  3. Looking for a simple guide MySensors+Domoticz (Raspi as controller with NRF)
8 Posts 3 Posters 3.4k Views 5 Watching
  • S Offline
    sineverba
    wrote on last edited by sineverba
    Hi to all!
    I'm not real new to the Raspberry and Arduino. I did try last year to build a total self made web controller with Raspberry 2 as central and Arduino as slave / reading temperature.
    Now I want to follow the route with MySensors + Domoticz.
    But I cannot find a "simple" guide.
    My goal:
    • Raspberry connected via LAN to the router. On GPIO it has a NRF module (it works, I did followed this link: https://www.mysensors.org/build/raspberry )
      Here the answer at sudo ./bin/mysgw -d
    mysgw: Starting gateway...
    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    • Arduino with a NRF and a DHT22 sensor that sends data to the Raspberry.
    I cannot understand how setup Raspberry as GATEWAY + CONTROLLER toghether.
    Summary:
    • Pi with domoticz installed: OK
    • PI with NRF that seems to work (https://www.mysensors.org/build/raspberry): OK (I hope and think)
    NRF compiled with "Serial gateway" method. It is now /ttyPI (if I remember right, how I can find it?).
    In domoticz, In select I have only MySensorUSB and MySensorLAN . If I select the USB, in second select I have only the AMA20 (?)
    Thank you very much
    Y mfalkviddM 2 Replies Last reply
    • S sineverba
      Hi to all!
      My goal:
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: MCO:BGN:STP
      Summary:
      Thank you very much
      Y Offline
      Y Offline
      @sineverba I haven't tried this setup myself yet, but I did have some issues with Domoticz not updating available serial ports if they come available with Domoticz running. Try refreshing the page, or even restarting Domoticz.
      If that doesn't work you could also try running the Pi gateway as Ethernet gateway and connect Domoticz to localhost.
      • S sineverba
        Hi to all!
        My goal:
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: MCO:BGN:STP
        Summary:
        Thank you very much
        @sineverba When I set up my Domoticz installation, Domoticz was very picky about the how the tty was named. I had to follow this part of the instruction:
        For some controllers a more recognisable name needs to be used: e.g. /dev/ttyUSB020 (check if this is free).
        See if running configure with --my-serial-pty=/dev/ttyUSB020 (in addition to all the other parameters you used last time) and then running make and try sudo ./bin/mysgw -d again.
        S 1 Reply Last reply
          sineverba
          @mfalkvidd said in Looking for a simple guide MySensors+Domoticz (Raspi as controller with NRF):
          Thank you. But I need to select which transport? Serial? Another thing, what i need to see / find on Domoticz if all is OK? Can you post me a screenshot of hardware section ?
          Thank you
          • S sineverba
            Thank you
            @sineverba I use serial. Ethernet should work as well.
            Here is what mine looks like. I am still running the old MySensors 1.4 gateway software though.
            • S Offline
              sineverba
              Ok,
              I did made some progress!
              Let's do a summary.
              1. Fresh install of last Raspbian from official site
              2. Did setup on Arduino for NRF + on PI for NRF with examples in TMRH20 library on github. They work very well, send and receiving data correctly.
              3. Setup with guide for 1.x version (this: https://forum.mysensors.org/topic/2437/step-by-step-procedure-to-connect-the-nrf24l01-to-the-gpio-pins-and-use-the-raspberry-as-a-serial-gateway-mysensors-1-x )
              4. No error, all OK, I did install domoticz (via "easy" mode)
              5. Now, in domoticz I see the USB Gateway (I remember, I have NRF direct attached on GPIO, arduino is on other side of the room, no physical USB) and I did add:
              1. I did upload sketch on arduino, an example sketch of MySensor library (CO2) or UV sensors (no sensor attached, only sketch + radio).
              This is the sketch (note custom define of 2 PINS):
              #define MY_RF24_CE_PIN 7
              #define MY_RF24_CS_PIN 8
              #define UV_SENSOR_ANALOG_PIN 0
              #define CHILD_ID_UV 0
              unsigned long SLEEP_TIME = 30*1000; // Sleep time between reads (in milliseconds)
              MyMessage uvMsg(CHILD_ID_UV, V_UV);
              unsigned long lastSend =0;
              float uvIndex;
              float lastUV = -1;
              uint16_t uvIndexValue [12] = { 50, 227, 318, 408, 503, 606, 696, 795, 881, 976, 1079, 1170};
              	sendSketchInfo("UV Sensor", "1.2");
              	present(CHILD_ID_UV, S_UV);
              	unsigned long currentTime = millis();
              	uint16_t uv = analogRead(UV_SENSOR_ANALOG_PIN);// Get UV value
              	if (uv>1170) {
              		uv=1170;
              	//Serial.print("UV Analog reading: ");
              	//Serial.println(uv);
              	int i;
              	for (i = 0; i < 12; i++) {
              		if (uv <= uvIndexValue[i]) {
              			uvIndex = i;
              			break;
              	//calculate 1 decimal if possible
              	if (i>0) {
              		float vRange=uvIndexValue[i]-uvIndexValue[i-1];
              		float vCalc=uv-uvIndexValue[i-1];
              		uvIndex+=(1.0/vRange)*vCalc-1.0;
              	//Serial.print("UVI: ");
              	//Serial.println(uvIndex,2);
              	//Send value to gateway if changed, or at least every 5 minutes
              	if ((uvIndex != lastUV)||(currentTime-lastSend >= 5UL*60UL*1000UL)) {
              		lastSend=currentTime;
              		send(uvMsg.set(uvIndex,2));
              		lastUV = uvIndex;
              	sleep(SLEEP_TIME);
              I have this in monitor serial of arduino:
              139291 TSMTSF:MSG:SEND,105-105-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              3 TSM:INIT
              4 TSF:WUR:MS=0
              11 TSM:INIT:TSP OK
              13 TSF:SID:OK,ID=105
              14 TSM:FPAR
              51 TSF:MSG:SEND,105-105-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              893 TSF:MSG:READ,0-0-105,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              899 TSF:MSG:FPAR OK,ID=0,D=1
              2058 TSM:FPAR:OK
              2059 TSM:ID
              2060 TSM:ID:OK
              2062 TSM:UPL
              2065 TSF:MSG:SEND,105-105-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              4072 TSM:UPL
              4074 TSF:MSG:SEND,105-105-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              6082 TSM:UPL
              6084 TSF:MSG:SEND,105-105-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              (without custom definition of pin, of course, I have simply fail, 'cause I did attach pin differently)
              It seems to me that Arduino sends in right way and have an answer from PI (?)
