  3. [SOLVED] Problems with Ethernet Gateway (Arduino Ethernet Shield)
67 Posts 12 Posters 42.7k Views 3 Watching
    Ahh.. then we should be fine with the defaults. @Anticimex did his own modification in config to fit his gateway.
    AnticimexA
    AnticimexA
    Anticimex
    @hek Yes, basically, when using SOFT_SPI, you need to decide what pins to use and set the config accordingly. I believe things has been standardized a bit since I meddled with that, because I abandoned the SOFT_SPI approach as soon as I managed to manipulate SPI_EN. Saves me both wires, program space and energy :)
    • JTBJ
      JTBJ
      JTB
      I have problems with this setup. No matter what I try i get this printout from the Humidity sensor node:
      req node id
      send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
      sensor started, id 255
      req node id
      T: 20.70
      req node id
      H: 31.70
      Appreciate any tips and help!
      • bjornhallbergB
        bjornhallbergB
        bjornhallberg
        I just switched to the ethernet gateway to try out native Domoticz support and quickly experienced the SPI issue that everyone has been talking about. Can someone explain how the MQTT gateway was able to run for several months with no issues, but the moment I flash the ETHERNET gateway on the same hardware everything goes belly up after a few hours?
        • korttomaK korttoma
          @hek said:
          I have now updated the ethernet sketch and instructions on www.mysensors.org to give a bit clearer instructions on how to use W5100 module and SoftSPI.
          greate! But you forgot one thing ;)
          RF24_config.h
          const uint8_t SOFT_SPI_MISO_PIN = 15;
          const uint8_t SOFT_SPI_MOSI_PIN = 14;
          const uint8_t SOFT_SPI_SCK_PIN = 16;
          mainali
          @korttoma Can you post the link to the updated code and the instruction of using NRF with ethernet module.
          korttomaK 3 Replies Last reply
          • M mainali
            korttomaK
            korttomaK
            korttoma
            I think everything you need to know is described here -> http://www.mysensors.org/build/ethernet_gateway
            • M mainali
              korttomaK
              korttomaK
              korttoma
              This post is deleted!
              • M mainali
                korttomaK
                korttomaK
                korttoma
