  3. Home Assistant
  4. Correct presentation of Sensebender temperature and humidity?
7 Posts 3 Posters 3.6k Views 3 Watching
  • MadhiasM
    MadhiasM
    Madhias
    wrote on last edited by Madhias
    I am starting slowly to get into MySensors, and currently my setup is sporting one Sensebender connected to a Raspberry serial gateway and Home Assistant on this Raspberry. This setup works, and the controller gets temperature and humidity from the sensor.
    I have some questions regarding the presentation in the loop function: the current temperature must be presented? Humidity also? To get the current temperature I have to add in the loop function everything needed to get a temperature value - since the values of the loop function are seen in Home Assistant? So looking at the sketch the temperature and humidity is sent twice to the gateway - once in loop, once in sendTempHumidityMeasurements? Should I get rid of one measurement sent to the gateway?
    Sorry for my basic questions... I am really happy to be so far though :)
    Here are those parts of the sketch:
    void presentation()  {
      sendSketchInfo("Sensebender Micro", RELEASE);
      present(CHILD_ID_TEMP,S_TEMP);
      present(CHILD_ID_HUM,S_HUM);
    #ifdef BATT_SENSOR
      present(BATT_SENSOR, S_POWER);
      if (!initialValueSent) {
        si7021_env data = humiditySensor.getHumidityAndTemperature();
        float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
        int humidity = data.humidityPercent;
        send(msgTemp.set(temperature,1));
        send(msgHum.set(humidity));
        wait(2000, C_SET, V_STATUS);
    void sendTempHumidityMeasurements(bool force)
      bool tx = force;
      raHum.addValue(data.humidityPercent);
      float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0);
      float diffHum = abs(lastHumidity - raHum.getAverage());
      Serial.print(F("TempDiff :"));Serial.println(diffTemp);
      Serial.print(F("HumDiff  :"));Serial.println(diffHum);
      if (isnan(diffHum)) tx = true;
      if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
      if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
      if (tx) {
        measureCount = 0;
        Serial.print("T: ");Serial.println(temperature);
        Serial.print("H: ");Serial.println(humidity);
        lastTemperature = temperature;
        lastHumidity = humidity;
        transmission_occured = true;
        if (sendBattery > 60) {
         sendBattLevel(true); // Not needed to send battery info that often
         sendBattery = 0;
    • MadhiasM Madhias
      #ifdef BATT_SENSOR
        bool tx = force;
        if (tx) {
          measureCount = 0;
           sendBattery = 0;
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @Madhias
      Just call sendTempHumidityMeasurements, with force argument set to true, from inside the if block in the loop. Then you don't need to duplicate code so much.
      You also need to change the last argument in the call to wait inside the if block in the loop. V_STATUS is not the correct type for temperature and humidity that you are waiting for. I think you can leave the last argument out in the call to wait. Let me double check that.
      Edit:
      No, you either have to call wait with all three arguments or only call it with one argument for time to wait. I guess you can put either V_HUM or V_TEMP as the last argument and just make sure you request that value last. BTW, you're missing a call to request as well. Put it after you send in the values ie after the call to sendTempHumidityMeasurements.
      • MadhiasM
        MadhiasM
        Madhias
        I have called the measurement function now inside the loop function (that is way better of course), and changed the third wait argument to V_TEMP. That works.
        I had a request in the code, but commented it out, it was like: request(CHILD_ID_TEMP, V_TEMP); because I was not sure if it is needed.
        Thanks for your help!
        • Mark69M
          Mark69M
          Mark69
          wrote on last edited by Mark69
          Hi Madhias, would you mind sharing your final sketch ?
          I am trying to get the very same thing working right now and am very new to programming for arduino's.
          Thanks in advance :)
          MadhiasM 1 Reply Last reply
          • Mark69M Mark69
            MadhiasM
            MadhiasM
            Madhias
            I thought I have a correct sketch now, but as I loaded the sketch to another sensor, something must be wrong, since I always get this error in the Home Assistant log:
            WARNING:mysensors.mysensors:Node 2 is unknown
            INFO:mysensors.mysensors:Requesting new presentation for node 2
            INFO:homeassistant.components.mysensors:No sketch_name: node 2
            WARNING:mysensors.mysensors:child_id 1 already exists in children of node 2, cannot add child
            WARNING:mysensors.mysensors:child_id 2 already exists in children of node 2, cannot add child
            The json file looks like it got some values (I just changed the format for better reading here):
                "2": {
                    "sketch_version": "1.4",
                    "children": {
                        "1": {
                            "type": 6,
                            "id": 1,
                            "description": "",
                            "values": {
                                "0": "25.6"
                        "2": {
                            "type": 7,
                            "id": 2,
                            "description": "",
                            "values": {
                                "1": "65"
                    "sensor_id": 2,
                    "type": 17,
                    "protocol_version": "2.1.1",
                    "sketch_name": null,
                    "battery_level": 104
            This is the sketch:
            // Define a static node address, remove if you want auto address assignment
            #define MY_NODE_ID 2
            // Enable to support OTA for this node (needs DualOptiBoot boot-loader to fully work)
            #define MY_OTA_FIRMWARE_FEATURE
            #include <Wire.h>
            #include <SI7021.h>
            #ifndef MY_OTA_FIRMWARE_FEATURE
            #include "drivers/SPIFlash/SPIFlash.cpp"
            #include <EEPROM.h>
            #include <sha204_lib_return_codes.h>
            #include <sha204_library.h>
            #include <RunningAverage.h>
            //#include <avr/power.h>
            // Uncomment the line below, to transmit battery voltage as a normal sensor value
            //#define BATT_SENSOR    199
            #define RELEASE "1.4"
            #define AVERAGES 2
            // Child sensor ID's
            #define CHILD_ID_TEMP  1
            #define CHILD_ID_HUM   2
            // How many milli seconds between each measurement
            #define MEASURE_INTERVAL 60000
            // How many milli seconds should we wait for OTA?
