  3. Node reboot issue
Node reboot issue
17 Posts 3 Posters 5.7k Views 3 Watching
  • S
    slt1
    If I try to reboot a node, from either MySController or MyController, the node hangs. Once it hangs from the reboot command, manually pressing the reset button on the Arduino Pro mini will not restart the arduino. It only starts again if power is removed and then added again.
    I have the same issue using both the standard arduino bootloader and with MySBootloader.
    Can anyone guide me to what may cause this?
      What Ide version and avr boards definitions are you using?
      • S
        slt1
        Arduino IDE : 1.8.2
        For standard installed bootloader : Arduino Pro or Pro Mini with Atmega328 (5V, 16Mhz)
        For MySBootloader : MySBootloader AtMega328 external 16Mhz
          You may try to use older or newer avr boards definitions
          • S
            slt1
            If by "board definitions" you mean the detail in the boards.txt file - here is what I have for Arduino Pro Mini / 5V 16Mhz ...
            pro.name=Arduino Pro or Pro Mini
            pro.upload.tool=avrdude
            pro.upload.protocol=arduino
            pro.bootloader.tool=avrdude
            pro.bootloader.unlock_bits=0x3F
            pro.bootloader.lock_bits=0x0F
            pro.build.board=AVR_PRO
            pro.build.core=arduino
            pro.build.variant=eightanaloginputs
            Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega328
            pro.menu.cpu.16MHzatmega328=ATmega328 (5V, 16 MHz)
            pro.menu.cpu.16MHzatmega328.upload.maximum_size=30720
            pro.menu.cpu.16MHzatmega328.upload.maximum_data_size=2048
            pro.menu.cpu.16MHzatmega328.upload.speed=57600
            pro.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
            pro.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
            pro.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0xFD
            pro.menu.cpu.16MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
            pro.menu.cpu.16MHzatmega328.build.mcu=atmega328p
            pro.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
            I have updated Arduino IDE o 1.8.2 recently which I guess that also updated the boards.txt file. Both the previous version and the latest version of Arduino have the same reboot issue.
            • S
              slt1
              One more thing that may be helpful ... when the node "hangs" the status LED is blinking rapidly.
              • S
                slt1
                After some looking around i found this ..
                https://arduino.stackexchange.com/questions/2922/watchdog-timer-stuck-in-restart-loop-green-led-flashing
                I flashed Optiboot bootloader and that worked.
                I flashed MYSBootloader again and now it does work - I am fairly certain this bootloader was causing the issue before ?!? Oh well - it works now !
                I flashed with Arduino Pro Mini 5V 16Mhz and that caused the reset hang
                So it seems to be an issue with the default Arduino Pro Mini bootloader that comes with Arduino IDE.
                Hope this helps anyone else experiencing same issue.
                • maghacM
                  maghacM
                  maghac
                  I have exactly the same problem, although I actually have the MYSBootloader installed.
                  This is also a 5V pro mini.
                  I'll check my boards.txt file later, maybe I have incorrect settings that don't work with 5V 16 Mhz units.
                  • S
                    slt1
                    @maghac I was still having issues with MYSBootloader. This was using the version bundled with MYSController - in a folder called "MYSController_1_0_0beta".
                    I found one on github here https://github.com/mysensors/MySensorsBootloaderRF24
                    It seems to be a newer version.
                    I downloaded that one and setup the 16MHz from their boards.txt file and so far this seems to work.
                    maghacM 1 Reply Last reply
                    • S slt1
                      maghacM
                      maghacM
                      maghac
                      wrote on last edited by maghac
                      @slt1 Thanks for the tip - I grabbed the files from the development branch - was that the one you were using? I found three versions of the .hex file - 1Mhz, 8Mhz and 16 Mhz.
                      Now I am unable to upload a sketch after flashing the MYSBootloader. It only works if I go back to the normal Pro Mino bootloader.
                      S 1 Reply Last reply
                      • S
                        slt1
                        @maghac
                        The previous version (bundled with MYSController) I was using would not allow me to upload sketches using FTDI cable after flashing the MYSBootloader. It also had the node reboot issue.
                        The latest dev branch from github link does allow me to now and the node reboot works too !
                        I copied all 3 hex files into a MySensors folder (C:\Program Files (x86)\Arduino\hardware\arduino\avr\bootloaders\MySensors)
                        They only had one board in the boards.txt - I only have 5V 16MHz Pro Mini's so changed link to hex file in the sample boards.txt they gave and added that to bottom of boards.txt file in Arduino install dir. boards.txt content I copied is ..
                        MYSBootloader
                        proMYSBL.name=ATmega328 16Mhz MYSBootloader
                        proMYSBL.upload.tool=avrdude
                        proMYSBL.upload.protocol=arduino
                        proMYSBL.upload.maximum_size=30720
                        proMYSBL.upload.maximum_data_size=2048
                        proMYSBL.upload.speed=115200
                        proMYSBL.bootloader.tool=avrdude
                        proMYSBL.bootloader.low_fuses=0xF7
                        proMYSBL.bootloader.high_fuses=0xDA
                        proMYSBL.bootloader.extended_fuses=0x06
                        proMYSBL.bootloader.unlock_bits=0x3F
                        proMYSBL.bootloader.lock_bits=0x0F
                        proMYSBL.bootloader.file=MySensors/MYSBootloader_16MHz.hex
                        proMYSBL.build.mcu=atmega328p
                        proMYSBL.build.f_cpu=16000000L
                        proMYSBL.build.board=AVR_UNO
                        proMYSBL.build.core=arduino
                        proMYSBL.build.variant=standard
                        • maghacM maghac
                          slt1
                          @maghac I tested a bit now again and see there is still an issue when uploading sketch using USB Asp cable. I am getting this error :
                          avrdude: Yikes! Invalid device signature.
