  3. OpenHAB
  4. MQTT Gateway
MQTT Gateway
2 Posts 1 Posters 2.3k Views 1 Watching
  • tianaT
    tianaT
    tiana
    wrote on last edited by tiana
    I try to make raspberry pi 3 to work like a mqtt gateway according to this tutorial, but something is wrong.
    https://www.mysensors.org/build/raspberry
    1.How to check condition on the gateway working,not working, what sending, what receiving?
    2.how to st my openhab to work with this gateway, i type this before "sudo make install"
    ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1
    and what port should set on my opehnab config?
    • tianaT
      tianaT
      tiana
      I successful tested my gateway, the gateway receives commands from nodes, but something missing the OpenHAB not receive commands from the gateway i install mosquitto but missing a lot of information:
      How to configure openhab to connect to the mosquitto ?
      in openhab.cfg i put this
      mqtt:mysensor.url=tcp://localhost:1883
      mqtt:mysensor.clientId=MyMQTT
      and other option is commented
      my binding is
      {mqtt="<[mysensor:MyMQTT/21/1/V_TEMP:state:default]"}
      What this "MyMQTT means is this related to some setting in mosquitto?
