  3. W5100 Gateway hangs /freezes after some time.
23 Posts 7 Posters 6.6k Views 5 Watching
  • webstorW Offline
    webstorW Offline
    webstor
    when you say freezes: Do you mean it hangs totally, which means it isn't pingable @ all?
    Or just won't accept connections from the sensors?
    • FraidF Offline
      FraidF Offline
      Fraid
      Thank for the hint, I was able to invested the issue more. Here the result:
      @gohan
      Sketch uses 19560 bytes (60%) of program storage space. Maximum is 32256 bytes.
      Global variables use 981 bytes (47%) of dynamic memory, leaving 1067 bytes for local variables. Maximum is 2048 bytes.
      @webstor No it's pingable but their some timeout.
      Request timeout for icmp_seq 115
      Request timeout for icmp_seq 116
      64 bytes from 1.1.0.130: icmp_seq=117 ttl=128 time=0.693 ms
      64 bytes from 1.1.0.130: icmp_seq=118 ttl=128 time=0.694 ms
      64 bytes from 1.1.0.130: icmp_seq=119 ttl=128 time=0.656 ms
      64 bytes from 1.1.0.130: icmp_seq=120 ttl=128 time=3.135 ms
      64 bytes from 1.1.0.130: icmp_seq=121 ttl=128 time=0.641 ms
      64 bytes from 1.1.0.130: icmp_seq=122 ttl=128 time=0.618 ms
      64 bytes from 1.1.0.130: icmp_seq=123 ttl=128 time=0.861 ms
      64 bytes from 1.1.0.130: icmp_seq=124 ttl=128 time=3.536 ms
      Request timeout for icmp_seq 125
      Request timeout for icmp_seq 126
      Request timeout for icmp_seq 127
      Request timeout for icmp_seq 128
      64 bytes from 1.1.0.130: icmp_seq=129 ttl=128 time=0.494 ms
      64 bytes from 1.1.0.130: icmp_seq=130 ttl=128 time=0.563 ms
      64 bytes from 1.1.0.130: icmp_seq=131 ttl=128 time=0.622 ms
      64 bytes from 1.1.0.130: icmp_seq=132 ttl=128 time=0.643 ms
      Request timeout for icmp_seq 133
      Request timeout for icmp_seq 134
      Request timeout for icmp_seq 135
      Request timeout for icmp_seq 136
      Request timeout for icmp_seq 137
      64 bytes from 1.1.0.130: icmp_seq=138 ttl=128 time=0.828 ms
      64 bytes from 1.1.0.130: icmp_seq=139 ttl=128 time=0.570 ms
      64 bytes from 1.1.0.130: icmp_seq=140 ttl=128 time=0.766 ms
      64 bytes from 1.1.0.130: icmp_seq=141 ttl=128 time=0.673 ms
      64 bytes from 1.1.0.130: icmp_seq=142 ttl=128 time=3.274 ms
      64 bytes from 1.1.0.130: icmp_seq=143 ttl=128 time=0.662 ms
      64 bytes from 1.1.0.130: icmp_seq=144 ttl=128 time=0.714 ms
      Request timeout for icmp_seq 145
      Request timeout for icmp_seq 146
      64 bytes from 1.1.0.130: icmp_seq=147 ttl=128 time=0.663 ms
      64 bytes from 1.1.0.130: icmp_seq=148 ttl=128 time=3.395 ms
      64 bytes from 1.1.0.130: icmp_seq=149 ttl=128 time=0.660 ms
      64 bytes from 1.1.0.130: icmp_seq=150 ttl=128 time=3.527 ms
      64 bytes from 1.1.0.130: icmp_seq=151 ttl=128 time=0.650 ms
      64 bytes from 1.1.0.130: icmp_seq=152 ttl=128 time=0.629 ms
      64 bytes from 1.1.0.130: icmp_seq=153 ttl=128 time=0.565 ms
      64 bytes from 1.1.0.130: icmp_seq=154 ttl=128 time=0.639 ms
      Same test after reset, GW keep dropping but this time with max of 2 drop per ten ping. Other devices (phone, bridge etc...) can be pinged without timeout and I'm on the same network.
      For the communication testing, I'm sending payload to my tv sensor, and I made a video showing the GW status led when he doesn't work:
      and
      After reset
      Look like it's a reset on the first video?
      Next test, new sketch with debug on, sending same payload, GW always receive something like:
      0;255;3;0;9;Eth: 2;3;1;0;32;10
      0;255;3;0;9;TSF:MSG:SEND,0-0-2-2,s=3,c=1,t=32,pt=0,l=2,sg=0,ft=0,st=OK:10
      Some time even when payload is received, TV doesn't turn on, also tested with a simple light sensor. GW and TV are in the same room.
      So look like GW is dropping some message, I'll try tomorrow to get back to previous AVR, if their no hint.
      • FraidF Offline
        FraidF Offline
        Fraid
        Hi guys, I may found the issue.
        GW was powered from the NAS (for month) and I switched for a wall adapter. Now I'm able to ping GW without timeout...sorry (I see you guys coming....obviously it's a power issue :D !). GW has been running for one days now.
        Note: I'm using AVR 1.6.16 now, but i'm pretty sure, power was the real issue.
