  3. why no one uses latching relays ?
41 Posts 14 Posters 22.2k Views 18 Watching
  • wallyllamaW
    wallyllamaW
    wallyllama
    There is a very minor edge case where you switch the relay and lose power before writing the state. Probably would never happen in reality. I think a bigger problem, which should be solvable) is if you lose power to your whole house, some relays would latched on and you could have surges or other problems. Hopefully latching relays are robust enough to handle it.
    Another solution to the state problem is to have a power up routine that set all relays to a predefined state, then you know. That may be annoying if you reboot the system while someone is reading and the lights go off. This could happen with the more common relays also. The state problem is a lesser worry. The bigger worry is what happens when power comes back, do the relays leave things in a safe state while things initialize.
    It comes down to trade offs, save some power and maybe have some imperfect behavior, or use a bit more and have fewer oddities. I think you almost have to decide for each relay.
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      I believe that with latching relay there is also a way to make the relay go into specific state during power outage - with a capacitor that stores some energy, that energy may be used to switch the relay into this specifi state. So I think that latching relays can do all the things non-laching relays can and also more :) and they are much more energy efficient. So my biggest issue is why there is so little of them on the market and hardly no ready made modules with required circuitry to handle them. And they are sooooo expensive ... :(
      wallyllamaW 1 Reply Last reply
      • Anne van RossumA
        Anne van RossumA
        Anne van Rossum
        You can store the state in FLASH indeed, and have a rotating scheme to reduce wear. However, in practice it should also go fine if you store the information outside your system.
        Suppose you have a phone that remotely SETs the relay. Now the relay gets powered off and on through some fluke. The next time it is powered on and its state is the same as that on the phone, because that device is oblivious to this entire sequence of events.
        Next time the phone remotely does a RESET and the relay will toggle as expected.
        If (1) someone else does change the state of the relay and (2) the chip is recycled, then you will be out of sync with the actual state for one cycle. After sending a SET or RESET it is synchronized again.
        • rozpruwaczR rozpruwacz
          wallyllamaW
          wallyllamaW
          wallyllama
          @rozpruwacz i think your answer is "sooooo expensive", i suspect they are more complicated to build, so even if they were popular they would still cost more. As for the power cost, to put it in perspective, if you use 14w led bulbs, and your automation saves you 1 hour of bulb use, that will run your relay for 28hours at .5w. Now that doesn't help much if you are trying to run the relay on batteries/solar.
            Do solid stare relays consume less power?
            YveauxY 1 Reply Last reply
              YveauxY
              YveauxY
              @gohan yes, they only consume power when making the switch. They don't consume any power to maintain state.
              gohanG 1 Reply Last reply
              • YveauxY Yveaux
                @Yveaux
                I am talking about something like these https://it.aliexpress.com/popular/solid-state-relay-arduino.html . I heven't looked much into them since they have limitations, but I like the fact they are not mechanical.
                • FotoFieberF
                  FotoFieberF
                  FotoFieber
                  Apart from 12V supply voltage, this seems interesting:
                  http://www.ebay.com/itm/Latching-Bistable-Relay-module-12V-Relay-board-for-AVR-PIC-Arduino-from-EU-/181276052335
                    @Yveaux
                    YveauxY
                    YveauxY
                    @gohan said in why no one uses latching relays ?:
                    @Yveaux
                    Sorry, I misread your question, as this thread is about latching relays, not solid state.
                    Solid state relays do consume power, but in general less than mechanical relays.
                    Nca78N 1 Reply Last reply
                      No problem, I brought up the solid state because the opening post was about power consumption of standard relays compared to the latching ones, so I was wondering where they fit in between. That's it. :)
                      • wallyllamaW wallyllama
                        rozpruwaczR
                        rozpruwaczR
                        rozpruwacz
                        @wallyllama I agree that there are cases where normal relays are completely fine, but if you want to control some low power device that draws 0.5W then it makes sense to use latching relay, especially if it will be turned on half the time and you have 20 of them.
                          rozpruwaczR
                          rozpruwaczR
                          rozpruwacz
                          @gohan ssr's require less power to drive them but on the load side they have about 1V drop so this produses power loses, and ssr's that can handle large currents are quite big. But the have other features, like zero crossing switching (they can switch on/off when the voltage sine wave is near 0V).
                          • YveauxY Yveaux
                            @Yveaux
                            Nca78N
                            Nca78N
                            Why are you all saying they are expensive ? If you take the 12V versions they are just a bit more expensive than normal relays.
                            @Yveaux said in why no one uses latching relays ?:
                            I'm sorry but I don't agree with this statement ;)
                            They consume nearly nothing from the "command" side, but they have a voltage drop. I think it's about 1V on those small Omron (on original one, not the copies sold on Aliexpress which could be worse) so the power loss is up to 2 watts for the 2A they are rated for. On the bigger models visible from the link above you need a (huge) radiator over 4A.
