  3. Domoticz
  4. Controller can not connect to Ethernet GW
3 Posts 2 Posters 2.5k Views 2 Watching
  • XortozX Offline
    XortozX Offline
    Xortoz
    I have a problem with my controller not being able to connect to my Ethernet gateway (Arduino Uno/W5100/NRF24)
    The gateway seems to start up ok.
    Serial monitor log:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.1.98
    0;255;3;0;9;TSP:SANCHK:OK
    Domoticz log:
     2016-12-03 16:52:29.271 Error: MySensors: Can not connect to: 192.168.1.98:5003
    2016-12-03 16:52:29.271 TCP: Connection problem (Unable to connect to specified IP/Port)
    2016-12-03 16:52:29.272 TCP: Reconnecting in 30 seconds...
    2016-12-03 16:52:59.278 TCP: Reconnecting...
    2016-12-03 16:53:02.279 Error: MySensors: Can not connect to: 192.168.1.98:5003
    2016-12-03 16:53:02.279 TCP: Connection problem (Unable to connect to specified IP/Port)
    2016-12-03 16:53:02.279 TCP: Reconnecting in 30 seconds...
    2016-12-03 16:53:32.284 TCP: Reconnecting...
    2016-12-03 16:53:35.286 Error: MySensors: Can not connect to: 192.168.1.98:5003
    2016-12-03 16:53:35.286 TCP: Connection problem (Unable to connect to specified IP/Port)
    2016-12-03 16:53:35.286 TCP: Reconnecting in 30 seconds...
    2016-12-03 16:54:05.291 TCP: Reconnecting...
    2016-12-03 16:54:08.293 Error: MySensors: Can not connect to: 192.168.1.98:5003
    2016-12-03 16:54:08.293 TCP: Connection problem (Unable to connect to specified IP/Port)
    2016-12-03 16:54:08.293 TCP: Reconnecting in 30 seconds...
    2016-12-03 16:54:38.298 TCP: Reconnecting...
    2016-12-03 16:54:41.300 Error: MySensors: Can not connect to: 192.168.1.98:5003
    2016-12-03 16:54:41.300 TCP: Connection problem (Unable to connect to specified IP/Port)
    2016-12-03 16:54:41.300 TCP: Reconnecting in 30 seconds...
    Code:
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
      #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
      #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
      #define MY_RF24_CS_PIN 6
    // Enable to UDP
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,1,98   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 97
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
    #if defined(MY_USE_UDP)
      #include <EthernetUdp.h>
    #include <Ethernet.h>
    Does anyone here have a clue of what the problem could be?
    Thanks!
    • XortozX Xortoz
      Serial monitor log:
      IP: 192.168.1.98
      Domoticz log:
      Code:
        #define MY_SOFTSPI
      // Enable to UDP
      Thanks!
      @Xortoz I am not sure, but I think
      turns off server mode. See if commenting this line helps.
      XortozX 1 Reply Last reply
        XortozX Offline
        XortozX Offline
        Xortoz
        @mfalkvidd i've tried to comment that, when i compile it with AVR boards v 1.6.15 it just restarts all the time. Tried with v1.6.8 and then it stopped restarting. However, i still can't ping my gateway.
        I've seen that other people get a message that the gateway has started, but i don't get that.
