  3. Vera Plus and ESP8266
23 Posts 5 Posters 8.3k Views 5 Watching
  • mntlvrM Offline
    mntlvrM Offline
    mntlvr
    How did you get Vera to install the non FTDI chip?
    D 1 Reply Last reply
    • mntlvrM mntlvr
      @mntlvr The Vera controllers have a list of supported serial devices. If you look at this page under USB Serial Devices, looking at the chipset column you will see that the FTDI and PL2303 chipsets are the only ones that Vera natively supports. For the 2303 chipsets, some say that they don't work, and others say that manual configuration is needed. Mine luckily just worked with no extra configuration. That list was last modified in 2013 though, so what is supported/works and what doesn't most likely has changed since then.
      • mntlvrM Offline
        mntlvrM Offline
        mntlvr
        Okay thanks
        Well I built a Ethernet board using 1.4.1 library and a W5100 Ethernet board and it worked right off so now I am as curious as heck to make the ESP 8266 work but I still think it has something to do with the newest library. I think I will start out with the Arduino IDE 1.6.4 or something like that and see if that makes a difference. Not very many on this site can help with the issue because they do not have Vera Controllers, so I have to figure this out and just keep trying