              But this is the log of domoticz...
              2017-06-18 15:29:59.327 Domoticz V3.5877 (c)2012-2016 GizMoCuz
              2017-06-18 15:29:59.333 Build Hash: 15b013c, Date: 2016-11-10 15:44:33
              2017-06-18 15:29:59.333 System: Raspberry Pi
              2017-06-18 15:29:59.334 Startup Path: /home/pi/domoticz/
              2017-06-18 15:29:59.964 Active notification subsystems: http (1/12)
              2017-06-18 15:30:00.001 WebServer(HTTP) started on address: :: with port 8080
              2017-06-18 15:30:00.036 WebServer(SSL) started on address: :: with port 443
              2017-06-18 15:30:00.043 Proxymanager started.
              2017-06-18 15:30:00.054 Starting shared server on: :::6144
              2017-06-18 15:30:00.056 RxQueue: queue worker started...
              2017-06-18 15:30:00.056 TCPServer: shared server started...
              2017-06-18 15:30:02.130 EventSystem: reset all events...
              2017-06-18 15:30:02.135 EventSystem: reset all device statuses...
              2017-06-18 15:30:02.137 EventSystem: Started
              2017-06-18 15:30:03.131 MySensors: Using serial port: /dev/ttyUSB20
              2017-06-18 15:30:35.783 Incoming connection from: 192.168.1.201
              And in child spaces are empty :(
              Maybe I did not do other steps? I repeat, the NRF works together (as tested from NRF24 library)...
              Thank you guys!
              PS:
              With domoticz live and Arduino sending, I did a
              sudo ./PiGateway
              This is the answer:
              pi@raspberrypi:~/Raspberry $ sudo ./PiGateway
              Starting Gateway...
              ================ SPI Configuration ================
              CSN Pin          = CE0 (PI Hardware Driven)
              CE Pin           = Custom GPIO25
              Clock Speed      = 8 Mhz
              ================ NRF Configuration ================
              STATUS           = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
              RX_ADDR_P0-1     = 0xa8a8e1fc69 0xa8a8e1fc00
              RX_ADDR_P2-5     = 0xff 0xc4 0xc5 0xc6
              TX_ADDR          = 0xa8a8e1fc69
              RX_PW_P0-6       = 0x20 0x20 0x20 0x00 0x00 0x00
              EN_AA            = 0x3b
              EN_RXADDR        = 0x06
              RF_CH            = 0x4c
              RF_SETUP         = 0x23
              CONFIG           = 0x0e
              DYNPD/FEATURE    = 0x3f 0x06
              Data Rate        = 250KBPS
              Model            = nRF24L01+
              CRC Length       = 16 bits
              PA Power         = PA_LOW
              [CALLBACK]0;0;3;0;14;Gateway startup complete.
              read: 105-105-0 s=255,c=3,t=24,pt=1,l=1:1
              [CALLBACK]105;255;3;0;24;1
              read: 105-105-255 s=255,c=3,t=7,pt=0,l=0:
              send: 0-0-105-105 s=255,c=3,t=8,pt=1,l=1,st=ok:0
              • S sineverba
                Ok,
                Let's do a summary.
                float uvIndex;
                float lastUV = -1;
                	if (uv>1170) {
                		uv=1170;
                	int i;
                			uvIndex = i;
                			break;
                	if (i>0) {
                		lastUV = uvIndex;
                	sleep(SLEEP_TIME);
                3 TSM:INIT
                4 TSF:WUR:MS=0
                11 TSM:INIT:TSP OK
                14 TSM:FPAR
                2058 TSM:FPAR:OK
                2059 TSM:ID
                2060 TSM:ID:OK
                2062 TSM:UPL
                4072 TSM:UPL
                6082 TSM:UPL
                Thank you guys!
                PS:
                sudo ./PiGateway
                This is the answer:
                Starting Gateway...
                Clock Speed      = 8 Mhz
                EN_AA            = 0x3b
                EN_RXADDR        = 0x06
                RF_CH            = 0x4c
                RF_SETUP         = 0x23
                CONFIG           = 0x0e
                Data Rate        = 250KBPS
                Model            = nRF24L01+
                PA Power         = PA_LOW
                @sineverba looks like you are using a MySensors 1.x gateway with a MySensors 2.1.1 node. That will not work. Gateway and sensor need to be the same major version. Use the 2.x gateway instructions instead.
                • S Offline
                  sineverba
                  @mfalkvidd yes, I'm using node 2 and mysensor 1 gateway.
                  Unfortunately I don't get on work 2.0 gateway..... :( :( :(
                  Next week I will restart with a fresh Raspbian, maybe I will solve my initial issues...
                  Thank you very much!
