  3. 230V power supply to Arduino
67 Posts 25 Posters 78.5k Views 22 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @axillent
    500mA should also be sufficient for a sensor node, even with a couple of relays, mysensors in GW mode, etc. it's not even near the 500mA limit
    • axillentA
      axillentA
      axillent
      sure. sensornode without relays requires 15-20mA
      with SSR relay will need +10-15mA for each relay
      +50-100mA for each regular relay
      sense and drive
      • T
        Tibus
        Hello, I'm also searching a way to get 5V from AC to make a beatiful mysensor wallPlug... I'm searching the smallest and cheapest way to do it. My problem is I want to drive a regular relay (a SSR is not very good for plug and other things no?), an atmega328 tqfp, a NRF24 and some other things like a current sensor,... so, I think I need 150ma +-? (100ma for the relay, max 25-30ma for the NRF and arduino and some ma for the status leds,...)
        I found here the SR086 but I don't know if I could take 150ma on it.
        What is the best way for my projet?
        I also found these one but don't know if it ok too :
        http://www.newark.com/vigortronix/vtx-214-001-105/ac-dc-conv-fixed-1-o-p-1w-5v/dp/45X5484?ost=VTX-214-001-105
        I'm searchin the smallest way because i also would like to make a in wall module for interuptor,... so the VTX above is ok for a wallplug but a bit big for a in wall module... How the cubino for exemple make a DC module so small?
        axillentA 1 Reply Last reply
        • T Tibus
          axillentA
          axillentA
          axillent
          @Tibus your selection is fine. Any one above is also fine
          what is you worry?
          sense and drive
          • T
            Tibus
            @axillent My worry is taking 150ma out of a SR086? Is the SR086 ok to give 150ma?
            The VTX is ok but big for an inwall module so is there a good way to get 150ma in 5V from 220VAC in the smallest form factor possible? (or in less than 1cm height?)
            I also found these one but a SR086 would be fine for a inwall relay... (but 150ma?)
            http://fr.rs-online.com/web/p/alimentations-a-decoupage-integrables/7719379/
            • T Tibus
              axillentA
              axillentA
              axillent
              wrote on last edited by axillent
              #26
              @Tibus SR086 able to provide 100mA from 9-50V. For example you can set it to provide 20V and add DC-DC step-down for example based on MP2359. This will give you current-UP benefit at 5V etc. 20V@100mA will give you 5V@360mA maximum with 90% efficiency
              My preference in your case LNK306, you can get directly up to 350mA. Using ceramic capacitors and SMD inductors you will fit in 7-10mm height (see one of my picture above)
              And at last. Why not SSR? What type of the load do you have?
              sense and drive
              • T
                Tibus
                @axillent Thank's verry much. I didn't know the current up benefit of a step-down. I think it's the key of my problem!
                I'll test the lnk306. Hope It will work for my project.
                For my "in wall module", it's just lights so no problem for an SSR. But for the wall plug, The user chose the load they want... so if it's a TV or a washing machine or a power supply, I read an SSR is not verry good for these things...
                • T Tibus
                  axillentA
                  axillentA
                  axillent
                  @Tibus YAW
                  For LNK take a look for AN37, especially optimization at table 9
                  an37-linkswitch.pdf
                  SSR is fine for most of the loads. But you need to follow recommendation of their use and to control limitations (like maximum ratings and heat dissipation)
                  sense and drive
                  • axillentA
                    axillentA
                    axillent
                    I'm expecting to receive my SR086 and SR10 this week
                    I have a plan to run some tests
                    sense and drive
                    • klimK
                      klimK
                      klim
                      Regarding the SR10 i've already here a few, but just no time to build up something ;-(
                      The more i'm curious for your results.
                      • klimK klim
                        axillentA
                        axillentA
                        axillent
                        #31
                        @klim I made a test PCB
                        I succeed to get about 34mA with 1uF capacitor and probably it will provide 40mA stated in the datasheet
                        it is not possible to use it directly without an additional LDO or step-down because of a very high ripple.
                        According to my measurement ripple is 2.8V with 12.6V average output (figures in table should be multiplied by 10):
                        consumed power from AC is 0.8 W with 36mA output
                        this means 57% efficiency, not bad for such thing
                        sense and drive
                        • T
                          Tibus
                          hox much current could you get with a LDO ort step-Down to 5V or 3.3V? 80ma?
                          • T Tibus
                            axillentA
                            axillentA
                            axillent
                            @Tibus the output current from SR10 is depends on the capacitor and rectifier. See the table inside the datasheet
                            with step-down I can get from my prototype about 100mA at 3.3V
                            with LDO you will get out as many as you get in minus quiescent current of LDO itself
                            sense and drive
                            • axillentA
                              axillentA
                              axillent
                              I made a success by replacing polymer capacitor by ceramic one in the usage of SR10
                              it leads to a dramatical decrease in needed space. I believe that it will be the smallest AC-DC fotprint
                              But still I have som problems with DHT sensor to work from SR10 (http://forum.mysensors.org/topic/971/small-wall-outlet-sensor-node)
                              sense and drive
                              jeylitesJ 1 Reply Last reply
                              • axillentA axillent
                                jeylitesJ
                                jeylitesJ
                                jeylites
                                @axillent
                                I like the case you are using. Where did you get it from?upload-a5807239-d1ad-499a-97c0-c24a736c0ce8.JPG
                                • jeylitesJ jeylites
                                  @axillent
                                  marceltrapmanM
                                  marceltrapmanM
                                  marceltrapman
                                  @jeylites said:
                                  @axillent
                                  It looks like it was printed.
                                  If so, are you willing to share the files?
                                  Fulltime Servoy Developer
                                  • axillentA
                                    axillentA
                                    axillent
                                    yes, all cases are printed
                                    sure, I can share if you need
                                    the case developed for a particular custom made PCB
                                    sense and drive
                                      marceltrapmanM
                                      marceltrapmanM
                                      marceltrapman
                                      I understand but the design is still a good starting point :)
                                      • marceltrapmanM marceltrapman
                                        axillentA
                                        axillentA
                                        axillent
                                        @marceltrapman sure, just give me some time to publish it on thingerverse
                                        sense and drive
                                        • marceltrapmanM
                                          marceltrapmanM
                                          marceltrapman
                                          Nice, thanks...
