  3. Molgan and Emengency Light
9 Posts 2 Posters 3.1k Views 2 Watching
    markcame
    I started play with an ikea molgan to make a a motion sensor for domoticz I want also have the possibility to use the onboard led as emergency light in case of black out so i've started with the standard motion sensor sketch trying to add the funcionality but i encountred some problems.
    Basically what i want is
    Normal state (motion sensor)
    Emergency light triggered on and off by pir (if at first motion triggering if cannot contact the gateway or if in domoticz a switch status is on )
    for the hardware i've connected che gate control to a digital i/o of arduino, but for the software i sill have problem.
    Sometimes the status is not correctly recived from controller in an acceptable time and i didn't have at the moment an efficient method to know if the gateway is alive.
    any suggest ?
    here the sketch used
     * Version 1.0 - Henrik Ekblad
     * Motion Sensor example using HC-SR501
     * http://www.mysensors.org/build/motion
    // Enable debug prints
    //#define MY_SIGNING_SOFT //Enable software Signing
    //#define MY_SIGNING_REQUEST_SIGNATURES //Enable signature on gateway
    //#define MY_SIGNING_SOFT_RANDOMSEED_PIN 7 //Randomize pin leave unconnected
    #define SENSOR_SLEEP_TIME_MS (24UL*60UL*60UL*1000UL) // Sleep time between reports (in milliseconds)
    #define CHILD_ID 1   // Id of motion sensor child
    #define DIGITAL_OUTPUT_LED 4 //Digital Output driving led mosfet
    #define LED_CHILD_ID 2 // Id of motion sensor child
    // define values for the battery measurement
    #define R1  1e6
    #define R2  470e3
    #define VMIN  3.5
    #define VMAX  4.5
    #define ADC_PRECISION  1024
    #define VREF 3.306
    int oldBatteryPcnt = 0;
    bool ledstatus = 0;
    bool response =0;
    bool tripped =0;
    // Initialize motion message
    MyMessage led(LED_CHILD_ID,V_TEXT);
        // use the 3.3 V  reference
        analogReference(DEFAULT);
        pinMode(DIGITAL_OUTPUT_LED, OUTPUT);
        digitalWrite(DIGITAL_OUTPUT_LED, 0);
        send(led.set(0));
        sendSketchInfo("Motion Sensor and EMO Light", "1.0");
        present(CHILD_ID, S_MOTION, "Motion Molgan ",true);
        wait(500);
        present(LED_CHILD_ID, S_INFO, "LED Molgan ",true);
        // Read digital motion value
        tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
        Serial.print("Motion State:");
        Serial.println(tripped);
        send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
        request(LED_CHILD_ID, V_TEXT);
        response=wait(5000, 2, V_TEXT);
        Serial.print("Controller Response:");
        Serial.println(response);
        int batteryPcnt=getBatteryPercentage();
            // Power up radio after sleep
            oldBatteryPcnt = batteryPcnt;
        // Sleep until interrupt comes in on motion sensor if gateway is responsive othervise prevent to sleep adn turn on led
        //if (response==1)
        Serial.print("Going to sleep");
        sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SENSOR_SLEEP_TIME_MS);
        //return;
        //else
        //          if (response==0){
        //          digitalWrite(DIGITAL_OUTPUT_LED, 1);
        //      return;
        if (message.type==V_TEXT) {
            // Change led state
            ledstatus=message.getBool();
            //tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
            if (ledstatus==1){
            digitalWrite(DIGITAL_OUTPUT_LED, tripped);
            else {
                    if(ledstatus==0)
            // Write some debug info
            Serial.print(message.sensor);
            Serial.println(ledstatus);
    int getBatteryPercentage() {
      // read analog pin value
      int inputValue = analogRead(BATTERY_SENSE_PIN);
      // calculate the max possible value and therefore the range and steps
      float voltageDividerFactor = 3.225622776;
      float maxValue = voltageDividerFactor * VREF;
      float voltsPerBit = maxValue / ADC_PRECISION;
      int batteryVoltage = (voltsPerBit * inputValue)*1000;
      Serial.print("Battery Voltage:");
      Serial.println(batteryVoltage);
      //int batteryPercentage = ((batteryVoltage-VMIN)/(VMAX-VMIN))*100;
      int batteryPercentage = min(map(batteryVoltage, 3500, 4500, 0, 100),100);
      Serial.print("Battery Percentage:");
      Serial.println(batteryPercentage);
      return batteryPercentage;
    AWIA 1 Reply Last reply
    • M markcame
      any suggest ?
