  3. How to access Uservariables (Domoticz)
6 Posts 3 Posters 3.0k Views 1 Watching
  • P
    P
    Petervdam
    Hi there,
    I'm using Mysensors 2.0 and the latest version of Domoticz.
    I am looking for a way to access the uservariable in Domoticz, looked everyware but could not find it. Sure you can access VAR's beloning to the sensors but thats not what i want.
    Anyone solved this "problem" ?
    thanks, help would be appreciated,
    Peter
    • P Petervdam
      Hi there,
      Peter
      @Petervdam -. Do you mean the raw data?
      Its inside the db file. Use some sort of SQL program to see them.
      Howto (Linux) http://domoticz.com/forum/viewtopic.php?t=11930
      Search "domoticz database sql" for more info
      (If you mean userdefined variables its found Setup -> More options -> User variables)
      • P
        P
        Petervdam
        Sorry, i should be more clear, i want to access the userdefined (uservariables), from within the arduino code. I know you can use json call's , but thats not what i am looking for. I wanty to know if it's posible to access then directly from within a code (arduino).
        • tbowmoT
          tbowmoT
          tbowmo
          It is not something that works out of the box, so you have to make a script of some kind, that picks up the user variable, and pushes it to a node, using whatever type you want to use with it.
          • P Petervdam
            @Petervdam - you need to use the request() function and fetch a variable from your controller.
            Inside the controller you need to make a script that updates the variable with the info you want.
            I use request in my rain-sensor: https://forum.mysensors.org/topic/1950/domotiocz-rain-gauge/2
            • P
              P
              Petervdam
              Ok, Thanks Guy's thats what i needed!
              I'll create a dummy sensor and use that for I/O.
