  3. new RFM69 Gateway and node
14 Posts 5 Posters 6.6k Views 4 Watching
  • G
    G
    gloob
    wrote on last edited by gloob
    I did now switch from NRF24 to RFM69 for the gateway and one sensor.
    I can connect to the gateway from my controller (FHEM) without any problems and dont see any errors in the debug messages of the controller.
    The node shows some strange behavior and does not connect to the gateway.
    TSM:INIT
    TSF:WUR:MS=0
    TSM:INIT:TSP OK
    TSM:INIT:STATID=40
    TSF:SID:OK,ID=40
    TSM:FPAR
    TSF:MSG:SEND,40-40-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    !TSM:FPAR:NO REPLY
    TSM:FPAR
    !TSM:FPAR:NO REPLY
    TSM:FPAR
    !TSM:FPAR:NO REPLY
    TSM:FPAR
    !TSM:FPAR:FAIL
    TSM:FAIL:CNT=1
    TSM:FAIL:PDT
    Is this a problem related to the controller or to my communication between the node and the gateway?
    Are there any samples to test the communication between two RFM69 devices to check that the communication is not the problem.
    Regards
    Stefan
    • rmtuckerR
      rmtuckerR
      rmtucker
      Can you post your sketches for your gateway and node?
      Also what hardware are you using (radio and mcu etc)?
      • G
        G
        gloob
        I use the same hardware for the gateway and the node, a Wemos and a RFM69HW module.
        The gateway is using the following sketch:
         * Version 1.0 - Henrik EKblad
         * Contribution by Ivo Pullens (ESP8266 support)
         * The EthernetGateway sends data received from sensors to the WiFi link.
         * VERA CONFIGURATION:
         * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
         * E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
         * LED purposes:
         * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
         * nRF24L01+  ESP8266
         * VCC        VCC
         * CE         GPIO4
         * CSN/CS     GPIO15
         * SCK        GPIO14
         * MISO       GPIO12
         * MOSI       GPIO13
         * GND        GND
          * Inclusion mode button:
        #define MY_BAUD_RATE 9600
        #define MY_RADIO_RFM69
        #define MY_RFM69_FREQUENCY RF69_868MHZ
        #define MY_IS_RFM69HW
        #define MY_GATEWAY_ESP8266
        #define MY_ESP8266_SSID "xxx"
        #define MY_ESP8266_PASSWORD "xxx"
        #define MY_ESP8266_HOSTNAME "MySensor-Gateway-RFM69"
        #define MY_PORT 5003
        // Enable inclusion mode
        // #define MY_INCLUSION_BUTTON_FEATURE
        // Flash leds on rx/tx/err
        // Led pins used if blinking feature is enabled above
        #define MY_DEFAULT_ERR_LED_PIN LED_BUILTIN  // Error led pin
        #define MY_DEFAULT_RX_LED_PIN  LED_BUILTIN  // Receive led pin
        #define MY_DEFAULT_TX_LED_PIN  LED_BUILTIN  // the PCB, on board LED
        #include <ESP8266WiFi.h>
          #if defined MY_DEBUG
          if (WiFi.status() != WL_CONNECTED) {
            Serial.println("Not connected to WiFi");
          } else {
            Serial.println("");
            Serial.println("-- STA (client) informations --");
            Serial.print("Hostname: ");
            Serial.println(WiFi.hostname());
            Serial.print("Connected to: ");
            Serial.print(WiFi.SSID());
            Serial.print(" (");
            Serial.print(WiFi.BSSIDstr());
            Serial.print("), ");
            Serial.print(WiFi.RSSI());
            Serial.println("dBm");
            Serial.print("IP address: ");
            Serial.println(WiFi.localIP());
            Serial.print("Gateway address: ");
            Serial.println(WiFi.gatewayIP());
            Serial.print("Subnet mask: ");
            Serial.println(WiFi.subnetMask());
            Serial.print("MAC STA address: ");
            Serial.println(WiFi.macAddress());
            Serial.println("-- AP (server) informations --");
            Serial.print("Soft IP address: ");
            Serial.println(WiFi.softAPIP());
            Serial.print("MAC AP address: ");
            Serial.println(WiFi.softAPmacAddress());
            Serial.println("----");
            Serial.println("");
        and for the node I use this test sketch:
         * Example sketch showing how to measue light level using a LM393 photo-resistor
         * http://www.mysensors.org/build/light
        #define MY_NODE_ID 050
        //#define MY_RADIO_NRF24
        #define CHILD_ID_LIGHT 0
        #define LIGHT_SENSOR_ANALOG_PIN 0
        int lastLightLevel;
        	sendSketchInfo("Light Sensor", "1.0");
        	int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
        	Serial.println(lightLevel);
        		send(msg.set(lightLevel));
        		lastLightLevel = lightLevel;
        	sleep(SLEEP_TIME);
        • G
          G
          gloob
          This is the output from the gateway:
          0;255;3;0;9;TSF:LRT:OK
          0;255;3;0;9;TSM:INIT
          0;255;3;0;9;TSF:WUR:MS=0
          scandone
          state: 0 -> 2 (b0)
          state: 2 -> 3 (0)
          state: 3 -> 5 (10)
          add 0
          aid 18
          cnt
          connected with HasenpupsExtreme, channel 1
          dhcp client start...
