb706ad9bd
    1. In the devices tab find the "Dimmer you want the Selector attached to (in this case RGB Wall Pattern W 62" with index 971
      0_1474614623251_upload-a4eb98fa-e59f-4915-a4aa-a970f8ab57c6
    "Edit" the newly created Selector switch and for each of the selector states attach a command to be executed.
    The commands here can be pretty much anything but here I used the Domoticz JSON command to set the Dimmer to one of the 16 possible states (Yes, a dimmer can only asume 16 states). You need to put your own domoticz URL/IP and port number in there. "Idx" is the dimmer device index from the previous step.
    A maximum of 10 switch values can be assigned
    :exclamation: don't forget to save :sweat:
    0_1474614939249_upload-825741bf-c2ee-4538-ad15-7881f12fc4ca
    I deliberately did not set "level 1" , because this translates to "0" and is associated with the off state in my case (room light)
    for the copycats (don't forget to include your own values):
    http://192.168.2.110:8080/json.htm?type=command&param=switchlight&idx=971&switchcmd=Set%20Level&level=0
    That's it. Now when you press a selector button it switches the dimmer value.
    In your sketch you can translate the dimmer values to differenct actions. Have a look at the Wall light sketch for an example.
    • AWIA
      AWIA
      AWI
      To make the tutorial complete, below the MySensors receive routine to handle the input ( ;-) @Reza )
      // Incoming messages from MySensors
      // Template to demonstrate use of V_PERCENTAGE for Selector Switch in Domoticz
          int ID = message.sensor;
      	int mySwitch = 0 ;
          Serial.print("Sensor: ");
          Serial.println(ID);
          switch (ID){											// If different sensors for this node
              case sensorID:				                        // the number of the V_PERCENTAGE sensor to be controlled
                  if (message.type == V_PERCENTAGE) {             //  Percentage indicates the pattern
                      mySwitch = map(message.getInt(), 0, 100, 0, 15); // mapper dimmer values to Switch states 0..9  and wrap
      				switch (mySwitch){
      					case 0:
      						{ } // whatever on switch action 0
      					break ;
      					case 1:
      						{ } // whatever on switch action 1
      					break ;
      					case 2:
      						{ } // whatever on switch action 2
      					break ;
      					case 3:
      						{ } // whatever on switch action 3
      					break ;
      					case 4:
      						{ } // whatever on switch action 4
      					break ;
      					// etc. max switch actions in Domoticz = 10
                  break ;
      R 1 Reply Last reply
      • AWIA AWI
        	int mySwitch = 0 ;
            Serial.println(ID);
        				switch (mySwitch){
        					case 0:
        					break ;
        					case 1:
        					break ;
        					case 2:
        					break ;
        					case 3:
        					break ;
        					case 4:
        					break ;
                    break ;
        R
        R
        Reza
        @AWI
        my friend , I'm embarrassed , answer in forum
        i'am sorry .
        so i upload this sketch in ir sensor :
        // Enable debug prints
        #define MY_RF24_CHANNEL 0
        #define MY_REPEATER_FEATURE
        #include <IRLib.h>
        int RECV_PIN = 8;
        #define CHILD_1  3  // childId
        IRsend irsend;
        IRrecv irrecv(RECV_PIN);
        IRdecode decoder;
        //decode_results results;
        unsigned int Buffer[RAWBUF];
        MyMessage msg(CHILD_1, V_VAR1);
          irrecv.enableIRIn(); // Start the ir receiver
          decoder.UseExtnBuf(Buffer);
        void presentation()  {
          sendSketchInfo("IR Sensor", "1.0");
          // Register a sensors to  Use binary light for test purposes.
          present(CHILD_1, S_LIGHT);
          if (irrecv.GetResults(&decoder)) {
            irrecv.resume();
            decoder.decode();
            decoder.DumpResults();
            char buffer[10];
            sprintf(buffer, "%08lx", decoder.value);
            // Send ir result to gw
            send(msg.set(buffer));
            int mySwitch =
            Serial.println(ID);
                case sensorID:                                      // the V_PERCENTAGE sensor to be controlled
                        switch (mySwitch){
                            case 0:
                            break ;
                            case 1:
                            break ;
                            case 2:
                            break ;
                            case 3:
                            break ;
                            case 4:
                            break ;
                    break ;
        and in selector switch in Selector actions put this :
        http://192.168.2.110:8080/json.htm?type=command&param=switchlight&idx=971&switchcmd=Set Level&level=0
        so where write the ir codes ?
        thank you
        AWIA 1 Reply Last reply
        • R Reza
          @AWI
          i'am sorry .
          #include <IRLib.h>
          int RECV_PIN = 8;
          IRsend irsend;
          IRdecode decoder;
              irrecv.resume();
              decoder.decode();
              char buffer[10];
              int mySwitch =
              Serial.println(ID);
                          switch (mySwitch){
                              case 0:
                              break ;
                              case 1:
                              break ;
                              case 2:
                              break ;
                              case 3:
                              break ;
                              case 4:
                              break ;
                      break ;
          thank you
          AWIA
          AWIA
          AWI
          @Reza
          I'm not going to spell it out for you, there needs to be something to investigate yourself... the comments are rather self explaining. So put your actions between the curly brackets..
          case 0:
              break ;
          • AWIA AWI
            @Reza
            case 0:
                break ;
            R
            R
            Reza
            @AWI
            thank you , you are kind friend
            • stockenS
              stockenS
              stocken
              Greetings!
              So i have a ledstrip and i am using your sketch straight off.
              I do not have a physical button connected, but the code for the button is still there.
              I have setup a Selector Switch in domoticz like in your example, but i doesnt work with the values 2,3,4 etc. the patterns doesnt start.
              If i change it to http://192.168.1.30:8090/json.htm?type=command&param=switchlight&idx=157&switchcmd=Set Level&level=25 i get the alarm blinking red and white.
              what are the values for each pattern in your "moodlight" sketch?
              Or do i have to add something to the sketch for it to work?
              • P
                P
                pjr
                wrote on last edited by pjr
                I did the selector <> dimmer mapping in lua:
                -- Heat pump mode selector <> dimmer mapping with lua
                commandArray = {}
                selectorName = 'Pumppu_Mode'
                selectorId = '332' -- needed for UpdateDevice
                dimmerName = 'Pumppu_ModeSW2'
                -- selector -> dimmer
                if(devicechanged[selectorName]) then
                  iDimLevel = tonumber(otherdevices_svalues[selectorName])
                  if(iDimLevel < 60) then -- not needed anymore?
                    commandArray[dimmerName]='Set Level '..iDimLevel
                  end
                end
                -- dimmer-> selector. UpdateDevice is not triggering this script again
                if (devicechanged[dimmerName]) then
                  if (devicechanged[dimmerName] == 'Off') then
                    commandArray['UpdateDevice'] = selectorId..'|0|0'
                  else
                    iCurrentDimLevel = 0
                    if(otherdevices[dimmerName] == 'On') then -- can be "On" or something else
                      iCurrentDimLevel = tonumber(otherdevices_svalues[dimmerName])
                    else
                      iCurrentDimLevel = tonumber(string.match(otherdevices[dimmerName], "Set Level: (%d+) %%"))
                    end
                    commandArray['UpdateDevice'] = selectorId..'|'..iCurrentDimLevel..'|'..iCurrentDimLevel
                  end
                end
                return commandArray```
                • K
                  K
                  Knightan
                  Hello AWI , is it possible to post the hole example sketch ?