            #define OTA_WAIT_PERIOD 300
            // FORCE_TRANSMIT_INTERVAL, this number of times of wakeup, the sensor is forced to report all values to the controller
            #define FORCE_TRANSMIT_INTERVAL 30
            // When MEASURE_INTERVAL is 60000 and FORCE_TRANSMIT_INTERVAL is 30, we force a transmission every 30 minutes.
            // Between the forced transmissions a tranmission will only occur if the measured value differs from the previous measurement
            // HUMI_TRANSMIT_THRESHOLD tells how much the humidity should have changed since last time it was transmitted. Likewise with
            // TEMP_TRANSMIT_THRESHOLD for temperature threshold.
            #define HUMI_TRANSMIT_THRESHOLD 0.5
            #define TEMP_TRANSMIT_THRESHOLD 0.5
            // Pin definitions
            #define TEST_PIN       A0
            #define LED_PIN        A2
            #define ATSHA204_PIN   17 // A3
            const int sha204Pin = ATSHA204_PIN;
            atsha204Class sha204(sha204Pin);
            SI7021 humiditySensor;
            SPIFlash flash(8, 0x1F65);
            // Sensor messages
            #ifdef BATT_SENSOR
            MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
            // Global settings
            int measureCount = 0;
            int sendBattery = 0;
            boolean isMetric = true;
            boolean highfreq = true;
            boolean transmission_occured = false;
            bool state = false;
            bool initialValueSent = false;
            // Storage of old measurements
            float lastTemperature = -100;
            int lastHumidity = -100;
            long lastBattery = -100;
            RunningAverage raHum(AVERAGES);
             * Setup code
              pinMode(LED_PIN, OUTPUT);
              digitalWrite(LED_PIN, LOW);
              Serial.begin(115200);
              Serial.print(F("Sensebender Micro FW "));
              Serial.print(RELEASE);
              Serial.flush();
              // First check if we should boot into test mode
              pinMode(TEST_PIN,INPUT);
              digitalWrite(TEST_PIN, HIGH); // Enable pullup
              if (!digitalRead(TEST_PIN)) testMode();
              // Make sure that ATSHA204 is not floating
              pinMode(ATSHA204_PIN, INPUT);
              digitalWrite(ATSHA204_PIN, HIGH);
              digitalWrite(TEST_PIN,LOW);
              digitalWrite(LED_PIN, HIGH);
              humiditySensor.begin();
              Serial.flush();
              Serial.println(F(" - Online!"));
              isMetric = getControllerConfig().isMetric;
              Serial.print(F("isMetric: ")); Serial.println(isMetric);
              raHum.clear();
              sendTempHumidityMeasurements(false);
              sendBattLevel(false);
            #ifdef MY_OTA_FIRMWARE_FEATURE
              Serial.println("OTA FW update enabled");
              present(CHILD_ID_HUM, S_HUM);
            #ifdef BATT_SENSOR
             *  Main loop function
                bool forceMeasure = true;
                sendTempHumidityMeasurements(forceMeasure);
                Serial.println("Requesting initial value from controller");
                request(CHILD_ID_HUM, V_HUM);
                wait(2000, C_SET, V_TEMP);
              measureCount ++;
              sendBattery ++;
              bool forceTransmit = false;
              if ((measureCount == 5) && highfreq)
                clock_prescale_set(clock_div_8); // Switch to 1Mhz for the reminder of the sketch, save power.
