  3. 💬 Effective Solar Supercap Boost Charger for Small Solar Panel
74 Posts 7 Posters 15.9k Views 8 Watching
  • N ncollins
    @neverdie at ~$1.90 per keychain, seems like a great way to get into harvesting.
    I bet it would be easy enough to design and 3d print a replacement to the button half of the housing with a little more space for a radio and sensors.
    I mean, you could probably just add an LDO, HT7333 or XC6206, and use it as is.
    NeverDieN
    NeverDieN
    #61
    @ncollins I'm curious as to why you aren't using your 3722-9L's on your solar motes?
    Is it because you're more geared to collecting sunshine instead of nighttime indoor lighting?
    Curiously enough, during the daytime (but still indoors) I found the IXYS is pumping twice the microamps as the 3722-9L So, clearly, the two boards respond to different spectra differently. The IXYS gives its "external quantum efficiency" for different wavelengths. In contrast, I haven't seen any reference to wavelength efficiency by the 3722-9L, but apparently I got lucky and it's optimized for the kind of light the LED's in my office are emitting. Regardless, the 3722-9L always has more open circuit voltage than the IXYS cell I referenced earlier.
    By the way, as an aside, I put a 10,000 uF capacitor on the "Effective Solar Supercap Boost Charger for Small Solar Panel," and now it blinks the red LED plenty bright enough to see without having shade it.
    N 1 Reply Last reply
    • NeverDieN NeverDie
      N
      N
      ncollins
      @neverdie It's mostly because I haven't figured out how to appropriately, efficiently handle the wide voltage range of the 3722s.
      In ambient light, they'd be perfect, but most locations in my house, there's a chance they'd get hit with direct sunlight. In a couple of my earlier prototypes, I fried the NRF module after the supercap exceeded 3.6v (damaged something that causes them to draw ~1-2ma).
      In my case, I don't have a lot of artificial lighting, but I do decent direct/indirect sun from windows for at least part of the day.
      Thoughts:
      • add a really efficient LDO between the 3722 and the super cap
      • Sacrifice size compact size and jump up to 5.5v supercaps. Add LDO between the supercap and mote
      • rig some kind of a pass through when vout < 3.6, else go through LDO
      I'm mostly avoiding the issue by using the SC-3517s. A single cell wasn't really cutting it unless in direct sunlight, so I double up in parallel.
      Bonus: other prototypes
      IndoorSolar
      Uses your boost charger
      Boost
      Testing out 50mF low ESR super cap
      Esr
      NeverDieN 1 Reply Last reply
      • N ncollins
        Thoughts:
        IndoorSolar
        Boost
        Esr
        NeverDieN
        NeverDieN
        #63
        @ncollins That AVX-BestCap looks like a great find. I love the compact form factor of it. Looking at the datasheet though, I worry that the self-discharge of 5-10ua might be a bit much: http://catalogs.avx.com/BestCap.pdf
        That's high enough that it might consume either all or at least much of the microamps produced by the 3722-9L (assuming just a single cell is used) when there's light available, and the leakage would continue overnight in the darkness to eat into whatever had been accumulated.
        On the other hand, the all aluminum caps at that same 50mF capacity are huge and for that reason not such a good fit either for a sensor that aspires to be compact.....
          N
          N
          ncollins
          @neverdie With all of your energy harvesting approaches, how are you handling unforeseen restarts? Almost all of my harvesting sensors have the same issue: if they drop below 1.8v (depending on BOD) they can't recover without manual intervention. Only one of my nodes has ever recovered and I think it's because the solar panel produced enough current to push through the MCU and radio startup.
          My thought was to use the MIC2778 supervisor ic (datasheet), which has programable hysteresis, and a mosfet to wait for supercap/battery to reach a voltage high enough to handle a cold start.
          • N ncollins
            NeverDieN
            NeverDieN
            @ncollins Yes, that should work. Since I disabled BOD in order to sleep at very low currents (100na for the atmega328p), I built my own in hardware using a voltage detector. So, if voltage drops below 1.8v, it cuts off the power. When it goes above the hysteresis point, it restarts.
            If you leave BOD enabled, I think it may do this work for you, and then you wouldn't need more hardware. But then your sleep current would be higher. So, it's a tradeoff as to how you want to do it.
              N
              N
              ncollins
              @neverdie yeah, the fixed hysteresis of the internal BOD (328p, NRF51) isn't wide enough to handle startup for my nodes. I'm guessing it's due to the high ESR and corresponding voltage drop of the supercaps I've been favoring.
              I also didn't realize how chatty mysensors can be during start up. My latest nodes have MY_PASSIVE_NODE enabled, skip presentation, and use dumb sleep.
              NeverDieN 3 Replies Last reply
              • N ncollins
                NeverDieN
                NeverDieN
                #67
                @ncollins I forgot to mention that I use a load switch, controlled by the voltage detector, to turn on and off the atmega328p. I don't drive it directly from the load switch. You could use two different voltage detectors to get a much wider hysteresis, or you could use a hysteresis chip for a more elegant solution. I know for sure that the voltage detectors draw a minuscule amount of current. I haven't looked into the hysteresis chips enough to know how they would compare along that dimension, but I'm guessing they would be similar.
                • N ncollins
                  NeverDieN
                  NeverDieN
                  #68
                  @ncollins Here's the load switch that I've been using: http://www.ti.com/product/TPS22860 I like it a lot. I think it, or something similar, should be in everyone's tool box.
                    N
                    N
                    ncollins
                    @neverdie said in 💬 Effective Solar Supercap Boost Charger for Small Solar Panel:
                    Awesome, I'll order a few. Appreciate the info, thanks.
                    • N ncollins
                      NeverDieN
                      NeverDieN
                      #70
                      @ncollins said in 💬 Effective Solar Supercap Boost Charger for Small Solar Panel:
                      You could either add a capacitor to get it over this hump, or you could just have the atmega328p check it's voltage level at startup. If it isn't high enough, it goes to sleep and keeps checking upon subsequent wake-up's until it's high enough to support radio transceiving without crashing below 1.8v.
                      • N ncollins
                        NeverDieN
                        NeverDieN
                        #71
                        @ncollins What I tried in the past, and which I rather liked, was to first charge up, say, a 100uF capacitor and use that to power the 328p when voltage threshhold is reached and to then also redirect the incoming solar charge current into a supercap for bulk collection That way, in a cold start scenario, the MCU powers up very quickly--nearly instantly with larger solar cells--rather than having to wait hours for a large supercap to fill up. 100uF is enough to power numerous transmissions.
                        All this comes at the cost of more circuitry though, so I can understand if someone would prefer to omit this feature to keep things simple.
                        Maybe we should start a separate thread for this kind of discussion?
                        The only downside I see to the hysteresis chips is that they consume more current, especially when you consider the amount of current consumed by the voltage divider circuit. In the case of the MIC2778, it recommends the total resistance of the voltage divider circuit be no more than 3megaOhm. At low voltages, though, I suppose that's not much of a problem. Still, for comparison, some voltage detectors might consume a mere 350na in total.
                          N
                          N
                          ncollins
                          @neverdie Yeah, I think starting a dedicated thread is the right move.
                          That sounds a lot like what I'm trying to do. Prioritize load (boot/transmission) power, then dump into a reserve. This make sense when light is strong, but when solar isn't producing, how do you get power from the reserve to the load capacitors. Would you boost it?
                          • NeverDieN
                            NeverDieN
                            Continuing the discussion on a new thread here: https://forum.mysensors.org/topic/10748/solar-energy-harvesting-for-wireless-motes
                              MarcosBe
                              Banned
                              Very interesting information, thank you very much!
