  3. Servo-Motion Multisensor - Release 2.0
1 Posts 1 Posters 587 Views 2 Watching
  • manuM
    manuM
    manu
    Hello everybody,
    I try to bring a multi sensor with 2.0 release to run. Containing a servo and a motion sensor.
    The sketch is compiled without errors
    But unfortunately only the motion sensor works.
    The servo motor does not react. I have tried a lot but without success
    Could someone help me please?
    Many thanks for any help
    #include <Servo.h>
    #define SERVO_DIGITAL_OUT_PIN 3
    #define SERVO_MIN 0 // Fine tune your servos min. 0-180
    #define SERVO_MAX 180  // Fine tune your servos max. 0-180
    #define DETACH_DELAY 900 // Tune this to let your movement finish before detaching the servo
    #define CHILD_SERVO 1   // Id of the sensor child
    #define CHILD_MOTION 2
    #define DIGITAL_INPUT_SENSOR 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    MyMessage msgMOTION(CHILD_MOTION, V_TRIPPED);
    MyMessage msgSERVO(CHILD_SERVO, V_DIMMER);
    Servo myservo;  // create servo object to control a servo
                    // a maximum of eight servo objects can be created Sensor gw(9,10);
    unsigned long timeOfLastChange = 0;
    bool attachedServo = false;
      // Request last servo state at startup
      request(CHILD_SERVO, V_DIMMER);
      pinMode(DIGITAL_INPUT_SENSOR, INPUT);
    void presentation()  {
      sendSketchInfo("Servo_Motion", "1.0");
      present(CHILD_SERVO, S_COVER);
      present(CHILD_MOTION, S_MOTION);
        if (attachedServo && millis() - timeOfLastChange > DETACH_DELAY) {
         myservo.detach();
        // Read digital motion value
         bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
         Serial.println(tripped);
         send(msgMOTION.set(tripped?"1":"0"));  // Send tripped value to gw
         sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
      myservo.attach(SERVO_DIGITAL_OUT_PIN);
      attachedServo = true;
      if (message.type==V_DIMMER) { // This could be M_ACK_VARIABLE or M_SET_VARIABLE
         int val = message.getInt();
         myservo.write(SERVO_MAX + (SERVO_MIN-SERVO_MAX)/100 * val); // sets the servo position 0-180
         // Write some debug info
         Serial.print("Servo changed. new state: ");
         Serial.println(val);
       } else if (message.type==V_UP) {
         Serial.println("Servo UP command");
         myservo.write(SERVO_MIN);
         send(msgSERVO.set(100));
       } else if (message.type==V_DOWN) {
         Serial.println("Servo DOWN command");
         myservo.write(SERVO_MAX);
         send(msgSERVO.set(0));
       } else if (message.type==V_STOP) {
         Serial.println("Servo STOP command");
         myservo.detach();
       timeOfLastChange = millis();
