  3. Help Me!!! Hardware problem arduino uno gateway
14 Posts 4 Posters 12.7k Views 2 Watching
  • gigiG
    gigiG
    gigi
    I would like to create a gateway ed a humidity sensor node
    I purchased two radio nRF24L01 and 2 arduino nano and 1 DHT-11
    Gatheway
    I connected all cable but I realized the arduino nano are Chinese and have a serial communication protocol different from the original arduino nano.
    I then abandoned the gateway with serial!!!
    I have another arduino uno whit ethernet shield!!!!
    loaded the sketck connected the cables but arduino crashes
    I followed the discussion forum
    uncomment (remove //) #define SOFTSPI
    change pin numbers as below:
    const uint8_t SOFT_SPI_MISO_PIN = 15;
    const uint8_t SOFT_SPI_MOSI_PIN = 14;
    const uint8_t SOFT_SPI_SCK_PIN = 16;
    Connecto radio and gateway as per instructions for ethernet gateway except MISO, MOSI and SCK.
    These connect as below
    radio MOSI to arduino A0,
    radio MISO to arduino A1,
    radio SCK to arduino A2.
    comment UIPEthernet.h (//#include <UIPEthernet.h>)
    uncomment Ethernet.h (#include <Ethernet.h>)
    choose IP address
    arduino uno don' respond at ping if i remove a radio module.
    Thank for all
    Gigi
    Vera lite - mysensors Ethernet gateway - AirWik sensor - Relay Module
    • m26872M
      m26872M
      m26872
      No clone Uno I suppose? How do the leds work? Any debug from serial monitor?
      • gigiG
        gigiG
        gigi
        Arduino Uno genuine!!!
        radio connect
        http://www.mysensors.org/build/ethernet_gateway
        arduino -- > radio
        GND -- > GND
        3.3V -- > VCC
        A2 -- > MISO
        A1 -- > MOSI
        A0 -- > SCK
        6 -- > CSN
        5 -- > CE
        Radio Led all off
        Arduino Uno Led:
        Led on : red
        ethernet shield: green led on
        serial monitor ide ardunino
        but no ping to 192.168.0.66
        Thank
        • gigiG
          gigiG
          gigi
          Humidiy sensor with arduino nano clone and dt11
          send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
          req node id
          send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
          sensor started, id 255
          req node id
          req node id
          req node id
          req node id
          req node id
          req node id
          req node id
          T: 20.00
          req node id
          H: 40.00
          req node id
          T: 21.00
          req node id
          T: 20.00
          • m26872M
            m26872M
            m26872
            Have you tried to power from the DC-in socket instead of the usb. I think I've read that just the usb isn't enough for the ethernet shield. And avoid use both at the same time unless you're really sure about that it wont destroy anything.
            Edit: You should be safe with keeping the usb connected and using a good quality supply. And of course you'll need the usb to debug.
            • gigiG
              gigiG
              gigi
              server.write(writeBuffer); in EthernetGateway.ino stops arduino!!!
              If I comment server.write(writeBuffer); in function writeEthernet(char *writeBuffer) arduino uno receive and transmit data via radio.
              Node Humidity
              req node id
              send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=ok:
              req node id
              req node id
              req node id
              req node id
              send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
              req node id
              req node id
              req node id
              T: 22.00
              req node id
              H: 39.00
              Gateway without server.write(writeBuffer);
              gateway is at 192.168.0.166
              0;0;3;0;9;read: 255-255-0 s=255,c=3,t=3,pt=0,l=0:
              255;255;3;0;3;
              255;255;3;0;3;
              255;255;3;0;3;
              255;255;3;0;3;
              255;255;3;0;3;
              Thank
              Gigi
              • gigiG
                gigiG
                gigi
                wrote on last edited by gigi
                My configuration!!!!
                circuit diagram
                in RF24_config.h
                enable softspi (remove // before "#define SOFTSPI").
                change
                arduino sketch
                • Copyright (C) 2013 Henrik Ekblad henrik.ekblad@gmail.com
                • Contribution by a-lurker
                • Contribution by Norbert Truchsess norbert.truchsess@t-online.de
                • This program is free software; you can redistribute it and/or
                • modify it under the terms of the GNU General Public License
                • version 2 as published by the Free Software Foundation.
                • DESCRIPTION
                • The EthernetGateway sends data received from sensors to the ethernet link.
                • The gateway also accepts input on ethernet interface, which is then sent out to the radio network.
                • The GW code is designed for Arduino 328p / 16MHz. ATmega168 does not have enough memory to run this program.
                • COMPILING WIZNET (W5100) ETHERNET MODULE
                • Edit RF24_config.h in (libraries\MySensors\utility) to enable softspi (remove // before "#define SOFTSPI").
                • COMPILING ENC28J60 ETHERNET MODULE
                • Use Arduino IDE 1.0.6 or 1.5.7 (or later)
                • Not compatible with Arduino IDE < 1.0.6 / 1.5.7 ! (use of EthernetClient operator ==)
                • Disable DEBUG in Sensor.h before compiling this sketch. Othervise the sketch will probably not fit in program space when downloading.
                • Remove Ethernet.h include below and include UIPEthernet.h
                • Remove DigitalIO include
                • Note that I had to disable UDP and DHCP support in uipethernet-conf.h to reduce space. (which means you have to choose a static IP for that module)
                • VERA CONFIGURATION:
                • Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
                • E.g. If you want to use the defualt values in this sketch enter: 192.168.178.66:5003
                • LED purposes:
                  • RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
                  • TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
                  • ERR (red) - fast blink on error during transmission error or recieve crc error
                • See http://www.mysensors.org/build/ethernet_gateway for wiring instructions.
