  3. Temperature sensor WITH battery monitor
10 Posts 4 Posters 5.8k Views 3 Watching
  • H Offline
    H Offline
    Hausner
    I'm new to all of this arduino stuff, but I've managed to get a Serial GW and 2 tempsensors going.
    Now I would like to add the battery monitor to the temp sensor sketch, to monitor the 3,7V LiPo batteries.
    What I've done is, merged the battery sketch setup with the temp sketch setup, and also done the same with the Void sections.
    No errors on upload - weee!
    Problem is now, that I only get the Volt reading from the Node and no temperature reading anymore. :(
    So where did I go wrong?
    • H Offline
      H Offline
      Hausner
      Here's my sketch for the tempnode:
      // Example sketch showing how to send in OneWire temperature readings
      #include <OneWire.h>
      unsigned long SLEEP_TIME = 120000; // Sleep time between reads (in milliseconds)
      OneWire oneWire(ONE_WIRE_BUS);
      int numSensors=0;
      boolean metric = true;
      MyMessage msg(0,V_TEMP);
      int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point
      int oldBatteryPcnt = 0;
      // Startup OneWire
      sensors.begin();
      gw.begin();
      gw.sendSketchInfo("Temperature Sensor", "1.0");
      gw.present(i, S_TEMP);
      analogReference(INTERNAL);
      gw.process();
      if (lastTemperature[i] != temperature && temperature != -127.00) {
      // get the battery Voltage
      Serial.println(sensorValue);
      float batteryV = sensorValue * 0.004106;
      Serial.print(batteryV);
      Serial.println(" V");
      Serial.print(batteryPcnt);
      Serial.println(" %");
      // Power up radio after sleep
      oldBatteryPcnt = batteryPcnt;
      gw.sleep(SLEEP_TIME);
      • H Offline
        H Offline
        Hausner
        DOH!!! Stupid me!
        Forgot the temp only transmits on temp change...
        it's working now :)
        • A Offline
          A Offline
          abalazs
          Perhaps related to the topic. This program was used for monitoring battery level, but can not read the battery level. :(
          mqtt="<[mysensor:MyMQTT/21/255/V_BATTERY_LEVEL:state:default]"
          So I tried to read, the program opanhab, but not getting value. Any ideas what went wrong.
          • M Offline
            M Offline
            Markus.
            Hi
            I know this is an old post but I try to convert this Sketch to use it with Version 2.1.and I am not sure If this can be work because I am tottaly new in Arduino and Mysenseors
            //#define MY_DEBUG
             #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
             unsigned long SLEEP_TIME = 300000; // Sleep time between reads (in milliseconds)
             //MySensors gw;
             int numSensors=0;
             // Startup OneWire
             sensors.begin();
             present(i, S_TEMP);
            float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
            sleep(SLEEP_TIME);
            Would be great If someone confirm Ifthis is correct so far...
            Many thanks
            Markus
            A 1 Reply Last reply
            • M Markus.
              Hi
              //#define MY_DEBUG
               //MySensors gw;
               int numSensors=0;
               // Startup OneWire
               sensors.begin();
               present(i, S_TEMP);
              sleep(SLEEP_TIME);
              Many thanks
              Markus
              A Offline
              A Offline
              AWI
              @Markus. I would say: give it a go. It looks fine at first instance. It's rather hard to say it's correct without running it through a compiler. For readability's sake I would advice you to look at the coding guidelines for reference.
              • M Offline
                M Offline
                Markus.
                Its working so far.:-) But the battery voltage is only available as serial print. How must i change the file to get also the voltage send to the gateway? Simply by adding the send command before the sleep?
                Thx
                M.
                • M Markus.
                  Thx
                  M.
                  A Offline
                  A Offline
                  AWI
                  @Markus. You need to send the voltage explicit with a V_VOLTAGE (S_MULTIMETER) message.
                  M 1 Reply Last reply
                  • A AWI
                    M Offline
                    M Offline
                    Markus.
                    @AWI Hope you can give me an example because it seems that the requiered programming Level currently are over my Knowledge ;-)
                    THX
                    Markus
                    • M Offline
                      M Offline
                      Markus.
                      Anyone here an idea how i can get the voltage send tomthe gateway? Works great so far except the send of the voltage ....:-(
