  3. i need a change in transport serial gateway
5 Posts 2 Posters 2.7k Views 2 Watching
  • R
    R
    Reza
    wrote on last edited by Reza
    hi friends
    in my wireless network all of configure and sketch is ok . even i use repeater between nodes.but i have error and lost some of command or ack . % of error is much. i want decrease this errors.even if delay will increase (a little).
    i search about this and i found some things.
    i think if i change MY_BAUD_RATE in MYConfig and decrease this , so decrease % of errors. is this true ?
    also if i put a delay between send and receive command and ack , so this may be effective !
    also if i increase number of resend command or ack (when first or second was fail) may be effective !
    are these true ? if yes , i dont know how change this ! :( please help me for the most Reliability
    thank you
    Boots33B 1 Reply Last reply
    • R Reza
      hi friends
      thank you
      Boots33B
      Boots33B
      Boots33
      @Reza Sorry to hear you are still having trouble with your nodes communication. I haven't tried any of the things you have outlined above but it will cost you nothing to try so worth a go.
      A couple of other things you might like to try( if you haven't already)
      First have you tried different NRF modules. I have had some of the blob type that were no good at all and very unreliable.
      They are easy to spot see the first picture has a round blob where the normally square chip is, as can be seen on the second picture. If yours are the round blob type that may be the problem
      The second thing would be to run a scanner to see if you have some congestion on the channel you are using.
      To do this you will need a spare arduino and nrf radio
      First install the rf24 library from your library manager
      then you will need to load the scanner sketch from maniacbug to your arduino. I have made a slight change to this sketch so it will use the same wiring as MySensors does.
       Copyright (C) 2011 J. Coliz <maniacbug@ymail.com>
       This program is free software; you can redistribute it and/or
       modify it under the terms of the GNU General Public License
       version 2 as published by the Free Software Foundation.
       * Channel scanner
       * Example to detect interference on the various channels available.
       * This is a good diagnostic tool to check whether you're picking a
       * good channel for your application.
       * Inspired by cpixip.
       * See http://arduino.cc/forum/index.php/topic,54795.0.html
       * uses the RF24 library. install from the library manager or download from
       * http://tmrh20.github.io/RF24/index.html for a manual install
      #include "nRF24L01.h"
      #include "RF24.h"
      #include "printf.h"
      // Hardware configuration
      // Set up nRF24L01 radio on SPI bus plus pins 9 & 10
      RF24 radio(9,10);
      // Channel info
      const uint8_t num_channels = 126;
      uint8_t values[num_channels];
      // Setup
      void setup(void)
        // Print preamble
        Serial.begin(115200);
        printf_begin();
        Serial.println(F("\n\rRF24/examples/scanner/"));
        // Setup and configure rf radio
        radio.begin();
        radio.setAutoAck(false);
        // Get into standby mode
        radio.startListening();
        radio.stopListening();
        // Print out header, high then low digit
        int i = 0;
        while ( i < num_channels )
          printf("%x",i>>4);
          ++i;
        Serial.println();
        i = 0;
          printf("%x",i&0xf);
          ++i;
        Serial.println();
      // Loop
      const int num_reps = 100;
      void loop(void)
        // Clear measurement values
        memset(values,0,sizeof(values));
        // Scan all channels num_reps times
        int rep_counter = num_reps;
        while (rep_counter--)
          int i = num_channels;
          while (i--)
            // Select this channel
            radio.setChannel(i);
            // Listen for a little
            delayMicroseconds(225);
            // Did we get a carrier?
            if ( radio.testCarrier() ){
              ++values[i];
        // Print out channel measurements, clamped to a single hex digit
        int i = 0;
          printf("%x",min(0xf,values[i]&0xf));
          ++i;
        Serial.println();
      // vim:ai:cin:sts=2 sw=2 ft=cpp
      Once it has loaded open up your serial monitor and you will see a sort of waterfall display that represents the 126 channels of the nrf module. A new line will be added every few seconds as the scanning progresses.
      The channels with 0 mean there is no activity. Channels with higher numbers mean there is traffic on those channels. The higher the number the more busy that channel is.
      You can see on the sample below most of my channels are pretty clear (I am lucky, I live in a semi rural area) There is activity around channels 30 to 40, that is my wifi network.
      R 3 Replies Last reply
      • Boots33B Boots33
         * Channel scanner
        #include "RF24.h"
        #include "printf.h"
        RF24 radio(9,10);
        // Channel info
        // Setup
        void setup(void)
          // Print preamble
          printf_begin();
          radio.begin();
          int i = 0;
            printf("%x",i>>4);
            ++i;
          Serial.println();
          i = 0;
            printf("%x",i&0xf);
            ++i;
          Serial.println();
        // Loop
        void loop(void)
            while (i--)
                ++values[i];
          int i = 0;
            ++i;
          Serial.println();
        R
        R
        Reza
        @Boots33 wow thank you dear boots for full explain and help me .
        i try with 5 type of nrf24+ module:) but . . .
        i will test your code and feedback here. thank you :pray:
        • Boots33B Boots33
           * Channel scanner
          #include "RF24.h"
          #include "printf.h"
          RF24 radio(9,10);
          // Channel info
          // Setup
          void setup(void)
            // Print preamble
            printf_begin();
            radio.begin();
            int i = 0;
              printf("%x",i>>4);
              ++i;
            Serial.println();
            i = 0;
              printf("%x",i&0xf);
              ++i;
            Serial.println();
          // Loop
          void loop(void)
              while (i--)
                  ++values[i];
            int i = 0;
              ++i;
            Serial.println();
          R
          R
          Reza
          @Boots33
          first thank you for your code. this is very interesting.
          so i test this in my home and my friends home.
          first pic is test near controller (but now controller is off)
          2th pic is test near a relay node(that very bad working)
          3th is in my friend house ...
          • Boots33B Boots33
             * Channel scanner
            #include "RF24.h"
            #include "printf.h"
            RF24 radio(9,10);
            // Channel info
            // Setup
            void setup(void)
              // Print preamble
              printf_begin();
              radio.begin();
              int i = 0;
                printf("%x",i>>4);
                ++i;
              Serial.println();
              i = 0;
                printf("%x",i&0xf);
                ++i;
              Serial.println();
            // Loop
            void loop(void)
                while (i--)
                    ++values[i];
              int i = 0;
                ++i;
              Serial.println();
            R
            R
            Reza
            @Boots33
            channel 0 and 76 that i use and test seem not busy and my problem is not related to this .
            as I said before . i think this is not related to my hardware because i use several .
            i test 5 model radio. also i test LED instead of relay but i have % of error (much).
            use power 5v 10A use radio adapter.use reglator .... but ...
            so i think best of solution is little change in library.do you think with decrease boud rate or increase number of resend or increase delay between command and ack can resolve this issue ?
