  3. ago control
  4. agocontrol agomysensors: No protocol version found for...t
Scheduled Pinned Locked Moved ago control
2 Posts 1 Posters 3.4k Views 1 Watching
  • zeblongZ
    zeblongZ
    zeblong
    Hi all.
    I use Raspbian jessie and Mysensors v1.5.
    I can not connect mysensors sensor and Ago Control.
    Getaway and agomysensors.service receive packet from sensor but not undestand it.
    Please help me.
    pi@agocontrol:~ $ sudo systemctl start agomysensors.service
    pi@agocontrol:~ $ sudo systemctl status agomysensors.service
    ● agomysensors.service - ago control MySensors interface
    Loaded: loaded (/lib/systemd/system/agomysensors.service; enabled)
    Active: active (running) since Sun 2016-10-23 15:19:11 UTC; 5s ago
    Main PID: 1204 (agoMySensors)
    CGroup: /system.slice/agomysensors.service
    └─1204 /opt/agocontrol/bin/agoMySensors
    Oct 23 15:19:12 agocontrol agomysensors[1204]: DIGEST-MD5 make_client_response()
    Oct 23 15:19:12 agocontrol agomysensors[1204]: DIGEST-MD5 create_layer_keys()
    Oct 23 15:19:12 agocontrol agomysensors[1204]: DIGEST-MD5 client step 3
    Oct 23 15:19:12 agocontrol agomysensors[1204]: Waiting for the gateway starts...
    Oct 23 15:19:15 agocontrol agomysensors[1204]: Done.
    Oct 23 15:19:15 agocontrol agomysensors[1204]: Requesting gateway version...
    Oct 23 15:19:15 agocontrol agomysensors[1204]: found v1.5
    Oct 23 15:19:15 agocontrol agomysensors[1204]: Initializing MySensors controller
    Oct 23 15:19:15 agocontrol agomysensors[1204]: Register existing devices:
    Oct 23 15:19:15 agocontrol agomysensors[1204]: Running MySensors controller...
    Hint: Some lines were ellipsized, use -l to show in full.
    Active: active (running) since Sun 2016-10-23 15:19:11 UTC; 5min ago
    Oct 23 15:23:35 agocontrol agomysensors[1204]: No protocol version found for...t
    Oct 23 15:23:40 agocontrol agomysensors[1204]: No protocol version found for...t
    Oct 23 15:23:45 agocontrol agomysensors[1204]: No protocol version found for...t
    Oct 23 15:23:50 agocontrol agomysensors[1204]: No protocol version found for...t
    Oct 23 15:23:55 agocontrol agomysensors[1204]: No protocol version found for...t
    Oct 23 15:24:00 agocontrol agomysensors[1204]: No protocol version found for...t
    Oct 23 15:24:05 agocontrol agomysensors[1204]: No protocol version found for...t
    Oct 23 15:24:10 agocontrol agomysensors[1204]: No protocol version found for...t
    Oct 23 15:24:15 agocontrol agomysensors[1204]: No protocol version found for...t
    Oct 23 15:24:20 agocontrol agomysensors[1204]: No protocol version found for...t
    pi@agocontrol:~ $ /opt/agocontrol/bin/agoMySensors -d
    2016-Oct-23 15:19:47.862621 [DEBUG] Using console log, level DEBUG
    2016-Oct-23 15:19:48.141411 [DEBUG] Using uuidMapFile "/etc/opt/agocontrol/uuidmap/mysensors.json"
    2016-Oct-23 15:19:48.155417 [DEBUG] Opening broker connection: localhost
    2016-Oct-23 15:19:48.406645 [INFO] Waiting for the gateway starts...
    2016-Oct-23 15:19:48.409229 [DEBUG] Opening serial port '/dev/ttyUSB0'...
    2016-Oct-23 15:19:50.986593 [DEBUG] Read: parent=0, distance=0
    2016-Oct-23 15:19:50.989693 [DEBUG] Read: ;Gateway startup complete.
    2016-Oct-23 15:19:50.992372 [DEBUG] Startup string found, continue
    2016-Oct-23 15:19:50.994967 [INFO] Done.
    2016-Oct-23 15:19:50.997982 [INFO] Requesting gateway version...
    2016-Oct-23 15:19:51.006023 [DEBUG] Read: 0;0;3;0;2;1.5
    2016-Oct-23 15:19:51.009352 [INFO] found v1.5
    2016-Oct-23 15:19:51.012073 [INFO] Initializing MySensors controller
    2016-Oct-23 15:19:51.029061 [INFO] Register existing devices:
    2016-Oct-23 15:19:51.032001 [INFO] Running MySensors controller...
    2016-Oct-23 15:19:53.684006 [DEBUG] => RECEIVING: 101/2;SET;0;V_STATUS;0
    2016-Oct-23 15:19:53.687611 [WARNING] No protocol version found for this message, drop it
    2016-Oct-23 15:19:55.939434 [DEBUG] I_LOG_MESSAGE send payload: infos string is not valid [30.0]
    2016-Oct-23 15:20:14.464399 [DEBUG] I_LOG_MESSAGE send payload: infos string is not valid [1]
    2016-Oct-23 15:20:14.470550 [DEBUG] => RECEIVING: 101/3;SET;0;V_STATUS;0
    2016-Oct-23 15:20:14.474548 [WARNING] No protocol version found for this message, drop it
    • zeblongZ
      zeblongZ
      zeblong
      Worked. Reboot mysensors device and agocontrol had seen them. But only switch without sensors.
