  3. 💬 RFM69(H)W Arduino Mini Pro Shield
rfm69arduino pro minishieldrfm69hw
27 Posts 8 Posters 12.0k Views 5 Watching
  • stevebusS
    stevebusS
    stevebus
    Thanks @jlaraujo... Definitely keep us up to date and i'll be happy to order and try it out.
    Vera Edge/UI7; mysensors; Arduino's and RPIs; data posted to Azure for an IoT 'dashboard' of my house
    Opinions expressed here are my own and do not necessarily reflect Microsoft's feelings on a given topic :-)
      If you can find the size let me know, I looked on aliexpress and none are showing what is the supported pcb size. So either it is like standard for 1.6mm pcbs or I have no idea
      @gohan - I have found both 1.6mm and 1mm on Ebay. Since i like to order 1mm thats what i went with SMA connector but it was way easier to find 1.6mm. I just mean a easy misstake would be to order a 1.6mm SMA connector and 1.0mm pcb. Might probably work.
        Since I ordered 1.6mm pcbs, I think I should be fine then.
        • 5
          556duckvader
          I really like this design as I am looking for a small for factor RFM69 shield. One question how hard would it be to integrate a connection for a DHT22 to be able to have a small temp and humidity transmitter. I need to have about 5 of these setup in different locations sending temp and humidity back to a gateway.
          J 1 Reply Last reply
            The sensor will be attached to the arduino, not to the shield
            • 5 556duckvader
              J
              J
              jlaraujo
              @556duckvader, like @gohan referred, you can attach the DHT22 to the arduino and not to the shield.
              You can make a simple PCB that will connect to the required ports for the DHT22 to operate.
              If you'd like to have an even smaller footprint, try this design:
              https://www.openhardware.io/view/615
              It is not yet tested in production, probably will be by the end of the week.
              Domoticz, mysensors 2.3.1, RFM69 and RF24 sensors
                There are also other solutions that have I2C bus pins on the shield and if you are going to make a battery powered node, I'd suggest to use an I2C sensor as it will be much more battery friendly
