  3. OpenHAB
  4. openHAB 2.2 binding
openHAB 2.2 binding
132 Posts 32 Posters 89.6k Views 34 Watching
  • L
    L
    LastSamurai
    I have added 2 more issues in github. Most importantly there seems to be an issue with ACK right now. So if you have enabled acknowledgment on one of your things and sometimes see no reactions from your leds (or whatever you are using) try disabling ACK. I helped in my case.
    • K
      K
      krejcarek
      Not sure if it is related to the above mentioned ACK issue... I have some distanced actuators, and was heavily relying on the repeated message send if no ACK. I habe the impression with this upgrade, it does not work as before. Can it be the case?
      L 1 Reply Last reply
      • K krejcarek
        L
        L
        LastSamurai
        @krejcarek I haven't heard anything from @TimO recently but have you tried it without ACK enabled? In my case the rate of success increased visibly. There are still some cases where the message doesn't get send successfully though, so I am still waiting for the working ACK feature ;)
        T 1 Reply Last reply
        • L LastSamurai
          TimO
          @LastSamurai I haven't found the time to look at the issues lately, I'm sorry. :-/
          I'm on vacation for the next 10 days and will continue my work after after that. :)
          • F
            F
            Fabien
            @TimO enjoy your holidays ;)
            • gahlawathomeG
              gahlawathomeG
              gahlawathome
              Hi TimO, I am interested in Mqtt version of binding as I like the flexibility of my system with Mqtt. I see that Sean has already a PR open for this quite some time and I do not see any reason why his changes would break things. Any idea when can we expect this to be merged. Also I have just started getting involved in things and although don't have much time but will try to contribute around this area.
              • gahlawathomeG gahlawathome
                TimO
                Hi @gahlawathome !
                The code for the MQTT support is only working within the development environment. If I try to compile a jar, there is a dependency problem which I was not yet able to solve. There is MQTT support in ESH and in OpenHAB. The MQTT binding needs the one from Openhab because it is still based on Openhab 1. The MQTT support in the binding needs to be based on ESH, but you can't fulfill both dependencies because only one library at a time is allowed.
                I need to check if there has been some development on a MQTT 2.x binding, that would solve the problem.
                gahlawathomeG 1 Reply Last reply
                • T TimO
                  Hi @gahlawathome !
                  gahlawathomeG
                  gahlawathomeG
                  gahlawathome
                  @TimO Thank you very much for a very clear explanation. I will also search around MQTT 2.x on OpenHAB and post here if I find something relevant.
                  • L
                    L
                    LastSamurai
                    wrote on last edited by LastSamurai
                    #49
                    @TimO Hope you had a nice vacation!
                    Is there already some new version of the binding to test?
                    I was on vacation too lately and when I powered my openhab system back on I got lots of problems with my gateway and sensor connections. First I got a never ending circle of failing startup checks (although I could already switch lights). After I disabled the check it seemed to work. But when restarting a sensor node (that did not send any values after the controller restart) I got this error:
                    16:55:54.552 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;159004 Skipping security for command 3 type 16
                    16:55:54.604 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;255;3;0;9;159011 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                    16:55:54.747 [WARN ] [rsAbstractConnection$MySensorsReader] - Exception on reading from connection
                    java.io.IOException: Underlying input stream returned zero bytes
                            at sun.nio.cs.StreamDecoder.readBytes(StreamDecoder.java:288)[:1.8.0_144]
                            at sun.nio.cs.StreamDecoder.implRead(StreamDecoder.java:326)[:1.8.0_144]
                            at sun.nio.cs.StreamDecoder.read(StreamDecoder.java:178)[:1.8.0_144]
                            at java.io.InputStreamReader.read(InputStreamReader.java:184)[:1.8.0_144]
                            at java.io.BufferedReader.fill(BufferedReader.java:161)[:1.8.0_144]
                            at java.io.BufferedReader.readLine(BufferedReader.java:324)[:1.8.0_144]
                            at java.io.BufferedReader.readLine(BufferedReader.java:389)[:1.8.0_144]
                            at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection$MySensorsReader.run(MySensorsAbstractConnection.java:335)[205:org.openhab.binding.mysensors:2.2.0.201707241115]
                            at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_144]
                            at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_144]
                            at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)[:1.8.0_144]
                            at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)[:1.8.0_144]
                            at java.lang.Thread.run(Thread.java:748)[:1.8.0_144]
                    Any idea why or how to fix this? Everything was working fine before
                    PS I also just got another error while switching a light (the light still worked though):
                    17:08:31.549 [WARN ] [rsAbstractConnection$MySensorsReader] - Exception on reading from connection
                    java.text.ParseException: class java.text.ParseException : Message length is not > 4
                            at org.openhab.binding.mysensors.internal.protocol.message.MySensorsMessage.parse(MySensorsMessage.java:337)[205:org.openhab.binding.mysensors:2.2.0.201707241115]
                            at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection$MySensorsReader.run(MySensorsAbstractConnection.java:345)[205:org.openhab.binding.mysensors:2.2.0.201707241115]
                    17:08:31.678 [WARN ] [rsAbstractConnection$MySensorsReader] - Exception on reading from connection
                    • L
                      L
                      LastSamurai
                      Ok I reflashed the gateway and it's gotten a little better. Still have some errors though.