      #define R1  1e6
      #define R2  470e3
      #define VMIN  3.5
      #define VMAX  4.5
      #define VREF 3.306
      bool ledstatus = 0;
      bool response =0;
      bool tripped =0;
          send(led.set(0));
          wait(500);
          //if (response==1)
          //return;
          //else
          //      return;
              // Change led state
              if (ledstatus==1){
              else {
                      if(ledstatus==0)
      AWIA
      AWIA
      AWI
      wrote on last edited by AWI
      @markcame I'm doing a similar thing with @Yveaux 's Molgan-Hack board. Interesting to see that you are using the wait() function in the extended version response=wait(5000, 2, V_TEXT); I never noticed that it existed :blush:
      A few remarks:
      • Domoticz can handle requests for (light)V_STATUS which fits the purpose better (and is more efficient)
      • Using the extend version of wait the second parameter cmd should be the MySensors command type set (value = = 1) as the node will be receiving a set from the controller. You better use the constant name C_SET
        although not mentioned in the API (yet). In MyMessage.h :
      /// @brief The command field (message-type) defines the overall properties of a message
      typedef enum {
      	C_PRESENTATION			= 0,	//!< Sent by a node when they present attached sensors. This is usually done in presentation() at startup.
      	C_SET					= 1,	//!< This message is sent from or to a sensor when a sensor value should be updated.
      	C_REQ					= 2,	//!< Requests a variable value (usually from an actuator destined for controller).
      	C_INTERNAL				= 3,	//!< Internal MySensors messages (also include common messages provided/generated by the library).
      	C_STREAM				= 4		//!< For firmware and other larger chunks of data that need to be divided into pieces.
      } mysensor_command;
        markcame
        Ok i will try with the modification suggested.
        I have at the moment some comunication problems with th radio so i've rewired my ESP8266 gateway and adding some capacitors.
        what type use S-BINARY , i have had some problems retriving the status from domoticz , i don't know if it is related to the lastest beta...
          markcame
          I've tryed everything but seems that the request does not return a value, seems that domoticz does not expose the value but only send status update at the moment of the switch, request on V_VAR1... ecc. ec... instead always works but they are not exposed to the user...
          • M markcame
            AWIA
            AWIA
            AWI
            @markcame can you please post your sketch showing the request?
            M 1 Reply Last reply
            • AWIA AWI
              markcame
              wrote on last edited by markcame
              @AWI
              Sketch
              #define VOLTAGE_CHILD_ID 3
              #define R1  1e6
              #define R2  470e3
              #define VMIN  3.5
              #define VMAX  4.5
              #define VREF 3.3
              int oldBatteryPcnt = 200;
              bool ledstatus = 0;
              bool response =0;
              bool tripped =0;
              float batteryvoltreport=0;
              MyMessage led(LED_CHILD_ID,V_STATUS);
              MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);
                  send(led.set(0));
                  wait(500);
                  present(LED_CHILD_ID, S_BINARY, "LED Molgan ",true);
                  wait(500);
                  present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery level" );
                  request(LED_CHILD_ID, V_STATUS);
                  response=wait(5000, C_SET, V_STATUS);
                      if (batteryPcnt < oldBatteryPcnt  ) {
                      send(voltageMsg.set(batteryvoltreport,2)); //send battery in Volt 2 decimal places
                  //if (response==1)
                  //Serial.print("Going to sleep");
                  //return;
                  //else
                  //      return;
                  if (message.type==V_STATUS) {
                      // Change led state
                      if (ledstatus==1){
                      else {
                              if(ledstatus==0)
                batteryvoltreport=(voltsPerBit * inputValue);
                //Serial.print("Battery Voltage:");
                //Serial.println(batteryVoltage);
                //Serial.print("Battery Percentage:");
                //Serial.println(batteryPercentage);
              Serial Debug
              4242 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              4371 TSF:MSG:READ,0-0-6,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              4378 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
              4386 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              5599 TSF:MSG:READ,0-0-6,s=255,c=3,t=6,pt=0,l=1,sg=0:M
              5609 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=25,sg=0,ft=0,st=OK:Motion Sensor and EMO Lig
              5619 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
              5628 TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=1,pt=0,l=14,sg=0,ft=0,st=OK:Motion Molgan
              5946 TSF:MSG:READ,0-0-6,s=1,c=0,t=1,pt=0,l=14,sg=0:Motion Molgan
              5951 TSF:MSG:ACK
              6140 TSF:MSG:SEND,6-6-0-0,s=2,c=0,t=3,pt=0,l=11,sg=0,ft=0,st=OK:LED Molgan
              6246 TSF:MSG:READ,0-0-6,s=2,c=0,t=3,pt=0,l=11,sg=0:LED Molgan
              6252 TSF:MSG:ACK
              6652 TSF:MSG:SEND,6-6-0-0,s=3,c=0,t=30,pt=0,l=13,sg=0,ft=0,st=OK:Battery level
              6660 MCO:REG:REQ
              6666 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              6804 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
