  3. Cannot assign NODE ID
4 Posts 3 Posters 1.5k Views 3 Watching
    moskovskiy82
    Have been running successfully mysensors for quite some time. Now building another sensor and have a nightmare. The manually set NODE_ID gets completly ignored and i don not why just gets itself from out of nowhere. My gateway is a version 2.0 ESP to MQTT
    Code
    #define SN "Vent Klapans"
    #define SV "2.1"
    //System settings
    #include <Bounce2.h>
    #include <DHT.h>
    #include <math.h>
    #include <Wire.h>
    #define MY_NODE_ID 56
    //SETUP PINS
    #define BUT1_PIN 7
    #define BUT2_PIN 8
    #define DHT_PIN 3
    #define RELAY_1  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    //Define connections
    #define CHILD_ID_HUM 3
    #define CHILD_ID_TEMP 4
    #define CHILD_BUT1_ID 7
    #define CHILD_BUT2_ID 8
    #define RELAY_ON 0  // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    DHT dht;
    //MQ+DHT
    long DHT_Millis = 0;
    long DHT_interval = 60000;
    //Buttons
    Bounce debouncer1 = Bounce();
    Bounce debouncer2 = Bounce();
    int oldValue1=-1;
    int oldValue2=-1;
    MyMessage msgHumi(CHILD_ID_HUM, V_HUM);
    MyMessage msgBut1(CHILD_BUT1_ID,V_STATUS);
    MyMessage msgBut2(CHILD_BUT2_ID,V_STATUS);
    void before()
      Serial.println( myNodeId );
      dht.setup(DHT_PIN);
      pinMode(BUT1_PIN,INPUT_PULLUP);
      pinMode(BUT2_PIN,INPUT_PULLUP);
      debouncer1.attach(BUT1_PIN);
      debouncer1.interval(5);
      debouncer2.attach(BUT2_PIN);
      debouncer2.interval(5);
      for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS;sensor++, pin++) // Fetch relay status
        pinMode(pin, OUTPUT);   // Then set relay pins in output mode
        digitalWrite(pin, loadState(sensor)?RELAY_ON:RELAY_OFF); // Set relay to last known state (using eeprom storage)
    {  Serial.begin(115200); }
      sendSketchInfo(SN, SV);
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_BUT1_ID, S_LIGHT);
      present(CHILD_BUT2_ID, S_LIGHT);
        present(sensor, S_LIGHT); // Register all sensors to gw (they will be created as child devices)
      unsigned long DHT_Current_Millis = millis();
      if(DHT_Current_Millis - DHT_Millis > DHT_interval)
        DHT_Millis = DHT_Current_Millis;
        if (isnan(temperature))
          if (isnan(humidity))
        else
          send(msgHumi.set(humidity, 1));
          Serial.print("T: ");
          Serial.println(temperature);
          Serial.print("H: ");
          Serial.println(humidity);
        debouncer1.update();
          int value = debouncer1.read();
          if (value != oldValue1)
            // Send in the new value
            send(msgBut1.set(value==HIGH ? 1 : 0));
            oldValue1 = value;
        debouncer2.update();
          int value2 = debouncer2.read();
          if (value2 != oldValue2)
            send(msgBut2.set(value==HIGH ? 1 : 0));
            oldValue2 = value2;
        if (message.type==V_STATUS) // We only expect one type of message from controller. But we better check anyway.
          digitalWrite(message.sensor-1+RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF); // Change relay state
          saveState(message.sensor, message.getBool()); // Store state in eeprom
          Serial.print("Incoming change for sensor:"); // Write some debug info
          Serial.print(message.sensor);
    Debug - Serial Print
    15 TSF:SID:OK,ID=75
    17 TSM:FPAR
    53 TSF:MSG:SEND,75-75-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    1238 TSF:MSG:READ,0-0-75,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    1243 TSF:MSG:FPAR OK,ID=0,D=1
    2060 TSM:FPAR:OK
    2061 TSM:ID
    2062 TSM:ID:OK
    2064 TSM:UPL
    2067 TSF:MSG:SEND,75-75-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2179 TSF:MSG:READ,0-0-75,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2184 TSF:MSG:PONG RECV,HP=1
    2186 TSM:UPL:OK
    2188 TSM:READY:ID=75,PAR=0,DIS=1
    2192 TSF:MSG:SEND,75-75-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2329 TSF:MSG:READ,0-0-75,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2336 TSF:MSG:SEND,75-75-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
    2345 TSF:MSG:SEND,75-75-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    4354 TSF:MSG:SEND,75-75-0-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:Vent Klapans
    4363 TSF:MSG:SEND,75-75-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.1
    4371 TSF:MSG:SEND,75-75-0-0,s=3,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4378 TSF:MSG:SEND,75-75-0-0,s=4,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
    4420 !TSF:MSG:SEND,75-75-0-0,s=7,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=NACK:
    4461 !TSF:MSG:SEND,75-75-0-0,s=8,c=0,t=3,pt=0,l=0,sg=0,ft=1,st=NACK:
    4502 !TSF:MSG:SEND,75-75-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=2,st=NACK:
    4510 TSF:MSG:SEND,75-75-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=3,st=OK:
    4516 MCO:REG:REQ
    4554 !TSF:MSG:SEND,75-75-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=NACK:2
    6561 TSF:MSG:SEND,75-75-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=OK:2
    6634 TSF:MSG:READ,0-0-75,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    6639 MCO:PIM:NODE REG=1
    6641 MCO:BGN:STP
    6642 MCO:BGN:INIT OK,TSP=1
    6647 TSF:MSG:SEND,75-75-0-0,s=7,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:1
    6654 TSF:MSG:SEND,75-75-0-0,s=8,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:1
    Debug - this is what i see on the MQTT broker (connected to
    mys-out/75/255/3/0/11 Vent Klapans
    mys-out/75/255/3/0/12 2.1
    mys-out/75/3/0/0/7 (null)
    mys-out/75/4/0/0/6 (null)
    mys-out/75/1/0/0/3 (null)
    mys-out/75/7/1/0/2 1
    mys-out/75/8/1/0/2 1
    mys-out/71/6/1/0/37 626.0
    • M moskovskiy82
      Code
      #define SV "2.1"
      //System settings
      #include <DHT.h>
      #include <math.h>
      #include <Wire.h>
      //SETUP PINS
      #define BUT1_PIN 7
      #define BUT2_PIN 8
      #define DHT_PIN 3
      DHT dht;
      //MQ+DHT
      //Buttons
      int oldValue1=-1;
      int oldValue2=-1;
      void before()
        dht.setup(DHT_PIN);
          else
              oldValue1 = value;
              oldValue2 = value2;
      15 TSF:SID:OK,ID=75
      17 TSM:FPAR
      2060 TSM:FPAR:OK
      2061 TSM:ID
      2062 TSM:ID:OK
      2064 TSM:UPL
      2186 TSM:UPL:OK
      4516 MCO:REG:REQ
      6641 MCO:BGN:STP
      @moskovskiy82 upload the clearEepromConfig sketch (available in Examples->MySensors in the Arduino IDE) and run it once, then re-upload your own sketch.
      I think the node is using an old node id stored in eeprom. Clearing the eeprom will get rid of that.
        on second thought, the problem is that #define MY_NODE_ID 56 is after #include <MySensors.h> in your sketch. It needs to be defined before including MySensors.h
          At least it was getting id 75 😀