                • in RF24_config.h
                • decommentare #define SOFTSPI riga 28 enable softspi (remove // before "#define SOFTSPI").
                • const uint8_t SOFT_SPI_MISO_PIN = 15;
                • const uint8_t SOFT_SPI_MOSI_PIN = 14;
                • const uint8_t SOFT_SPI_SCK_PIN = 16;
                • radio Pin
                • ARDUINO RADIO
                • pin 5 --> CE
                • pin 6 --> CSN
                • pin A0 --> MOSI
                • pin A1 --> MISO
                • pin A2 --> SCK
                #include <DigitalIO.h> // This include can be removed when using UIPEthernet module
                #include <MyGateway.h>
                #include <stdarg.h>
                // Use this if you have attached a Ethernet ENC28J60 shields
                // Use this fo WizNET W5100 module and Arduino Ethernet Shield
                #define INCLUSION_MODE_TIME 1 // Number of minutes inclusion mode is enabled
                #define INCLUSION_MODE_PIN 3 // Digital pin used for inclusion mode button
                #define RADIO_CE_PIN 5 // radio chip enable
                #define RADIO_SPI_SS_PIN 6 // radio SPI serial select
                #define RADIO_ERROR_LED_PIN 7 // Error led pin
                #define RADIO_RX_LED_PIN 8 // Receive led pin
                #define RADIO_TX_LED_PIN 9 // the PCB, on board LED
                #define IP_PORT 5003 // The port you want to open
                IPAddress myIp (192, 168, 0, 166); // Configure your static ip-address here COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later!
                // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
                byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // DEAD BEEF FEED
                // a R/W server on the port
                EthernetServer server = EthernetServer(IP_PORT);
                // handle to open connection
                EthernetClient client = EthernetClient();
                // No blink or button functionality. Use the vanilla constructor.
                MyGateway gw(RADIO_CE_PIN, RADIO_SPI_SS_PIN, INCLUSION_MODE_TIME);
                // Uncomment this constructor if you have leds and include button attached to your gateway
                //MyGateway gw(RADIO_CE_PIN, RADIO_SPI_SS_PIN, INCLUSION_MODE_TIME, INCLUSION_MODE_PIN, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                char inputString[MAX_RECEIVE_LENGTH] = ""; // A string to hold incoming commands from serial/ethernet interface
                int inputPos = 0;
                // Initialize gateway at maximum PA level, channel 70 and callback for write operations
                gw.begin(RF24_PA_LEVEL_GW, RF24_CHANNEL, RF24_DATARATE, writeEthernet);
                Ethernet.begin(mac, myIp);
                // give the Ethernet interface a second to initialize
                delay(1000);
                // start listening for clients
                server.begin();
                // This will be called when data should be written to ethernet
                void writeEthernet(char *writeBuffer) {
                client.write(writeBuffer);
                // if an incoming client connects, there will be
                // bytes available to read via the client object
                EthernetClient newclient = server.available();
                // if a new client connects make sure to dispose any previous existing sockets
                if (newclient) {
                if (client != newclient) {
                client.stop();
                client = newclient;
                client.print(F("0;0;3;0;14;Gateway startup complete.\n"));
                if (client) {
                if (!client.connected()) {
                client.stop();
                // if got 1 or more bytes
                } else if (client.available()) {
                // read the bytes incoming from the client
                char inChar = client.read();
                if (inputPos<MAX_RECEIVE_LENGTH-1) {
                // if newline then command is complete
                if (inChar == '\n') {
                // a command was issued by the client
                // we will now try to send it to the actuator
                inputString[inputPos] = 0;
                // echo the string to the serial port
                Serial.print(inputString);
                gw.parseAndSend(inputString);
                // clear the string:
                inputPos = 0;
                } else {
                // add it to the inputString:
                inputString[inputPos] = inChar;
                inputPos++;
                } else {
                // Incoming message too long. Throw away
                inputPos = 0;
                gw.processRadioMessage();
                here is the result
                thank to Norbert Truchsess for skecth
                • m26872M
                  m26872M
                  m26872
                  Please indent any code 4 spaces before pasting to make it easier to read.
                  Did you try an external power source?
                  • K
                    K
                    kalle
                    Im not sure it is a typo or you tried to ping different IP's
                    In the third post you write "but no ping to 192.168.0.66" instead of 192.168.0.166 which is written in the sketch, maybe this is the problem.
                    • gigiG
                      gigiG
                      gigi
                      I don't try external power source. In this moment is connect to usb cable from pc!!
                      Ip is 192.168.0.166
                      Thank
                      • K
                        K
                        kalle
                        What is your progress? Now it works?
                        It is better to use a power supply instead of USB power with the Ethernetshield.
                        gigiG 1 Reply Last reply
                        • K kalle
                          gigiG
                          gigiG
                          gigi
                          I put arduino and ethernet and shield directly connected with PC USB.
                          Are two weeks and works without problems.
                          even if the PC is powered off the USB supply current!!!!
                          Merry Christmas and Happy Holidays!!!!
                          A 1 Reply Last reply
                          • K
                            K
                            kalle
                            wrote on last edited by kalle
                            Nice to hear everything works fine.
                            Merry Christmas and Happy Holidays ;-)
                            • gigiG gigi
                              A
                              A
                              anibaldiniz
                              Hello, I only managed to make it work ties in:
                              #define SOFTSPI
                              #ifdef SOFTSPI
                              const uint8_t SOFT_SPI_MISO_PIN = 12; //A0
                                   const uint8_t SOFT_SPI_MOSI_PIN = 11; // A1
                                   const uint8_t SOFT_SPI_SCK_PIN = 13; // A0
                              I do not know how to explain.