              6808 MCO:PIM:NODE REG=1
              6811 MCO:BGN:STP
              6814 TSF:MSG:SEND,6-6-0-0,s=2,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
              6820 MCO:BGN:INIT OK,TSP=1
              Motion State:0
              6824 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
              6865 !TSF:MSG:SEND,6-6-0-0,s=2,c=2,t=2,pt=0,l=0,sg=0,ft=0,st=NACK:
              Controller Response:0
              11874 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=1,st=OK:100
              11891 TSF:MSG:SEND,6-6-0-0,s=3,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=OK:4.88
              11897 MCO:SLP:MS=86400000,SMS=0,I1=1,M1=1,I2=255,M2=255
              11902 MCO:SLP:TPD
              11905 MCO:SLP:WUP=1
              Motion State:1
              11909 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
              11916 TSF:MSG:SEND,6-6-0-0,s=2,c=2,t=2,pt=0,l=0,sg=0,ft=0,st=OK:
              16922 MCO:SLP:MS=86400000,SMS=0,I1=1,M1=1,I2=255,M2=255
              16928 MCO:SLP:TPD
              16930 MCO:SLP:WUP=1
              Motion State:0
              16936 TSF:MSG:SEND,6-6-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
              16944 TSF:MSG:SEND,6-6-0-0,s=2,c=2,t=2,pt=0,l=0,sg=0,ft=0,st=OK:
              21950 MCO:SLP:MS=86400000,SMS=0,I1=1,M1=1,I2=255,M2=255
              21956 MCO:SLP:TPD```
              Gateway
              0;255;0;0;18;2.1.1
              0;255;3;0;2;2.1.1
              0;255;3;0;22;188673920
              0;255;3;0;22;188683854
              6;255;0;0;17;2.1.1
              6;255;3;0;6;0
              6;255;3;0;11;Motion Sensor and EMO Lig
              6;255;3;0;12;1.0
              6;1;0;0;1;Motion Molgan
              6;2;0;0;3;LED Molgan
              6;3;0;0;30;Battery level
              6;2;1;0;2;0
              6;1;1;0;16;0
              6;2;2;0;2;
              0;255;3;0;22;188693888
              6;255;3;0;0;100
              6;3;1;0;38;4.88
              0;255;3;0;22;188703923
              6;1;1;0;16;1
              6;2;2;0;2;
              6;1;1;0;16;0
              6;2;2;0;2;
              • M markcame
                @AWI
                Sketch
                #define R1  1e6
                #define R2  470e3
                #define VMIN  3.5
                #define VMAX  4.5
                #define VREF 3.3
                bool ledstatus = 0;
                bool response =0;
                bool tripped =0;
                    send(led.set(0));
                    wait(500);
                    wait(500);
                    //if (response==1)
                    //return;
                    //else
                    //      return;
                        // Change led state
                        if (ledstatus==1){
                        else {
                                if(ledstatus==0)
                Serial Debug
                5951 TSF:MSG:ACK
                6252 TSF:MSG:ACK
                6660 MCO:REG:REQ
                6811 MCO:BGN:STP
                Motion State:0
                11902 MCO:SLP:TPD
                11905 MCO:SLP:WUP=1
                Motion State:1
                16928 MCO:SLP:TPD
                16930 MCO:SLP:WUP=1
                Motion State:0
                Gateway
                0;255;0;0;18;2.1.1
                0;255;3;0;2;2.1.1
                6;255;0;0;17;2.1.1
                6;255;3;0;6;0
                6;255;3;0;12;1.0
                6;2;1;0;2;0
                6;1;1;0;16;0
                6;2;2;0;2;
                6;255;3;0;0;100
                6;3;1;0;38;4.88
                6;1;1;0;16;1
                6;2;2;0;2;
                6;1;1;0;16;0
                6;2;2;0;2;
                AWIA
                AWIA
                AWI
                @markcame apart from that there is some variable type mixing (bool, int, ) the sketch looks fine. Domoticz returns values for: V_STATUS, V_PERCENTAGE, V_RGB(W), V_VARx and V_TEXT (see code snippet below (github))
                You can try to have the sensor re-create in Domoticz with a fixed node Id. Experimenting could have caused Domoticz to mess up the database.
                 if (message_type == MT_Req)
                		//Request a variable
                		std::string tmpstr;
                		switch (sub_type)
                		case V_STATUS:
                		case V_PERCENTAGE:
                		case V_RGB:
                		case V_RGBW:
                			if (GetSwitchValue(node_id, child_sensor_id, sub_type, tmpstr))
                				SendNodeCommand(node_id, child_sensor_id, message_type, sub_type, tmpstr);
                			break;
                		case V_VAR1:
                		case V_VAR2:
                		case V_VAR3:
                		case V_VAR4:
                		case V_VAR5:
                			//send back a previous stored custom variable
                			tmpstr = "";
                			GetVar(node_id, child_sensor_id, sub_type, tmpstr);
                			//SendNodeSetCommand(node_id, child_sensor_id, message_type, (_eSetType)sub_type, tmpstr, true, 1000);
                			break;
                		case V_TEXT:
                				//Get Text sensor value from the database
                				bool bExits = false;
                				tmpstr = GetTextSensorText(node_id, child_sensor_id, bExits);
                			break;
                		default:
                			while (1==0);
                			break;
                		while (1==0);
                  markcame
                  Ok, how can assign a fixed id ?
                  • M markcame
                    AWIA
                    AWIA
                    AWI
                    @markcame #define MY_NODE_ID xxx in the start of your sketch
