  3. PCB design with nRF24L01 and Arduino Pro Mini
21 Posts 8 Posters 16.3k Views 4 Watching
  • RaPoR
    RaPoR
    RaPo
    wrote on last edited by RaPo
    Hello all,
    I am quite new to this form. I really like the idea of using small nrf24l01+arduino nodes around the home to control electronics.
    I have successfully hand built few nodes (2 based on Arduino Nano and 1 based on Arduino Pro Mini) and deployed around the home.
    Here are some of the pictures of my nodes
    It takes lot of time to hand build these nodes. So I decided to make a small generic PCB uing Arduino Pro Mini and fabricate it and use it. I designed the PCB in Eagle SW and fabricated with Seedstudios.
    Here is my board looks like
    After mounting the components, I found it is not working. Tx/Rx was completely failure. After several hours of debugging, found that my circult is correct and I assume there were some EMC effects.
    If I touch the antenna of nrf with my finger, Tx/Rx is successful and everything works perfect. If I remove my finger it does not work again.
    I thought because of placement of nrf module there were some EMC effects and created a V2 of my board by just changing position of nrf. It looks like this
    Unfortunately, even this board/design has the same problem.
    These are how the boards look like
    I also tried changing the position of nrf module by placing it in proto area and rewiring from the actual position, seems to have same problem.
    On both of these board when I lift the nrf module at higher level than the Arduino Pro by stacking additional female headers for nrf (as shown in below picture), they seem to be working.
    Could some please help me understand whats happening on my board. :-( I want to go for V3 of board which solves these problem but I could not figure out what exactly is causing the problem.
    Thank you so much for your support.
    Unfortunately, I do not have privilege to upload board and schematic files, so I adding screenshots here.
    H mfalkviddM 2 Replies Last reply
    • RaPoR RaPo
      Hello all,
      H
      H
      HarryDutch
      @Raghavendra-Prasad Looks like interference between the radio module and and the pcb. Could also be a GROUND problem with your pcb (it works when you're touching the antenna).
      First: remove the nrf from your pcb and reconnect with some jumper wires. Make sure the radio module is outside the pcb. If it works you have to redesign your pcb in such a way that the antenna is outside the pcb.
      You could also try to shield your nrf (search the forum).
      If it's still not working could you post your EAGLE files? (board and circuit file).
      Success
      RaPoR 1 Reply Last reply
      • pansenP
        pansenP
        pansen
        Also the schematic would be helpful! Do you have equipment to check the air interface? (i.e. oscilloscope, spectrum analyzer)
        Did you play with the power level of the nrf24?
        Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
        • H HarryDutch
          Success
          RaPoR
          RaPoR
          RaPo
          @HarryDutch Thanks for the reply. I think if I remove nrf and keep away from board it will definetly work. As shown in one of the pictures above when I put the NRF little higher than Arduio, it works flawless. I tried to share the board and schematic files, but I could not upload seems I do not have privilege to upload them. If there special way to upload .brd and .sch files ?
          H 1 Reply Last reply
          • pansenP pansen
            RaPoR
            RaPoR
            RaPo
            @pansen Thanks for reply. I tried to upload the .sch file could got some error, so I added schematic screenshot. I do not have a sophisticated equipment, but I can manage to use a oscilloscope from my office.
            • RaPoR RaPo
              @RaPo try different capacitors on the radio from VCC to GND and also try to make a wire from ground on different places like radio and arduino to source ground and see if that helps and when.
              Your pinheaders might also be the problem... sometimes they are not that good quality. Same thing if you solder everything directle to the board?
              • pansenP
                pansenP
                pansen
                Hmmm looks good, very strange indeed. Is it maybe the ground plane? A problem with your gateway?
                • sundberg84S sundberg84
                  RaPoR
                  RaPoR
                  RaPo
                  @sundberg84 I will give a try to source the groung from Arduino. I also had same doubt about the headers, so I tried headers of different qualities. So, I hope headers are good, nevertheless I will try to solder directly.
                  • pansenP pansen
                    RaPoR
                    RaPoR
                    RaPo
                    @pansen Even I have doubts on ground. My gateway is pretty good. I still have my hand made nodes deployed around home working with Gateway without any problem.
                    • RaPoR
                      RaPoR
                      RaPo
                      Are there any hints/advises or best practices, if I decide to re-design from scratch ?
                      Thanks.
                      • pansenP
                        pansenP
                        pansen
                        Unfortunately I am not a PCB designer..I would advise you to ask this question (and also why the boards does not work) on a dedicated electronics forum. EEVBlog forums are very good for that purpose.
                        Good luck!
                        P.S.: I guess you also tried different nrf24 boards right?
                        • RaPoR RaPo
                          H
                          H
                          HarryDutch
                          @RaPo You can zip your .brd and .sch files and upload the zip file.
                          • scalzS
                            scalzS
                            wrote on last edited by scalz
                            Hi.
                            I'm thinking like others..for bad antenna orientation regarding your pcb. Sometimes this can work, but it adds noise to your radio.. what makes me think is on your pic you place it a little bit more above then it works.. the @sundberg84 notes can be interesting to check too ;)
                            Not really needed here, because you've only one thing on SPI bus, but it's good practice to have a pullup on CS line, to be sure to enable SPI periph only when needed. but not mandatory here sure!
                            For a battery powered node, i would better use a si7021 than dht22 ;) you can find si7021 breakout board at ali for a reasonable cost, and you'll definitely get a better battery lifetime.
                            And don't forget the resistor divider for batt voltage will consumes power. If directly powered from battery, you can simply use the VCC lib to read the voltage, or in other case (with any kind of reg) would need a mosfet to switch off your resistor divider.
                            Keep the good work, you'll get it i'm sure :+1:
                            • RaPoR RaPo
                              Hello all,
                              @RaPo I think all the conductive material near the antenna absorbs/blocks the radio signal. That's why you get a better signal when the nrf is put on taller headers. Let the antenna stick out over the side of the board or make sure there is a sufficiently large area without any connections around the antenna. I do not know how much is considered sufficient though.
                              • bjacobseB
                                bjacobseB
                                bjacobse
                                Hi you are welcome to copy my design
                                https://www.openhardware.io/view/56/Mys-Interposer-NRFArduino-Pro-Mini
                                • pansenP pansen
                                  Good luck!
                                  RaPoR
                                  RaPoR
                                  RaPo
                                  @pansen Hi thanks, I will try in that forum you mentioned and yes I have tried different nrfs too ..
                                  • scalzS scalz
                                    Hi.
                                    RaPoR
                                    RaPoR
                                    RaPo
                                    @scalz HI, thanks for the kind words. Its a very useful hint about VCC lib. Even I was thinking around saving the power loss at the resistor. Thanks again.
                                      RaPoR
                                      RaPoR
                                      RaPo
                                      @mfalkvidd Thanks for the hints. I will definitely consider this in my design.
                                      • bjacobseB bjacobse
                                        RaPoR
                                        RaPoR
                                        RaPo
                                        @bjacobse Hi, Thank you so much. This exactly meets my requirements too, I will re-use it.
                                        • RaPoR
                                          RaPoR
                                          RaPo
                                          Hello all,
                                          Thank you so much for all your kind support. From a review from one my colleague, I learned that 90 degree sharp bends should be avoided. These sharp edges acts as local antenna and EMC interference. Unfortunately, my design has several of such sharp bends.