          0;255;3;0;9;TSM:INIT:TSP OK
          0;255;3;0;9;TSM:INIT:GW MODE
          f r0, scandone
          ip:192.168.1.35,mask:255.255.255.0,gw:192.168.1.1
          .IP: 192.168.1.35
          0;255;3;0;9;MCO:BGN:STP
          Hostname: MySensor-Gateway-RFM69
          Connected to: HasenpupsExtreme (80:EA:96:F0:49:F2), -73dBm
          IP address: 192.168.1.35
          Gateway address: 192.168.1.1
          Subnet mask: 255.255.255.0
          MAC STA address: 5C:CF:7F:2C:11:3D
          Soft IP address: 0.0.0.0
          MAC AP address: 5E:CF:7F:2C:11:3D
          pm open,type:2 0
          0;255;3;0;9;Client 0 connected
          0;255;3;0;9;Client 0: 0;0;3;0;2;
          tekkaT 1 Reply Last reply
          • G gloob
            scandone
            state: 0 -> 2 (b0)
            state: 2 -> 3 (0)
            state: 3 -> 5 (10)
            add 0
            aid 18
            cnt
            f r0, scandone
            .IP: 192.168.1.35
            pm open,type:2 0
            tekkaT
            tekkaT
            tekka
            @gloob How did you connect the radio to the wemos board?
            • G
              G
              gloob
              I use this board:
              link text
              • E
                E
                emc2
                One thing seems to be missing for your GW sketch.
                In the example sketch I provide I define some things that seems to be missing here:
                #define MY_RF69_IRQ_PIN D2  // GPIO 4
                #define MY_RF69_SPI_CS  D8  // GPIO 15
                Could you try with the included "MySWemosGatewayESP8266OTA.ino" sketch to see if this one is working?
                • G
                  G
                  gloob
                  I now get some kind of communication but it seems that the WeMos pro mini does reset when a controller is connected and a message is received from a node.
                  I will check this tomorrow.
                  korttomaK 1 Reply Last reply
                  • G gloob
                    korttomaK
                    korttomaK
                    korttoma
                    @gloob reset of ethernet modules is usually a symptom of the problem in the Arduino AVR board definition in version 1.6.12 and newer. Please try version 1.6.11. (don't remember exactly what versions vere affected but 1.6.11 works for me).
                    • Tomas
                    G 1 Reply Last reply
                    • korttomaK korttoma
                      G
                      G
                      gloob
                      Thanks for this hint but is this also neccessary for the WeMos modules (ESP8266)? My gateway with an NRF24L01 chip and the same WeMos is running without any problems.
                      E 1 Reply Last reply
                      • G gloob
                        E
                        E
                        emc2
                        @gloob I received my RFM69 radio modules yesterday and did a quick test.
                        Same as for you, I'm unable to have a "MockSensor" talk to an esp8266 based gateway, both WeMos or NodeMCU.
                        Never used RFM69 before so I'm not sure how to go from there, will do a few more tests on evenings and this week end, let me know if you got something on your side.
                        • G
                          G
                          gloob
                          I can confirm that the adapter PCB is working without any problems together with a WeMos, because I use them to receive some signals of a weather station.
                          • E
                            E
                            emc2
                            Good to know.
                            I guess this is not a MySensors weather station, do you mind sharing the code you used, or project (I found a few on github).
                            I will have a look in the code to see if there is something obvious somewhere.
                            • G
                              G
                              gloob
                              It is called "LaCrosse Gateway"
                              You can find the source code here: https://svn.fhem.de/trac/export/HEAD/trunk/fhem/contrib/arduino/36_LaCrosseGateway.zip
                              I have included this gateway in FHEM and receive a weather station sensor from "Technoline" which is sending on 868MHz.