                highfreq = false;
              if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
                forceTransmit = true;
                measureCount = 0;
            /*  if (sendBattery > 60)
                 sendBattLevel(forceTransmit); // Not needed to send battery info that often
                 sendBattery = 0;
              if (transmission_occured) {
                  wait(OTA_WAIT_PERIOD);
              sleep(MEASURE_INTERVAL);
             * Sends temperature and humidity from Si7021 sensor
             * Parameters
             * - force : Forces transmission of a value (even if it's the same as previous measurement)
              bool tx = force;
              if (tx) {
                measureCount = 0;
                 sendBattery = 0;
             * Sends battery information (battery percentage)
             * Parameters
            void sendBattLevel(bool force)
              if (force) lastBattery = -1;
              long vcc = readVcc();
              if (vcc != lastBattery) {
                lastBattery = vcc;
            #ifdef BATT_SENSOR
                float send_voltage = float(vcc)/1000.0f;
                send(msgBatt.set(send_voltage,3));
                // Calculate percentage
                vcc = vcc - 1900; // subtract 1.9V from vcc, as this is the lowest voltage we will operate at
                long percent = vcc / 14.0;
                sendBatteryLevel(percent);
             * Internal battery ADC measuring
            long readVcc() {
              #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
                ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
              #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
                ADMUX = _BV(MUX5) | _BV(MUX0);
              #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
                ADcdMUX = _BV(MUX3) | _BV(MUX2);
              #else
              long result = (high<<8) | low;
             * Verify all peripherals, and signal via the LED if any problems.
            void testMode()
              uint8_t rx_buffer[SHA204_RSP_SIZE_MAX];
              uint8_t ret_code;
              byte tests = 0;
              digitalWrite(LED_PIN, HIGH); // Turn on LED.
              Serial.println(F(" - TestMode"));
              Serial.println(F("Testing peripherals!"));
              Serial.flush();
              Serial.print(F("-> SI7021 : "));
              Serial.flush();
              if (humiditySensor.begin())
                Serial.println(F("ok!"));
                tests ++;
              else
                Serial.println(F("failed!"));
              Serial.flush();
              Serial.print(F("-> Flash : "));
              Serial.flush();
              if (flash.initialize())
                tests ++;
              else
              Serial.flush();
              Serial.print(F("-> SHA204 : "));
              ret_code = sha204.sha204c_wakeup(rx_buffer);
              Serial.flush();
              if (ret_code != SHA204_SUCCESS)
                Serial.print(F("Failed to wake device. Response: ")); Serial.println(ret_code, HEX);
              Serial.flush();
              if (ret_code == SHA204_SUCCESS)
                ret_code = sha204.getSerialNumber(rx_buffer);
                  Serial.print(F("Failed to obtain device serial number. Response: ")); Serial.println(ret_code, HEX);
                else
                  Serial.print(F("Ok (serial : "));
                  for (int i=0; i<9; i++)
                    if (rx_buffer[i] < 0x10)
                      Serial.print('0'); // Because Serial.print does not 0-pad HEX
                    Serial.print(rx_buffer[i], HEX);
                  Serial.println(")");
                  tests ++;
              Serial.flush();
              Serial.println(F("Test finished"));
              if (tests == 3)
                Serial.println(F("Selftest ok!"));
                while (1) // Blink OK pattern!
                  delay(200);
                  delay(200);
              else
                Serial.println(F("----> Selftest failed!"));
                while (1) // Blink FAILED pattern! Rappidly blinking..
            @Mark69 Can't post a helpful sketch so far. Sorry!
            • MadhiasM Madhias
                  "2": {
                      "children": {
                          "1": {
                              "type": 6,
                              "id": 1,
                              "description": "",
                              "values": {
                                  "0": "25.6"
                          "2": {
                              "type": 7,
                              "id": 2,
                              "description": "",
                              "values": {
                                  "1": "65"
                      "sensor_id": 2,
                      "type": 17,
              This is the sketch:
              #include <Wire.h>
              #include <SI7021.h>
              #include <EEPROM.h>
              #define AVERAGES 2
              // Pin definitions
              #define TEST_PIN       A0
              #define LED_PIN        A2
              // Sensor messages
              #ifdef BATT_SENSOR
              // Global settings
              bool state = false;
               * Setup code
                Serial.flush();
                Serial.flush();
                raHum.clear();
              #ifdef BATT_SENSOR
                measureCount ++;
                sendBattery ++;
                  highfreq = false;
                  measureCount = 0;
                   sendBattery = 0;
               * Parameters
                bool tx = force;
                if (tx) {
                  measureCount = 0;
                   sendBattery = 0;
               * Parameters
                  lastBattery = vcc;
              #ifdef BATT_SENSOR
              long readVcc() {
                #else
              void testMode()
                uint8_t ret_code;
                byte tests = 0;
                Serial.flush();
                Serial.flush();
                  tests ++;
                else
                Serial.flush();
                Serial.flush();
                  tests ++;
                else
                Serial.flush();
                Serial.flush();
                Serial.flush();
                  else
                    tests ++;
                Serial.flush();
                if (tests == 3)
                    delay(200);
                    delay(200);
                else
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @Madhias
              Sketchname is missing in the persistence file, so maybe that message doesn't go through? Have you looked at the serial log of the node and confirmed that all messages are sent ok?
                @Madhias
                MadhiasM
                MadhiasM
                Madhias
                @martinhjelmare It works now! I think it is a hardware issue I have here, since I just put the decoupling capacitor in between the radio and the pin header socket. Checking that connection helped (pushing again in), and the presentation was correct now - including the sketch name.
