  3. not going in the void receive() function
2 Posts 2 Posters 1.5k Views 2 Watching
  • npiotN
    npiotN
    npiot
    working on my sensors v2, IDE arduino 1.6.7
    The sketch is working OK, and connects to my jeedom controller no problem.
    I want to use the data received from node directly on my gateway to process it (jeedom is just here to record the data over time).
    on my serial gateway sketch, I added a void receive( const Mymessage &message) {} fonction, and it seems the sketch is never going there, even when messages are received, as I can see in my serial console.
    Any idea someone? Any help much appreciated.
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    #include <DHT.h>
    #define CHILD_ID_HUM 10
    #define CHILD_ID_TEMP 11
    #define HUMIDITY_SENSOR_DIGITAL_PIN 4  //data pin pour DHT
    #define BUREAU_NODE_ID 1
    #define GW_NODE_ID 0
    #define DS18B20 0
    #define THERM 17
    #define TEMP_DHT 11
    #define HRD_HT 10
    float bureauds = 0, bureautherm =0, tempdht = 0, hrdht =0;
    unsigned long SLEEP_TIME = 10000; // Sleep time between reads (in milliseconds)
    DHT dht;
    //float lastTemp;
    //float lastHum;
    boolean metric = true;
      Serial.begin(115200);
      Serial.println();
      Serial.println("Status\tHumidity (%)\tTemperature (C)\t(F)");
    void presentation() {
      sendSketchInfo("GW Humidity/Temp", "1.0");
      present(CHILD_ID_HUM, S_HUM);
      wait(dht.getMinimumSamplingPeriod());
      if (isnan(temperature)) {
      } else {
        Serial.print("T: ");
        Serial.println(temperature);
      if (isnan(humidity)) {
      } else {
          Serial.print("H: ");
          Serial.println(humidity);
     Serial.print("Dallas: ");
     Serial.println(bureauds);
     Serial.print("Therm: ");
     Serial.println(bureautherm);
     Serial.print("tempDHT: ");
     Serial.println(tempdht);
     Serial.print("HRDHT: ");
     Serial.println(hrdht);
      //sleep(SLEEP_TIME);
      wait(SLEEP_TIME);
      Serial.print("received something: ");
      Serial.println(message.sender, message.sensor);
      switch (message.sender) {
            case BUREAU_NODE_ID:
                 switch (message.sensor){
                       case DS18B20:
                             bureauds = message.getFloat();
                      break;
                      case THERM:
                             bureautherm = message.getFloat();
                      break;
              break;
         case GW_NODE_ID:
                      case TEMP_DHT:
                             tempdht = message.getFloat();
                      break;
                      case HRD_HT:
                             hrdht = message.getFloat();
                      break;
             break;
    abstract from serial output when a message is received from node 1, with sensors 0 and 17 :
    0;255;3;0;9;TSP:SANCHK:OK
    0;11;1;0;0;25.4
    T: 25.40
    0;10;1;0;1;50.3
    H: 50.30
    Dallas: 0.00
    Therm: 0.00
    tempDHT: 0.00
    HRDHT: 0.00
    0;255;3;0;9;TSP:MSG:READ 1-1-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.5
    1;0;1;0;0;24.5
    0;255;3;0;9;TSP:MSG:READ 1-1-0 s=17,c=1,t=0,pt=7,l=5,sg=0:24.6
    1;17;1;0;0;24.6
    0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=0,pt=1,l=1,sg=0:94
    1;255;3;0;0;94
    0;255;3;0;9;TSP:MSG:READ 1-1-0 s=20,c=1,t=38,pt=7,l=5,sg=0:3.8
    1;20;1;0;38;3.8
    0;11;1;0;0;25.3
    T: 25.30
    0;10;1;0;1;50.2
    H: 50.20
    Dallas: 0.00
    Therm: 0.00
    tempDHT: 0.00
    HRDHT: 0.00
    0;11;1;0;0;25.3
    T: 25.30
    0;10;1;0;1;50.2
    H: 50.20
    Dallas: 0.00
    Therm: 0.00
    tempDHT: 0.00
    HRDHT: 0.00
    Thanks, Nicolas
    • npiotN npiot
      #include <DHT.h>
      #define DS18B20 0
      #define THERM 17
      #define TEMP_DHT 11
      #define HRD_HT 10
      DHT dht;
      //float lastTemp;
      //float lastHum;
        Serial.println();
        } else {
        } else {
        wait(SLEEP_TIME);
                         case DS18B20:
                        break;
                        case THERM:
                        break;
                break;
           case GW_NODE_ID:
                        case TEMP_DHT:
                        break;
                        case HRD_HT:
                        break;
               break;
      0;11;1;0;0;25.4
      T: 25.40
      0;10;1;0;1;50.3
      H: 50.30
      Dallas: 0.00
      Therm: 0.00
      tempDHT: 0.00
      HRDHT: 0.00
      1;0;1;0;0;24.5
      1;17;1;0;0;24.6
      1;255;3;0;0;94
      1;20;1;0;38;3.8
      0;11;1;0;0;25.3
      T: 25.30
      0;10;1;0;1;50.2
      H: 50.20
      Dallas: 0.00
      Therm: 0.00
      tempDHT: 0.00
      HRDHT: 0.00
      0;11;1;0;0;25.3
      T: 25.30
      0;10;1;0;1;50.2
      H: 50.20
      Dallas: 0.00
      Therm: 0.00
      tempDHT: 0.00
      HRDHT: 0.00
      Thanks, Nicolas
      This post is deleted!
