  3. 230V power supply to Arduino
67 Posts 25 Posters 78.5k Views 22 Watching
  • ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    @axillent Hello. It is an old topic but I am really interedting in your designs and want to know how stable are they after 1 year.
    I have two question please.
    • I am desiging the LNK pcb layout but I am a bit confused regarding safety. Pad size ? Trace width ? Ground plane for heat sink ? All these stuff. You mind sharing your design please ?
      Also I dont see a fuze or MOV in your design. Aren't they important ?
    • you posted above 4 circuit deaigns. regarding the final chinese cheap design, what are the advantages and disadvantages of that design. I have just saw it in a cheap LED lamp.
    Thanks.
    • diegolfD
      diegolfD
      diegolf
      @axillent
      Hello my friend! Can you share the schematic and BOM of this LNK circuit, please? I tried to follow LNK Datasheet, but is different of your Project...
      thx
      • themolochT themoloch
        @axillent said:
        if you know what you are doing it is also other choice - linkswitch chips LNK302/304/306. The last one can deliver up to 350mA not isolated power directly 5V or 3.3V. It is as efficient as isolated - unloaded it will consume about 0.2W. A bit bigger than SR036. Easy to construct because you do not need custom transformers. For example Duwi zwave wall switches are using this type of the supply. This is my one side SMD version with regulated output:
        Hello axillent, I just bought some of those LNK306 and would like to make a test board, could you share your schematic or components you used to make your own?
        Thanks a lot.
        StephanS
        StephanS
        Stephan
        Hello, I return to this topic which dates a bit.
        I am very interested in the version that uses the LNK306.
        I found this electronic diagram that uses LNK306
        Could you provide a detailed nomenclature?
        Thank you in advance.
        Best regards.
          Thanks a lot.
          crocC
          crocC
          croc
          @themoloch Hello can you please tell me which 1uf you bought? because you have them in parallel and what is the maximum Am you can get out of them. regards from croc.
          • axillentA axillent
            @scalz said:
            I have these http://fr.aliexpress.com/item/AC-220V-DC-3V-10V-5V-9V-1w-1x1w-2w-2x1w-3w-3x1w-Constant-Current-Constant/1900256299.html?recommendVersion=1
            I'm using similar one, it is also called 3 x1 W Led driver and by my measurements provides 300mA and 17V without load
            I use 220uF to filter its output and I use 78L05 to regulate down to 5V. This can give up to 5V@40mA output. The restriction is a heating desipation rating for 78L05.
            For higher loads I would recomment to use DC stepdown. With DC stepdown you can get up to 5V@650mA with 80% efficiency
            crocC
            crocC
            croc
            @axillent can you look at my early question? can you send a BOM list from your design?
            axillentA 1 Reply Last reply
            • crocC croc
              axillentA
              axillentA
              axillent
              @croc sorry to be so late in answer
              this as an application note 0_1479681329040_an37-linkswitch.pdf
              My design is equal to the schematic posted by @Stephan except an input filter. According to an37 I'm using 2uF + 1uH +2uF as input filter.
              I'm using a compact X7R 1uF x 450V purchased from aliexpress. Instead of RF1 I'm using PTFE (a resettable fuse) 40mA @ 250V
              D3 + D4 are M7
              D1 is US1J / ES1J
              C2 & C3 are also X7R
              sense and drive
              crocC 1 Reply Last reply
                D3 + D4 are M7
                D1 is US1J / ES1J
                crocC
                crocC
                croc
                @axillent thanks and what is the smd coil that you use?
