  3. Low power battery Door/Window sketch nrf24l01
21 Posts 7 Posters 12.3k Views 5 Watching
  • M mortommy
    I want also to specify that my sensor was running under library 1.5.4. At the moment I'm experiencing an issue under the library 2.1.1 that makes the sensor continuously wake up, so the battery discharges itself after few hours. Better under library 2.0.0 but the initialization process has many transmissions failure that give to the battery a heavy blow.
    warmaniacW
    warmaniacW
    warmaniac
    wrote on last edited by warmaniac
    #21
    @mortommy
    YES !!! That's it !!! But it is fatal error , because i use step up booster and when battery goes down , It caused that arduino start / shutdown quickly , it spams my Gateway I must disconnect it .
