  3. Current Sensing?
Current Sensing?
111 Posts 12 Posters 65.4k Views 10 Watching
  • S
    Samuel235
    I'm pretty impressed with how it handeling that overhang on the logo considering there wasn't much vertical space under it to the bed i expected it to droop down to the bed. I like it! Ignore the little cunk out at the cable entry part, my glue held it too hard on the bed. The cable grip is a little too small, reprinting it with a more pronounced grip now (Didn't want it too large as it would damage the cable, but its not enough at the moment).
    MySensors 2.1.1
    • scalzS
      scalzS
      wrote on last edited by scalz
      #82
      it didn't slice the text??
        mwalker
        It looks good @Samuel235, having the detector recessed in a cavity in order to reduce the impact of ambient light isn't something that I had considered, I guess because I was mainly thinking about an off the shelf enclosure, or repurposing some other type of container, i.e. this, but I like these designs a lot better.
        I was able to use a cheap logic analyser with sigrok to work out the pulse time on my meter, and I am in the midst of designing a test rig using WS2812 led strip and a separate microcontroller in order to be able to test my pulse detection code when more of the LM393 modules arrive. One location I need to use this system has ten meters, and another has nine meters, so I need to have a good test rig to make sure that my system won't be dropping pulses.
        • S
          Samuel235
          #84
          This is the bottom @scalz, the previous post was of the top part.
          Yes, having the diode resessed was big importance in my eyes. Where do you live as if its not that bad we could print some for you and send to you if you wanted it after it was finished.
          I have a few little tweeks to do but i'm pretty pleased with how the details have turned out.
          Things to ammend:
          1. Change cable specs if i decide on using 4 core into a rj11 connector.
          2. Sort out screw holes as they need some more plastic inside to be more substantial to receive my self-tapping screws.
          3. Make walls slightly thicker to allow for another skin.
          MySensors 2.1.1
            rj11 connector would be very nice to have :)
            S 1 Reply Last reply
              Samuel235
              @gohan - I'm thinking either a 4p4c variant or some other board connector. If you could choose any board connector for this use then what would you prefer? Molex JST, dupont, RJ45/RJ11, 3.5mm headphone, 2.5mm headphone, USB mini/micro, anything. What would your preference be? I was only thinking RJ because it locks into place and is hard to pull out if knocked or anything.
              MySensors 2.1.1
              gohanG 1 Reply Last reply
              • scalzS
                scalzS
                #87
                @Samuel235 yep screw holes are a bit tight but it looks good ;) I did a mini tunnel too on mine for isolating a bit the sensor, i think this can help, but not sure as it also increases the distance between the blinking led, but should work.
                For the connector on my side i don't really care :) or rj11/45 maybe..
                • S Samuel235
                  @Samuel235
                  IMHO rj11 is good because as you said it locks in place, it is not easily mistaken for whatever use, you can make a cable with rj11 plug very quickly (if you have the tool ofc). On the other hand I don't know how hard it would be to make the female socket fit in the 3D printed housing or in any sensor box where the arduino will be placed.
                  • S
                    Samuel235
                    As i would be making the arduino side as a custom board, then i will be able to just put a footprint onto the PCB, not an issue in that respect :)
                    MySensors 2.1.1
                      I am more into IT stuff, 3D modeling/printing and PCB design are still unknown subjects for me :D
                        mwalker
                        @Samuel235 I'm a fair way away from anywhere in Australia, so it may not be worth it, but thank you.
                        For connectors I have been leaning towards them being captive on the sensor end, I was looking at RJ45 for the other end, if only because I thought I could repurpose the connector bank and case from a cheap or surplus hub/switch/router.
                        • M mwalker
                          Samuel235
                          @mwalker - Ahh okay, no worries.
                          Thats makes sense for a one off for yourself, if it is just a one off then i would just wait for us to finished the pcb design and get them made up then you could just cut the connector off the end and add dupont connectors or something and push onto arduino. Unless you're waiting for the finished product with the custom arduino board too.
                          MySensors 2.1.1
                            mwalker
                            Yes, I imagine a requirement to monitor 9 or 10 separate meters at a single location is a bit of a one off, but I'll be definitely interested in what you come up with to see if I can utilise it. I expect I will be using an ESP8266 based board for the micro controller part as power supply is not an issue, and I have wifi available.
                            While researching bits and pieces across the internet I came across:
                            https://openenergymonitor.org/forum-archive/node/10707.html
                            which I thought may be of interest. It seems they are flashing the LED from a microcontroller output, which is an interesting way of proving that the overall system is working.
