  3. MQCalibration was not declared in this scope, what`s wrong?
3 Posts 2 Posters 1.4k Views 2 Watching
  • asmmanA
    asmmanA
    asmman
    wrote on last edited by asmman
     * Version 1.0 - Henrik EKblad
     * Example sketch showing how to measue light level using a LM393 photo-resistor
     * http://www.mysensors.org/build/light
    //#define MY_DEBUG
    #define MY_GATEWAY_SERIAL
    #define CHILD_ID_LIGHT 0
    #define LIGHT_SENSOR_ANALOG_PIN 0
    #define CHILD_ID_MQ 1
    #define MQ_SENSOR_ANALOG_PIN 1 //define which analog input channel you are going to use
    #define         RL_VALUE                     (5)     //define the load resistance on the board, in kilo ohms
    #define         RO_CLEAN_AIR_FACTOR          (9.83)  //RO_CLEAR_AIR_FACTOR=(Sensor resistance in clean air)/RO,
    //which is derived from the chart in datasheet
    /***********************Software Related Macros************************************/
    #define         CALIBARAION_SAMPLE_TIMES     (50)    //define how many samples you are going to take in the calibration phase
    #define         CALIBRATION_SAMPLE_INTERVAL  (500)   //define the time interal(in milisecond) between each samples in the
    //cablibration phase
    #define         READ_SAMPLE_INTERVAL         (50)    //define how many samples you are going to take in normal operation
    #define         READ_SAMPLE_TIMES            (5)     //define the time interal(in milisecond) between each samples in
    //normal operation
    /**********************Application Related Macros**********************************/
    #define         GAS_LPG                      (0)
    #define         GAS_CO                       (1)
    #define         GAS_SMOKE                    (2)
    /*****************************Globals***********************************************/
    //VARIABLES
    int lastLightLevel;
    float Ro = 10000.0;    // this has to be tuned 10K Ohm
    int val = 0;           // variable to store the value coming from the sensor
    float valMQ =0.0;
    float lastMQ =0.0;
    float           LPGCurve[3]  =  {2.3,0.21,-0.47};   //two points are taken from the curve.
    //with these two points, a line is formed which is "approximately equivalent"
    //to the original curve.
    //data format:{ x, y, slope}; point1: (lg200, 0.21), point2: (lg10000, -0.59)
    float           COCurve[3]  =  {2.3,0.72,-0.34};    //two points are taken from the curve.
    //data format:{ x, y, slope}; point1: (lg200, 0.72), point2: (lg10000,  0.15)
    float           SmokeCurve[3] = {2.3,0.53,-0.44};   //two points are taken from the curve.
    //data format:{ x, y, slope}; point1: (lg200, 0.53), point2:(lg10000,-0.22)
    //unsigned long SLEEP_TIME = 30000;
    MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
    MyMessage msgMQ(CHILD_ID_MQ, V_LEVEL);
      Ro=MQCalibration(MQ_SENSOR_ANALOG_PIN);         //Calibrating the sensor. Please make sure the sensor is in clean air
    	sendSketchInfo("Light Sensor+GaS_Smoke_MQ2", "1.0");
       //sendSketchInfo("Air Quality Sensor", "1.0");
      present(CHILD_ID_MQ, S_AIR_QUALITY);
    	int16_t lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
    	Serial.println(lightLevel);
    		send(msgLight.set(lightLevel));
    		lastLightLevel = lightLevel;
      uint16_t valMQ = MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_CO);
      Serial.println(val);
      Serial.print("LPG:");
      Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_LPG) );
      Serial.print( "ppm" );
      Serial.print("    ");
      Serial.print("CO:");
      Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_CO) );
      Serial.print("    ");
      Serial.print("SMOKE:");
      Serial.print(MQGetGasPercentage(MQRead(MQ_SENSOR_ANALOG_PIN)/Ro,GAS_SMOKE) );
      Serial.print("\n");
      if (valMQ != lastMQ) {
        send(msgLight.set((int16_t)ceil(valMQ)));
        lastMQ = ceil(valMQ);
      sleep(SLEEP_TIME); //sleep for: sleepTime
    /home/pi/Desktop/MyScratches/LightSensor/LightSensor.ino: In function 'void setup()':
    LightSensor:84: error: 'MQCalibration' was not declared in this scope
    /home/pi/Desktop/MyScratches/LightSensor/LightSensor.ino: In function 'void loop()':
    LightSensor:107: error: 'MQRead' was not declared in this scope
    LightSensor:107: error: 'MQGetGasPercentage' was not declared in this scope
    exit status 1
    What wrong?
    • asmmanA asmman
      //#define MY_DEBUG
      //normal operation
      #define         GAS_LPG                      (0)
      #define         GAS_CO                       (1)
      //VARIABLES
      int lastLightLevel;
      float valMQ =0.0;
      float lastMQ =0.0;
        Serial.print("    ");
        Serial.print("    ");
        Serial.print("\n");
      exit status 1
      What wrong?
      @asmman welcome to the MySensors community.
      Looks like you are trying to use this sketch, but only included some parts of the code?
      Side note: Please use the code button when including code in a forum post. This makes the code much easier to read. The code button looks like this: </>
      • asmmanA
        asmmanA
        asmman
        Thanks for the tip about inserting the code, sorry! In this example I used two scratch specified and Light Sensor, in order to use the smoke sensor and light sensor in one gateway. Individually, these scratching are working properly and the WTO combine of together does not work, error appears. Thank you for understanding!
        see here: sendSketchInfo("Light Sensor+GaS_Smoke_MQ2", "1.0");