                      • L LastSamurai
                        TimO
                        Hi @LastSamurai !
                        You've debug enabled on the gateway, have you? Looks like the binding does not like the (debug) output from the gateway.
                        But the binding should recover just fine from the exception, only the (debug) message that has lead to this exception won't be parsed.
                        • T TimO
                          Hi @LastSamurai !
                          L
                          L
                          LastSamurai
                          Wow, you are right of course. Debugging is indeed enabled... but than I can just ignore the errors, thank you.
                          @TimO said in openHAB 2.2 binding:
                          Hi @LastSamurai !
                          • L
                            L
                            LastSamurai
                            So I disabled debug output on the gateway to avoid the error messages but I still have problems with my setup. I used to have a motion sensor that worked with openhab. Now when the sensor sends a motion event to the gateway nothing happens in openhab.
                            Part of the log of the motion sensor:
                            6236 TSF:MSG:SEND,11-11-0-0,s=1,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
                            6307 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            6367 TSF:TDI:TSL
                            6385 MCO:SLP:WUP=-1
                            6406 TSF:TRI:TSB
                            6424 MCO:SLP:MS=86400000,SMS=0,I1=1,M1=1,I2=255,M2=255
                            6481 TSF:TDI:TSL
                            6500 MCO:SLP:WUP=1
                            6520 TSF:TRI:TSB
                            6541 TSF:MSG:SEND,11-11-0-0,s=1,c=1,t=16,pt=1,l=1,sg=0,ft=0,st=OK:1
                            6612 MCO:SLP:MS=30000,SMS=0,I1=255,M1=255,I2=255,M2=255
                            6670 TSF:TDI:TSL
                            So it seems like the message gets send succesfully but on the openhab log I see no mentioning of that (although I enable debug output for mysensors and I can switch on/off some led nodes). Any ideas why? I really want to get this working again.
                            • L
                              L
                              LastSamurai
                              Sorry for bothering you guys, I figured out the problem: I have installed domoticz on the same raspberry and after a restart I forgot to turn it off. So all the missing data was "hidden" away by domoticz instead of openhab.
                              • L LastSamurai
                                TimO
                                @LastSamurai :smile:
                                I'm glad you've found the problem, I was out of ideas. ;-)
                                • L
                                  L
                                  LastSamurai
                                  The problem is that the motion sensor still doesn't show up at the gateway although it gets an answer from it. I disabled domoticz though so I need to find another reason ;( Earlier it showed up in domoticz ... strange. I will try to change the id and see if OH picks it up then.
                                  Btw @TimO Any idea yet when you will be able to work on the github issues I posted?
                                  • G
                                    G
                                    gonzalonal
                                    wrote on last edited by gonzalonal
                                    #57
                                    Hi @TimO and @andreacioni.
                                    Back in the day link we discussed about request type of messages being supported by the binding and the complex scenario it created.
                                    Are there any plans to continue developing this feature?
                                    • T
                                      TimO
                                      @LastSamurai I can't say when I'm able to solve those issues.
                                      According the ACK problem I need to enable ACK support in my network at home, which was something I already wanted to do a long time ago but haven't found the time yet.
                                      The RGBW is a tough nut for me. I don't have a RGBW node to test with and the conversion HSB <=> RGBW is driving me crazy. The algorithm for the conversion can be found here: https://github.com/tobof/openhab2-addons/blob/MySensors_Binding/addons/binding/org.openhab.binding.mysensors/src/main/java/org/openhab/binding/mysensors/converter/MySensorsRGBWTypeConverter.java
                                      @gonzalonal May I ask you to add an issue on github? This would allow me track those enhancement requests. Thank you!
                                      • G
                                        G
                                        gonzalonal
                                        #59
                                        Yes, sure. I'll do that to keep track.
                                        By the way, I have RGBW led strip and I am using it with mysensors with no issues. Would you mind telling me what's wrong so I can recreate the scenario?
                                        • G gonzalonal
                                          L
                                          L
                                          LastSamurai
                                          @gonzalonal said in openHAB 2.2 binding:
                                          You can find the issues here. Basically you (I ;)) can't set RGBW nodes to display pure white colors via openhab, dimming is not working (error confirmed by TimO) and most importantly ACK isn't working properly (for me at least). If you can help with any of this (especially the conversion HSB <=> RGBW) you are most welcome.
