  3. When powered from usb, nrf24I01 is ok, from external Power not
5 Posts 3 Posters 1.9k Views 3 Watching
  • G
    G
    Grave
    I hope, you will understand my english.
    I have a sensebender micro. When I connect it only with a FTDI Programmer to watch the serial monitor, all is OK.
    But when I connect it to his power source, a LM2596S step down regulator, I get this on the serial monitor:
    0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
    4 MCO:BGN:BFR
    6 TSM:INIT
    6 TSF:WUR:MS=0
    14 TSM:INIT:TSP OK
    16 TSF:SID:OK,ID=1
    18 TSM:FPAR
    55 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2064 !TSM:FPAR:NO REPLY
    2066 TSM:FPAR
    2103 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4112 !TSM:FPAR:NO REPLY
    4114 TSM:FPAR
    4151 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6160 !TSM:FPAR:NO REPLY
    6162 TSM:FPAR
    6199 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8208 !TSM:FPAR:FAIL
    8210 TSM:FAIL:CNT=1
    8212 TSM:FAIL:PDT
    18216 TSM:FAIL:RE-INIT
    On the gateway I get this:
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;TSM:INIT:TSP OK
    0;255;3;0;9;TSM:INIT:GW MODE
    0;255;0;0;18;2.1.1
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:BC
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=1
    0;255;3;0;9;TSF:CKU:OK,FCTRL
    0;255;3;0;9;TSF:MSG:GWL OK
    0;255;3;0;9;!TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    0;255;3;0;9;MCO:REG:NOT NEEDED```
    I have tryid it with an 10uf capacitor. But still nothing.
    Thanks Grave
    • G Grave
      4 MCO:BGN:BFR
      6 TSM:INIT
      6 TSF:WUR:MS=0
      14 TSM:INIT:TSP OK
      16 TSF:SID:OK,ID=1
      18 TSM:FPAR
      2066 TSM:FPAR
      4114 TSM:FPAR
      6162 TSM:FPAR
      8208 !TSM:FPAR:FAIL
      8210 TSM:FAIL:CNT=1
      8212 TSM:FAIL:PDT
      0;255;0;0;18;2.1.1
      Thanks Grave
      Welcome to the MySensors community @Grave !
      What capacitors do you use? The datasheet suggests 220uF.
      Have a look at the power troubleshooting flowchart here if you haven't already.
      Edit: sorry, I see now that you used a 10uF capacitor.
        It looks like the gateway restarts just after receiving the fpar message. Strange. What kind of gateway are you running?
        J 1 Reply Last reply
          J
          J
          Jan Gatzke
          @mfalkvidd I bet the serial gateway. 2.1.1 is bugy. I solved this problem by upgrading to the 2.2 beta from github.
          • G
            G
            Grave
            I solved the problem. I have soldered a 1000uf capacitor to the output of the step down modul. Now everything is ok.
            I will try the beta Version.