                            • M mwalker
                              Samuel235
                              @mwalker - Okay, well at that quantity you may find it useful to get some PCBs ordered that i design and then put it in a enclosure that you can come up with (saving shipping costs from me to you). Unless you just directly copy my circuitry to your own solution, up to you! So yeah, if you wanted to use my circuitry you would just wire the three wires into the arduino rather than using a RJ11 connector, would be easier than making a enclosure with panel mounted jacks and stuff. Its much easier for me to use RJ11 connectors as i'm making the arduino side as a custom board too.
                              That is what i would call a backward solution. I do agree that it would allow you to see that the arduino is running, but its just not really the way i'm doing this. The LED that i will be blinking on the front of the module is being triggered by the Photodiode and comparator itself, nothing to do with the arduino (this way if someone needed to come to your meter, they can see the LED even if the arduino has failed, as long as its still getting its power. This is not really a design feature though, just a bi-product of how i've made it).
                              MySensors 2.1.1
                                mwalker
                                @Samuel235 sounds good.
                                More digging identified the openenergymonitor sensor is a rebadged unit manufactured in China:
                                https://community.openenergymonitor.org/t/directly-connecting-to-optical-pulse-counter-with-rpi/1294/2
                                The link doesn't work but it is in the Internet archive, they have a (fuzzy) photo of the internals at right at the bottom:
                                http://web.archive.org/web/20160819224835/https://openenergymonitor.org/emon/opticalpulsesensor
                                • M mwalker
                                  Samuel235
                                  @mwalker - Same image as i found on one of the links above. They are not choosing to go the comparator method either. I will be interested to see how fast mine could detect pulses. I might take one into University/school and get the pulse/wave generator on it.
                                  MySensors 2.1.1
                                  • scalzS
                                    scalzS
                                    #97
                                    @Samuel235
                                    i don't think you need to go very high freq though, even with 50hz i think you can cover almost all meters you would need.
                                    Because 50hz would allow 50*3600= 180000 pulses/hour so if you say you go up to 20kw/h which is a lot! that would be 9000pulses/kw/h. So 100hz with a photores is a lot..
                                    but sure photodiode could be useful maybe for some other usecase, i don't know..or for some data transmission lol but here it's more something like "dark or light" at "slow rate".
                                    in case you have parts in stock and want to play, you still can use 3,4 resistors, cheap bs250 mosfet and photoresistor, very easy to use. My files are now uploaded at openhardware if you need https://forum.mysensors.org/topic/6430/mypulse-sensor
                                    Another nice article about photoresistor and blinking led detection i've just discovered. Looks like i've decided to use a mosfet for switching and perhaps a better digital level.., thus saving the footprint size + cost of the potentiometer.
                                    http://jeelabs.org/2012/03/18/detecting-a-blinking-led/
                                    • scalzS scalz
                                      @Samuel235
                                      Samuel235
                                      @scalz - I made it with a comparator for two main reasons:
                                      1. I wasn't sure how much the frequency fluctuated from country to country and instead of spending days on end doing research for that, I just chose to go safe rather than sorry.
                                      2. If there is another application that we're not thinking of that would take advantage of a fast/high frequency light detector, this would fit perfectly.
                                      Thanks for uploading the files, will check them out today, although i pretty much have mine done now, just not got the design penalised onto the PCB to get 4 out of the 50x50 prototype order.
                                      I will get it made at University to test the board too.
                                      MySensors 2.1.1
                                        mwalker
                                        @scalz the jeelabs post is interesting. When I was using an LM393 module with a LDR I was unable to detect the pulses coming from my meter (later established as 15ms). Reading that article it seems that was because of inadequate light proofing (the meter is shaded, but outdoors), but lacking any sort of test equipment, it's interesting to see his oscilloscope tracings of the response of the LDR to a pulse. Thanks for linking it.
                                        • F
                                          F
                                          fabiancrg
                                          I have a Smappee energy monitor, it's connected to the main input and "detect" the different equipments. It's good to monitor the overall energy consumption and production if you have solar pannels but it's not able to detect everything.
                                          In summary, it can tell you the consumption of anything with a resistor (electric oven, motor, cofee machine) or a motor (roller shutter, pump,...) but for electronic, PC and other things for which the power consumption is not regular it won't help you much. For this, I think monitoring individual component will be the best.
                                          But as you probably plus a pwoer meter on each plug, maybe a combintation of both will be a good choice.
