  3. Problems with Node sensor
6 Posts 4 Posters 2.7k Views 4 Watching
  • tandobkhcmT Offline
    tandobkhcmT Offline
    tandobkhcm
    wrote on last edited by tandobkhcm
    Hello guys!. I got tutorial "http://www.makeuseof.com/tag/diy-smart-home-sensors-arduino-mysensors-openhab/". But i didn't see humiditysensor in library. Then, i got code from https://www.mysensors.org/build/humidity and uploaded sketch on my sensors node and serial monitor look like this alt text
    and
    it's different to what i see in tutorial alt text
    what is "st=bc"?
    Thank you for taking the time to help and sorry because my English is not good.
    • mhkoM Offline
      mhkoM Offline
      mhko
      I have the same problem with different nodes. Yesterday only one node hade this problem today i have 2 nodes.
      any commens on this topic?
      i have a ethernet gateway.
      Tms:fpar:fail
      • mfalkviddM Offline
        Welcome to the MySensors community @tandobkhcm and @mhko ! I'll handle tandobkhcm's problem first since that's the problem where I have some information.
        https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help has information on how to read the debug output. bc means broadcast.
        find parent (fpar) means the node is searching for a way to reach a parent (usually the gateway but can be a repeater node in a more advanced setup, read https://www.mysensors.org/about/network for more details).
        fpar fail means that the node was unable to find a way to reach a parent.
        Please share information on gateway setup, which radio you are using and share the sketch for the gateway.
        radio fail means that the node is unable to initialize the radio. This is usually due to incorrect wiring.
        tandobkhcmT 1 Reply Last reply
          tandobkhcmT Offline
          tandobkhcmT Offline
          tandobkhcm
          Hi @mfalkvidd !. Thank you for that infomations. I'll read https://ci.mysensors.org/job/Verifiers/job/MySensorsArduino/branch/development/Doxygen_HTML/group__MyTransportgrp.html#details.
          After I convert Mysensors 1.5.x -> 2.0 it's probably working. But i don't see temperature and humidity to display serial monitor
          My code for Humiditysensor :
          #define MY_NODE_ID 1 // Sets a static id for a node
          #define MY_DEBUG    // Enables debug messages in the serial log
          #define MY_RF24_CE_PIN 9    // Radio specific settings for RF24
          #define MY_RF24_CS_PIN 10 // Radio specific settings for RF24 (you'll find similar config for RFM69)
           //Enabdle if use NRF24
           //Enable if use RFM69
           //Enable iff use RS485
           //#define MY_RS485
          #include <DHT.h>
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 1
          #define HUMIDITY_SENSOR_DIGITAL_PIN 2
          DHT dht;
          float lastTemp;
          float lastHum;
          boolean metric = true;
            sendSketchInfo("Humidity", "1.0");
            // Register all sensors (they will be created as child devices)
            present(CHILD_ID_HUM, S_HUM);
            metric = getConfig().isMetric;
            if (isnan(temperature)) {
              lastTemp = temperature;
              if (!metric) {
              Serial.print("T: ");
              Serial.println(temperature);
            if (isnan(humidity)) {
                lastHum = humidity;
                Serial.print("H: ");
                Serial.println(humidity);
            sleep(SLEEP_TIME); //sleep a bit
          For gateway
          // Set MQTT client id
          //#define MY_W5100_SPI_EN 4
          // radio on the same spi bus.
            #define MY_SOFTSPI
          #ifndef MY_RF24_CE_PIN
            #define MY_RF24_CE_PIN 5
          #ifndef MY_RF24_CS_PIN
            #define MY_RF24_CS_PIN 6
          #define MY_IP_ADDRESS 192,168,10,103
          #define MY_IP_GATEWAY_ADDRESS 192,168,10,1
          #define MY_CONTROLLER_IP_ADDRESS 192, 168, 10, 102
          #define MY_PORT 1883
          // Enable inclusion mode
          // Set blinking period
          // Flash leds on rx/tx/err
          #include <Ethernet.h>
          void presentation() {
          My router
          • mhkoM Offline
            mhkoM Offline
            mhko
            Thanks for the time and effort.
            The links did help me, sometime it can be very difficult to find the relevant information for problem solving, so the help i much appreciated.
            it all turn out to be a dodig antenna connector on me GW radio. I am using the nRF24L01+PA+LNA.
            • Nathan MatosN Offline
              Nathan Matos
              Guys, i'm having the same problem but with a serial GW..
              Any ideas?
