  3. [SOLVED] Pro Mini 3.3v with DS18B20 sensor getting (-)127 Celsius!
6 Posts 2 Posters 7.6k Views 2 Watching
  • G
    G
    gogopotato
    I hooked up DS18B20 to Pro Mini 3.3v using Vcc (3.3v). But the temp reading is constant at -127 degree Celsius. Below is my wiring with 4k7 Ohm resistor across data and vcc. I did some googling and some say -127 C reading means incorrect wiring. Is my wiring wrong?
    AWIA 1 Reply Last reply
    • G gogopotato
      AWIA
      AWIA
      AWI
      @gogopotato the - 127 can either mean that your sensor is not working or is read in the wrong way. Which sketch are you using? (the connections look ok)
      G 1 Reply Last reply
      • AWIA AWI
        G
        G
        gogopotato
        @AWI I'm using the example provided in https://www.mysensors.org/build/temp
        The above statement is returning zero. So perhaps I have a faulty/dead sensor? I should have tested the sensor before soldering it in...
        • G gogopotato
          AWIA
          AWIA
          AWI
          wrote on last edited by AWI
          @gogopotato The DS18B20 is a pretty solid device, but there is a chance that it's broken. Re-check your wiring and measure the resistor before breaking anything.
          G 2 Replies Last reply
          • AWIA AWI
            G
            G
            gogopotato
            @AWI I will try that. Thanks!
            • AWIA AWI
              G
              G
              gogopotato
              wrote on last edited by gogopotato
              @AWI Turns out, I was using 47k resistor instead of 4.7k resistor. Now it's working with no issue :)
