  3. How to connect QUIP300 to Domoticz
31 Posts 3 Posters 8.1k Views 3 Watching
  • M Offline
    M Offline
    mckenzi
    Last question: one pin of each PIR's relay must be connected to common Arduino GND pin, right ?
      it depends, you could also wire it to the 5V and detect when the digital pin goes high you have movement.
      • M Offline
        M Offline
        mckenzi
        THank you Gohan. Now everything is more clearer. :-) Will try today to wire everything.
        • M Offline
          M Offline
          mckenzi
          Hi GOHAN,
          Finally i've build my serial gateway ( Arduino UNO + nRF24) + node (Arduino Nano + nRF24) but i failed with PIR conection to my NODE. How should i connect PIR's relay to Nano ? ( digital input + GND ) ?
          Now i know that relay is normally closed ( 0, 1 state, no power on it)
          I was trying to connect this way and it was working for few second ( i saw in the serial monitor , 1 , 0) but after some time NODE was sending weird data to GW.
          How connect it corectlly and how to mod the sketch for more sensors? (4 pcs). ```
          This is the way ?
          #define DIGITAL_INPUT_SENSOR 4   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
          #define CHILD_ID 2   // Id of the sensor child```
            IF the pir sensor has a normally closed relay you need to use the 5v output of the arduino to one pin of the relay and the other to the digital input and use the code to send TRIPPED true message when pin goes LOW and TRIPPED false when pin is high
            • M Offline
              M Offline
              mckenzi
              Hi Gohan,
              This is the way i should follow ?:
              	// Read digital motion value
                if(digitalRead(DIGITAL_INPUT_SENSOR) == HIGH){
                  tripped = true;
                } else {
                  tripped = false;
              Not so easy to set :-)
                actually the opposite, then you need to send the tripped value. Pls check the logic with the relay on the sensor
                • M Offline
                  M Offline
                  mckenzi
                  If my understanding is correct it works as follows:
                  (HIGH : when relay is closed, connected to digital pin & 5V VCC)
                  1- HIGH->TRUE-> msg.set 1
                  2- LOW->FALSE->msg.set 0
                  It works but it's very unstable. Sometimes working sometimes not.
                  Is it necessary to add some resistors to this circuit?
                    In this case you need to debug where problem is, if it is the relay not closing, the arduino not getting the pin change or message send failed. Also pls post all the code you are using.
                    • M Offline
                      M Offline
                      mckenzi
                      Relay is working correctly, checked with multimeter. Now i'm study about debugging.
                      Below is the code i'm using (4 PIRs).
                      Problem with sleep mode?
                      // Enable debug prints
                      // #define MY_DEBUG
                      #define MY_NODE_ID AUTO
                      unsigned long SLEEP_TIME = 5000 ; // 120000 Sleep time between reports (in milliseconds)
                      #define DIGITAL_INPUT_SENSOR1 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                      #define DIGITAL_INPUT_SENSOR2 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                      #define DIGITAL_INPUT_SENSOR3 4   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                      #define DIGITAL_INPUT_SENSOR4 5   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                      #define CHILD_ID_PIR1 21   // Id of the sensor child
                      #define CHILD_ID_PIR2 22   // Id of the sensor child
                      #define CHILD_ID_PIR3 23   // Id of the sensor child
                      #define CHILD_ID_PIR4 24   // Id of the sensor child
                      #define MY_REPEATER_FEATURE
                      // Initialize motion message
                      MyMessage msg1(CHILD_ID_PIR1, V_TRIPPED);
                      MyMessage msg2(CHILD_ID_PIR2, V_TRIPPED);
                      MyMessage msg3(CHILD_ID_PIR3, V_TRIPPED);
                      MyMessage msg4(CHILD_ID_PIR4, V_TRIPPED);
                        pinMode(DIGITAL_INPUT_SENSOR1, INPUT);      // sets the motion sensor digital pin as input
                        pinMode(DIGITAL_INPUT_SENSOR2, INPUT);      // sets the motion sensor digital pin as input
                        pinMode(DIGITAL_INPUT_SENSOR3, INPUT);      // sets the motion sensor digital pin as input
                        pinMode(DIGITAL_INPUT_SENSOR4, INPUT);      // sets the motion sensor digital pin as input
                        sendSketchInfo("PIR Sensor", "0.1");
                        present(CHILD_ID_PIR1, S_MOTION);
                        present(CHILD_ID_PIR2, S_MOTION);
                        present(CHILD_ID_PIR3, S_MOTION);
                        present(CHILD_ID_PIR4, S_MOTION);
                      // Read digital motion value (PIR1)
                        bool tripped1 = digitalRead(DIGITAL_INPUT_SENSOR1) == HIGH;
                        if(digitalRead(DIGITAL_INPUT_SENSOR1) == HIGH)
                          tripped1 = true;
                         else
                          tripped1 = false;
                      // Read digital motion value (PIR2)
                        bool tripped2 = digitalRead(DIGITAL_INPUT_SENSOR2) == HIGH;
                        if(digitalRead(DIGITAL_INPUT_SENSOR2) == HIGH)
                          tripped2 = true;
                         else
                          tripped2 = false;
                      // Read digital motion value (PIR3)
                         bool tripped3 = digitalRead(DIGITAL_INPUT_SENSOR3) == HIGH;
                         if(digitalRead(DIGITAL_INPUT_SENSOR3) == HIGH)
                          tripped3 = true;
                         else
                          tripped3 = false;
                      // Read digital motion value (PIR4)
                        bool tripped4 = digitalRead(DIGITAL_INPUT_SENSOR4) == HIGH;
                        if(digitalRead(DIGITAL_INPUT_SENSOR4) == HIGH)
                          tripped4 = true;
                         else
                          tripped4 = false;
                        Serial.println(tripped1);
                        send(msg1.set(tripped1?"1":"0"));  // Send tripped value to gw
                        Serial.println(tripped2);
                        send(msg2.set(tripped2?"1":"0"));  // Send tripped value to gw
                        Serial.println(tripped3);
                        send(msg3.set(tripped3?"1":"0"));  // Send tripped value to gw
                        Serial.println(tripped4);
                        send(msg4.set(tripped4?"1":"0"));  // Send tripped value to gw
                        sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR1), CHANGE, SLEEP_TIME);
                          sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR2), CHANGE, SLEEP_TIME);
                            sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR3), CHANGE, SLEEP_TIME);
                              sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR4), CHANGE, SLEEP_TIME);
                        You can use only 2 interrupts on pin 2 and 3, calling 4 sleep functions is useless
                        12.1k
