  3. Randomness
Randomness
12 Posts 2 Posters 3.8k Views 2 Watching
  • d00616D
    d00616D
    d00616
    wrote on last edited by d00616
    I have modified the way how random numbers handled for signing. With the original version of MySensors, Nonce data for signing generated from the internal pseudo random generator and the millis() time.
    My change replaces the way random numbers are generated with MySensors.
    The AVR platform uses a 32 Bit random seed build from a floating analog pin. The way of the generation of this seed is FIPS 140-2 compliant.
    For support MCU with a fast way to generate random data, the hwGetentropy() command is now available to allow rapid generation of random data.
    The ESP8266 platform uses the internal random source for randomness for hwGetentropy() and Arduino's random() function.
    The NRF5 platform initializes the pseudo random number generator from internal hardware number generator. The internal AES-ECB unit generates random data after filling with HWRNG data.
    On Linux getrandom() is implemented via syscall().
    signerAtsha204SoftGetNonce speed:
    AVR = ~14000us (sha204Soft)
    NRF51 = ~152us (AES), 1739us (sha204Soft)
    NRF52 = ~31us (AES), 183us (sha204Soft)
    ESP8266 = ~20us (RANDOM_REG32), 380us (sha204Soft)
    Linux = untested!
    All Nonce results tested for FIPS 140-2 compliance successfully.
    I have no Raspberry Pi to check my change. It would by helpful if someone can install my version on a Raspberry Pi.
    The code can be found at https://github.com/d00616/MySensors/tree/add_random_abstraction
    • d00616D d00616
      Linux = untested!
      @d00616 very nice! I can try on a rpi. What do I need to do to test, besides checking out your branch?
      d00616D 1 Reply Last reply
        d00616D
        d00616D
        d00616
        @mfalkvidd
        @mfalkvidd said in Randomness:
        @mfalkvidd Thank you. Checkout and build should be enough.
        I have measured the performance with this sketch, but this doesn't work on the Raspberry. By removing the "#define MY_HW_HAS_GETRANDOM", you can switch between old an new mode.
        #include <stdint.h>
        #include <pins_arduino.h>
        //#define MY_DEBUG
        //#define MY_DEBUG_VERBOSE_SIGNING
        //#define MY_RADIO_NRF24
        //#define MY_RADIO_NRF5_ESB
        #define MY_SIGNING_SOFT
        //#define MY_SIGNING_ATSHA204
        //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}}
        #ifndef MY_SIGNING_SOFT_RANDOMSEED_PIN
        #define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
        #ifndef MY_SIGNING_ATSHA204_PIN
        #define MY_SIGNING_ATSHA204_PIN 17
        // Enable serial gateway
        #define MY_GATEWAY_SERIAL
         MyMessage data;
         Serial.print("signerAtsha204SoftGetNonce=");
         unsigned long start = micros();
         signerAtsha204SoftGetNonce(data);
         char *c = (char *)data.getCustom();
         Serial.println(micros()-start);
          delay(1000);
        • d00616D d00616
          @mfalkvidd
          #include <stdint.h>
          //#define MY_DEBUG
           MyMessage data;
            delay(1000);
          @d00616 Sorry, seems like I am in over my head here.
          Do I need to run configure? If so, with which parameters? Then, do I run make? I tried this:
          pi@raspberrypi ~/d00616/MySensors $ ./configure --my-gateway=ethernet --my-transport=nrf24 --my-rf24-irq-pin=15 --my-rf24-channel=119
          [SECTION] Detecting target machine.
            [OK] machine detected: SoC=BCM2836, Type=rpi2, CPU=armv7l.
          [SECTION] Detecting SPI driver.
            [OK] SPI driver detected:BCM.
          [SECTION] Detecting init system.
            [OK] init system detected: sysvinit.
          [SECTION] Saving configuration.
          [SECTION] Cleaning previous builds.
          [OK] Finished.
          pi@raspberrypi ~/d00616/MySensors $ make
          gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi2\" -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/log.c -o build/drivers/Linux/log.o
          g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv7-a -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DRPI_TYPE=\"rpi2\" -DMY_RF24_CHANNEL=119 -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
          cc1plus: error: bad value (cortex-a7) for -mtune switch
          Makefile:98: recipe for target 'build/drivers/Linux/IPAddress.o' failed
          make: *** [build/drivers/Linux/IPAddress.o] Error 1
          Or do I just compile the sketch? If so, how do I do that?
            [OK] Finished.
            d00616D
            d00616D
            d00616
            @mfalkvidd It requires the option "--my-signing=software --my-signing-request-signatures". But i don't know if it is all.
            • d00616D d00616
              Sorry @d00616, seems like compiling is too hard for me. I am not able to get past the IPAddress.o error. I get the same problem when compiling against vanilla MySensors master so it's not your fault ;-)
                d00616D
                d00616D
                d00616
                Thank you.
                • d00616D d00616
                  Thank you.
                  @d00616 I got a bit further by upgrading from gcc 4.6 to gcc 4.7 (and same for g++). Instructions here: http://helloraspberrypi.blogspot.se/2014/06/install-gcc-47-on-raspberry-pi-and-set.html
                  Now I can compile MySensors master, but not MySensors development. I'll create a separate thread for this.
                    @d00616 your branch compiles with the following settings on Raspberry Pi, if I revert 4c31e2 (see the other thread)
                    ./configure --my-transport=nrf24 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensors2Gateway --spi-driver=BCM --my-signing=software --my-signing-request-signatures
                    I don't have any signing nodes and I don't know how to run the test sketch though.
                    d00616D 2 Replies Last reply
                      d00616D
                      d00616D
                      d00616
                      Thank you.
                        d00616D
                        d00616D
                        d00616
                        @mfalkvidd With "./configure --my-transport=nrf24 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensors2Gateway --spi-driver=SPIDEV --my-signing=software --my-signing-request-signatures" I can compile on my x86 machine.
                        Now, I can write some code to check the generated random data.
                        • d00616D
                          d00616D
                          d00616
                          I have checked the hwGetentropy() on my x86 Linux. When https://github.com/mysensors/MySensors/pull/830 is merged, I create a new Pull Request.
