  3. NewBee: Auto ID Problem / !TSM:ID:FAIL
4 Posts 2 Posters 1.5k Views 2 Watching
  • S
    Severin
    Hi All,
    first of all thank's to everybody who put so much work into MySensors.
    I'm new to MySensors and only recently started with HomeAutomation.
    I have a Raspberry 3 running Openhabian and already got ZWAVE and Philips Hue up and running doing stuff with Motion detection, Lights and Wallplugs. So far so good.
    Now I want to expand to MySensors in order to build my own Arduino based sensors and actuators.
    I've wired one NRF24L01+ Module directly to my Raspberry following this great Guide by Marcelo.
    The GW connects to a Mosquitto MQTT Server running on the same Raspberry and seems to work correctly:
     ./mysgw -d
    mysgw: Starting gateway...
    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: Attempting MQTT connection...
    mysgw: connected to 127.0.0.1
    mysgw: MQTT connected
    I also have my first Motion Detection Sensor wired up with an Uno R3 and the same NRF24L01+ Modul.
    I use the unmodified Sketch from Henrik Ekblad
    Both NRF24L01+ Modules are pimed with an capacitor.
    But what I gather from the node logs it seems to be stuck at requesting an ID
    Node:
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:FPAR
    15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    897 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    902 TSF:MSG:FPAR OK,ID=0,D=1
    2022 TSM:FPAR:OK
    2023 TSM:ID
    2024 TSM:ID:REQ
    2027 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    4034 TSM:ID
    4035 TSM:ID:REQ
    4037 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    6045 TSM:ID
    6046 TSM:ID:REQ
    6048 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    8056 TSM:ID
    8057 TSM:ID:REQ
    8059 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    10068 !TSM:ID:FAIL
    10070 TSM:FAIL:CNT=1
    10072 TSM:FAIL:PDT
    Gateway:
     ./mysgw -d
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: MCO:BGN:STP
    mysgw: Sending message on topic: mysensors-out/0/255/0/0/18
    mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:FPAR REQ,ID=255
    mysgw: TSF:PNG:SEND,TO=0
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:GWL OK
    mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
    mysgw: Sending message on topic: mysensors-out/255/255/3/0/3
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK
    I've tried adding:
    #define MY_NODE_ID 1
    Unfortunately that does not affect the Output.
    I've also cleared the eeprom several times with the MySensors ClearEepromConfig Sketch, but also to no effect.
    Communication between Gateway and Node seems to work (as I judge from the logs, since Parent Node ID is exchanged)
    But Client Node does not get through with ID Request: !TSM:ID:FAIL
    Would be glad to receive a hint or advice.
    Thank you
    Severin
    • S Severin
      Hi All,
       ./mysgw -d
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: MCO:BGN:STP
      Node:
      3 TSM:INIT
      4 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      13 TSM:FPAR
      2022 TSM:FPAR:OK
      2023 TSM:ID
      2024 TSM:ID:REQ
      4034 TSM:ID
      4035 TSM:ID:REQ
      6045 TSM:ID
      6046 TSM:ID:REQ
      8056 TSM:ID
      8057 TSM:ID:REQ
      10068 !TSM:ID:FAIL
      10072 TSM:FAIL:PDT
      Gateway:
       ./mysgw -d
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: MCO:BGN:STP
      mysgw: TSF:MSG:BC
      mysgw: TSF:CKU:OK
      mysgw: TSF:MSG:BC
      mysgw: TSF:CKU:OK
      I've tried adding:
      Thank you
      Severin
      Welcoem to the MySensors community @Severin!
      Did you add
      before including MySensors.h?
      • S
        Severin
        Dear Mikael,
        nop didn't.
        Moving it before the include fixed it ;)
        Thank you very much for your quick reply
        Sensor now works like a charm.
        • S Severin
          Dear Mikael,
          nop didn't.
          @Severin great! Thanks for reporting back.
