  3. πŸ’¬ Soil Moisture Sensor Pro Mini
pro minisoilmoisturemysensornrf24l01
23 Posts 10 Posters 9.7k Views 10 Watching
  • M MikaelJones
    So would you say there are better solutions to building a soil moisture monitoring for many plants ol the cheap? For me, it’s mainly for fun and making sure I don’t miss watering my plants at home :)
    UL7AAjrU
    UL7AAjrU
    UL7AAjr
    wrote on last edited by UL7AAjr
    #21
    @mikaeljones
    I think the most suitable device for monitoring processes is a tablet PC based on Intel and Windows. There are simple and cheap models costing less than $ 200. This is much simpler and more versatile than developing advanced controllers with a display. In addition, you can get remote access in a simple way, for example, TeamViewer. Well, the simplicity of developing a program is also important.
    Since I use the RS-485 protocol and Modbus, it's easy for me to connect all sensors and pumps via USB-RS485 adapter.
    I do not use wireless sensors, as I believe that if a pipe comes to the plant for irrigation, it is not difficult to add a cable.
    However, from time to time, I return to developing my own simplified watering controller :)
    • S
      schif
      Thanks for this great project.
      You have optimized the space used, battery and corrosion, good job man !
      About the battery level, can i replace the 0.1uF by a 0.22uF ?
      I only have this one.
      Thank you
      tonnerre33T 1 Reply Last reply
      • S schif
        Thank you
        tonnerre33T
        tonnerre33T
        tonnerre33
        wrote on last edited by tonnerre33
        #23
        @schif
        Thanx for you comment. Yes you can use it but use a ceramic capacitor ;)
        With your input, this post could be even better πŸ’—