                            • YveauxY Yveaux
                              @rozpruwacz We were talking relay modules (like this one) which normally only take supply and a single control signal.
                              Having to control the latching of the relay using an H-Bridge I find 'a bit harder' compared to just toggling an IO, regarding both software and hardware.
                              For reference, this is the schematic I use to control a latching relay:
                              0_1487085965612_upload-0a5788cc-27e7-4bf6-98a1-7c26962bf71f
                              It uses a MAX2226/4427/4428 or compatible MOSFET driver to drive the relay.
                              And a function to switch it:
                              #define RELAY_INA_PIN         (A0)
                              #define RELAY_INB_PIN         (A1)
                              #define RELAY_SET_TIME_MS     (30)
                              static void switchRelay( const bool on )
                                  digitalWrite(RELAY_INA_PIN, on ? LOW : HIGH);
                                  digitalWrite(RELAY_INB_PIN, on ? HIGH : LOW);
                                  delay(RELAY_SET_TIME_MS);
                                  digitalWrite(RELAY_INA_PIN, LOW);
                                  digitalWrite(RELAY_INB_PIN, LOW);
                              A Former User
                              wrote on last edited by [[global:former-user]]
                              #34
                              You don't necessary need to use an H-Bridge, you can use: (Don't forget the flyback diodes!)
                              That above schematic is for an intermediate switch in a multi way switching circuit. This way has a high W.A.F (Wife Acceptance Factor). Doing it this way, you can keep the conventional light switches operational. As its part of a multiway light switch circuit, you only need to toggle it to turn the light on or off. You do of course need to detect if the light is on though!
                              And unless you're mass producing these for sale, what does the extra cost matter?
                              • rozpruwaczR
                                rozpruwaczR
                                rozpruwacz
                                wrote on last edited by rozpruwacz
                                #35
                                HAHA, You can always get a new wife with lower W.A.T (Wife Acceptance Treshold) :D
                                YveauxY ? 2 Replies Last reply
                                  YveauxY
                                  YveauxY
                                  @rozpruwacz that's even more expensive! :nail_care:
                                    A Former User
                                    @rozpruwacz I've invested too much time and money in to this one already!
                                    • G
                                      G
                                      Grubstake
                                      wrote on last edited by Grubstake
                                      #38
                                      @rozpruwacz
                                      Late to this but for anyone who finds this thread (like I did) with the same thing in mind...here's a relay that looks like it might work for some. (I have not received it yet.)
                                      https://www.ebay.com/p/5v-Flip-flop-Latch-Relay-Module-Bistable-Self-locking-Switch-Low-Trigger-Board/14005978712
                                      Specifications:
                                      Working voltage: DC 5V
                                      Working current: 70MA
                                      Standby current: 1UA
                                      Load current: AC 250V / 10A, DC 30V / 10A
                                      Trigger mode: Low pulse trigger
                                      There are 10 more listings for what looks like the same product...most about $2 US.
                                      This seems useful for any sort of battery powered node that is to trigger opening or closing a circuit. I certainly would not use it for house lighting in general due to the toggle/uncertain state, storing the state at the node, detecting the relay state when switching, and synchronizing to correct an error seems possible if needed.
                                      My use case is to provide remote control to outdoor landscape lights that use AC line power and a transfer to feed low voltage lighting common in the USA. I have a large yard with 4 different transformers that currently mechanical timer, light sensor, or electrical timer. I'm usually happy to NOT automate dedicated independent simple systems that just work. In this case, my equipment needs fixing after a power outage (mechanical timer), doesn't work well in winter when photo sensors don't get enough light, and I can't turn on the lighting manually very easily. I want to keep these transformers in place as a fallback (in manual 'on' mode), so I could use remote controlled relay to switch the 12 volt AC output to the lighting circuit. I prefer to use battery powered nodes even though line power is available because everything is outdoors and weatherproofing an AC power supply to power a node might be more work.
                                      • S
                                        sridhar
                                        I just came across this thread while doing more research - good stuff!
                                        I do have a latching relay breakout board with 2 latching bistable relays that can switch 16A @ 250VAC
                                        As others have already mentioned, these relays have separate inputs for setting/unsetting the relay, so you can always start off with whatever state you want. Adding a hall effect current sensor, you can also detect the current state of the relay to see if it is open or closed.
                                        You can check it out on Tindie.
                                        Cheers,
                                        Sridhar
                                        • G Grubstake
                                          @rozpruwacz
                                          Specifications:
                                          YveauxY
                                          YveauxY
                                          @grubstake said in why no one uses latching relays ?:
                                          Be aware that the relay on the board is non latching. Keeping it in actuated state requires continuous power to the relay coil, which will quickly drain batteries.
