  3. Binary / Temp sensor help - sleep time
temperaturesleep timebinary
3 Posts 2 Posters 4.0k Views 1 Watching
  • N
    N
    niccodemi
    I combined temp and binary (2x) sketches.
    All works ok if I remove "sleep time" but in this case I get flooded with temperature sensor data.
    If "sleep time" is used then binary switches don't change states.
    How to amend sketch to send temp to gw at certain interval ie 30 seconds?
         // 2x binary switch + dallas temp example
         // Connect button or door/window reed switch between
         // digitial I/O pin 4,5 (BUTTON_PIN_4/BUTTON_PIN_5 below) and GND.
        // Connect dallas temp sensor to digital pin 3
    #include <Bounce2.h>
    #include <OneWire.h>
    #define CHILD_ID_4 4
    #define CHILD_ID_5 5
    #define BUTTON_PIN_4  4  // Arduino Digital I/O pin for button/reed switch
    #define BUTTON_PIN_5  5  // Arduino Digital I/O pin for button/reed switch
    OneWire oneWire(ONE_WIRE_BUS);
    Bounce debouncer = Bounce();
    Bounce debouncer_2 = Bounce();
    int oldValue=-1;
    int oldValue_2 =-1;
    int numSensors=0;
    boolean metric = true;
    MyMessage msg(0,V_TEMP);
    MyMessage msg4(CHILD_ID_4,V_TRIPPED);
    MyMessage msg5(CHILD_ID_5,V_TRIPPED);
      // Startup OneWire
      sensors.begin();
      gw.begin();
      gw.sendSketchInfo("Door/Temp", "1.0");
         gw.present(i, S_TEMP);
     // Setup the button
      pinMode(BUTTON_PIN_4,INPUT);
      pinMode(BUTTON_PIN_5,INPUT);
      // Activate internal pull-up
      digitalWrite(BUTTON_PIN_4,HIGH);
      digitalWrite(BUTTON_PIN_5,HIGH);
      debouncer.attach(BUTTON_PIN_4);
      debouncer.interval(5);
      debouncer_2.attach(BUTTON_PIN_5);
      debouncer_2.interval(5);
      gw.present(CHILD_ID_4, S_DOOR);
      gw.present(CHILD_ID_5, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         gw.send(msg4.set(value==HIGH ? 1 : 0));
         oldValue = value;
      debouncer_2.update();
      int value_2 = debouncer_2.read();
      if (value_2 != oldValue_2) {
         gw.send(msg5.set(value_2==HIGH ? 1 : 0));
         oldValue_2 = value_2;
      gw.process();
        if (lastTemperature[i] != temperature && temperature != -127.00) {
      gw.sleep(SLEEP_TIME);
    • N niccodemi
      int oldValue=-1;
      int oldValue_2 =-1;
      int numSensors=0;
        // Startup OneWire
        sensors.begin();
        gw.begin();
       // Setup the button
        debouncer.update();
           oldValue = value;
        gw.process();
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @niccodemi
      you can try this way... untested but it compiles:
      //unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
      int oldValue=-1;
      int oldValue_2 =-1;
      int numSensors=0;
        sensors.begin();
        gw.begin();
        debouncer.update();
          oldValue = value;
        gw.process();
        updateTemperature(30);// update time in seconds
        //gw.sleep(SLEEP_TIME);
      void updateTemperature(int frequency)
        static unsigned long lastUpdateTime;
        if (millis() - lastUpdateTime >= frequency * 1000UL)
          for (int i=0; i<numSensors && i< MAX_ATTACHED_DS18B20; i++)
          lastUpdateTime += frequency * 1000UL;
      N 1 Reply Last reply
        @niccodemi
        int oldValue=-1;
        int oldValue_2 =-1;
        int numSensors=0;
          sensors.begin();
          gw.begin();
          debouncer.update();
            oldValue = value;
          gw.process();
        N
        N
        niccodemi
        @BulldogLowell thank you, I uploaded it and so far it works fine.
