  3. WDT doesn't work well
5 Posts 2 Posters 1.9k Views 2 Watching
  • logger02L Offline
    logger02L Offline
    logger02
    I'm testing the library 2.0 with WDT enabled.
    In before() I add "wdt_enable(wdto_8seg)" and I comment from the _proces() the line "hwWatchdogReset();" to force the wdt reset after 8seg
    After wdt reset, the system crash and it is not restore. If I do a manual reset, neither it is restore. I need to remove the power supply to restore the system.
    Need I use a especial bootloader to use wdt with mysensor? I'm using the default bootloader flashed in the arduino pro mini v3
    • logger02L Offline
      logger02L Offline
      logger02
      I'm going to answer me.
      The problem was the bootloader, I have flashed the MYSbootloader and the WDT is working well.
      Anybody know a bootloader compatible with MYS but it run quickly? because MYSbootloader spends 10seconds to start
      • logger02L Offline
        logger02L Offline
        logger02
        I answer me again, I try the optiboot bootloader and it work well with mysensor library and WDT enable.
        I hope that the solution is useful for more people
        PD: The optiboot bootloader can be downloaded from here: https://github.com/Optiboot/optiboot/tree/master/optiboot
        T 1 Reply Last reply
        • logger02L logger02
          T Offline
          T Offline
          tekka
          @logger02 Indeed, this is a known issue with the stock AVR bootloader - Optiboot or MYSBootlader (depending on the use case) is suggested.
          • logger02L Offline
            logger02L Offline
            logger02
            Thank you to confirm it