                          Double check connections and try again, or use -F to override
                          this check.
                          However, that is non-critical for me as I only want to flash the bootloader using USB Asp cable and then I use the FTDI Cable for sketch uploads
                          • maghacM
                            maghacM
                            maghac
                            Here are my custome entries from boards.txt:
                            ## Arduino Pro or Pro Mini (3V3 & 5V, 16 MHz) w/ ATmega328 MYSBootloader
                            proMYSBL.name=ATmega328 16Mhz MYSBootloader 1.3 beta
                            proMYSBL.bootloader.extended_fuses=0xfe
                            proMYSBL.bootloader.file=MySensors/MYSBootloader.hex
                            proMYSBL16.name=ATmega328 16Mhz MYSBootloader 1.3 beta DEV
                            proMYSBL16.upload.tool=avrdude
                            proMYSBL16.upload.protocol=arduino
                            proMYSBL16.upload.maximum_size=30720
                            proMYSBL16.upload.maximum_data_size=2048
                            proMYSBL16.upload.speed=57600
                            proMYSBL16.bootloader.tool=avrdude
                            proMYSBL16.bootloader.low_fuses=0xF7
                            proMYSBL16.bootloader.high_fuses=0xDA
                            proMYSBL16.bootloader.extended_fuses=0xFD
                            proMYSBL16.bootloader.unlock_bits=0x3F
                            proMYSBL16.bootloader.lock_bits=0x0F
                            proMYSBL16.bootloader.file=MySensors/MYSBootloader_16MHz.hex
                            proMYSBL16.build.mcu=atmega328p
                            proMYSBL16.build.f_cpu=16000000L
                            proMYSBL16.build.board=AVR_UNO
                            proMYSBL16.build.core=arduino
                            proMYSBL16.build.variant=standard
                            ## Arduino Pro or Pro Mini (3V3 & 5V, 8 MHz) w/ ATmega328 MYSBootloader
                            proMYSBL8.name=ATmega328 8Mhz MYSBootloader 1.3 beta DEV
                            proMYSBL8.upload.tool=avrdude
                            proMYSBL8.upload.protocol=arduino
                            proMYSBL8.upload.maximum_size=30720
                            proMYSBL8.upload.maximum_data_size=2048
                            proMYSBL8.upload.speed=57600
                            proMYSBL8.bootloader.tool=avrdude
                            proMYSBL8.bootloader.low_fuses=0xE2
                            proMYSBL8.bootloader.high_fuses=0xD2
                            proMYSBL8.bootloader.extended_fuses=0xFE
                            proMYSBL8.bootloader.unlock_bits=0x3F
                            proMYSBL8.bootloader.lock_bits=0x3F
                            proMYSBL8.bootloader.file=MySensors/MYSBootloader_8MHz.hex
                            proMYSBL8.build.mcu=atmega328p
                            proMYSBL8.build.f_cpu=8000000L
                            proMYSBL8.build.board=AVR_UNO
                            proMYSBL8.build.core=arduino
                            proMYSBL8.build.variant=standard
                            MYSBootloader.hex is from the master branch of MYSBootloader 1.3.0-beta.3, the other two are from the development branch.
                            Doesn't matter which one I use, I can never get my 5V 16MHz boards to accept a new sketch via FTDI cable. I have to go back to the standard bootloader.
                            Just realized I should probably post this in the Wireless Programming thread instead.
                            • maghacM maghac
                              slt1
                              wrote on last edited by slt1
                              @maghac I copied and tried your settings for
                              and I get errors like this uploading via FTDI cable ...
                              avrdude: stk500_recv(): programmer is not responding
                              avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x2c
                              etc
                              If you want to try my settings then change the 16Mhz settings to this -
                              #ATmega328 16Mhz MYSBootloader 1.3 beta DEV
                              proMYSBL16.upload.speed=115200
                              proMYSBL16.bootloader.extended_fuses=0x06
                              And rem Arduino IDE needs to be closed and restarted after changes
                              • S slt1
                                etc
                                maghacM
                                maghacM
                                maghac
                                @slt1 Thanks, I'll give it a try next time. Now the node is actually mounted in a place where it's difficult to physically reach it (which is why I wanted to enable OTA updates of course).
                                The only difference between your entry and mine is the extended_fuses line, isn't it?
                                Whenever I use your settings (extended_fuses=0x06), avrdude gives me a warning and instructs me to change the value.
                                • maghacM maghac
                                  slt1
                                  @maghac In your one configured as "MYSBootloader 1.3 beta DEV" which uses the MYSBootloader_16MHz.hex there is also a difference in upload.speed.
                                  • maghacM
                                    maghacM
                                    maghac
                                    So, now I have the same problem with a 5V pro clone.
                                    With normal bootloader:
                                    • the board gets stuck in a loop with flashing LED when i try to reboot it.
                                    With MYSBootloader (1.3.0-beta.4 or 1.3.0-beta.3):
                                    • unable to upload a new sketch using the FTDI cable
                                    • node doesn't seem to get recognized properly by the GW or the controller. I see it's contiously sending "mysensors-out/10/255/4/0/0 FFFFFFFFFFFFFE400102" messages on MQTT, which I think is when it's checking for a new firmware, but nothing on the serial monitor. This makes it impossible to upload a new sketch OTA.
                                    Any ideas on how to troubleshoot?
