  3. [Solved] NRF24L01+ Serial Gateway not starting ( Sanity check failed )
radio failnrf24l01+serial gateway
3 Posts 2 Posters 3.6k Views 1 Watching
  • 19Dani921
    19Dani921
    19Dani92
    wrote on last edited by tekka
    Hello Guys,
    i tried to build my first mySensors - Serial Gateway.
    It does not seem to work, since the serial monitor gives the following output messages:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;RF24:write register, reg=0, value=14
    0;255;3;0;9;RF24:write register, reg=3, value=3
    0;255;3;0;9;RF24:write register, reg=4, value=95
    0;255;3;0;9;RF24:write register, reg=5, value=76
    0;255;3;0;9;RF24:write register, reg=6, value=35
    0;255;3;0;9;RF24:read register, reg=6, value=255
    0;255;3;0;9;RF24:read register, reg=5, value=255
    0;255;3;0;9;RF24:Sanity check failed: configuration mismatch! Check wiring, replace module or non-P version
    0;255;3;0;9;!TSM:RADIO:FAIL
    0;255;3;0;9;!TSM:FAILURE
    0;255;3;0;9;TSM:PDT
    0;255;3;0;9;RF24:write register, reg=0, value=12
    0;255;3;0;9;RF24:power down
    I setup my software like this:
    1. Download and install Arduino IDE.
    2. In Arduino IDE, downloaded the MySensors library
    3. I took the sketch from the example GatewaySerial ( File/Examples/MySensors/GatewaySerial )
    4. Uploaded the sketch with these 2 additional Defines:
    #define MY_NODE_ID 124
    #define MY_DEBUG_VERBOSE_RF24
    Since i thought the problem could be, that i need a controller to get rid of those error messages, i put the my_node_id to a random value, and to get some more error details i put the verbose_rf24 in the defines.
    So the final sketch, that i'm uploading is:
     * The ArduinoGateway prints data received from sensors on the serial link.
     * The gateway accepts input on seral which will be sent out on radio network.
     * The GW code is designed for Arduino Nano 328p / 16MHz
     * Wire connections (OPTIONAL):
     * - Inclusion button should be connected between digital pin 3 and GND
     * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
     * LEDs (OPTIONAL):
     * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    void presentation() {
    The OS I'm using running arduino IDE:
    Windows 10 ( I also tried it with my macbook pro MacOs X, same result. )
    The Hardware, that I'm using:
    1. Arduino Nano with CH340g Chip ( Working without manually installing driver on win10 )
    2. NRF24L01+, The text on the chip is:
      NRF M
      24L01+
      1452AB
    3. Capacitor 4.7uF
    4. Jumper Cables
    5. Usb - to MicroUsb Cable
    6. Board
    What i tried so far:
    1. Replacing the NRF24L01+ with ones from a different manufacturer.
    2. Downloading MySensors API manually from Homepage and copy paste the sample from the MySensors Site.
    3. Re-wiring all the components.
    4. Searching forum and google for similar problems.
    Sadly, nothing of this helped me so far.
    Here's how i wired things up:
    Note: For simplicity i used the same colors for my cables as the ones in the example
    Arduino:
    NRF24L01+:
    If you have any ideas what i could have missed, or what i could try to get it working, please let me know.
    Thank you in advance.
    • scalzS
      scalzS
      wrote on last edited by scalz
      Hello.
      have you missed to solder pinheaders to your arduino nano ? on the pics it looks like..
      That would explain your miswiring error in log.
      I hope this helps.
      • 19Dani921
        19Dani921
        19Dani92
        Thank you so much, scalz.
        That solved my problem.
        Just soldered them and now it works.
        It really seems the arduino needs a good wired connection in order to work.
