  3. Controlling a ( or some) device(s) via IR
2 Posts 2 Posters 2.3k Views 1 Watching
  • CorvlC
    CorvlC
    Corvl
    wrote on last edited by Corvl
    Hello all,
    Having been a happy vera3 and a bridged lite owner I was still missing some options. I am so happy this arduino stuff came available. I recently build an actuator to controll my floorheating.
    The second device I would like to make is a device which at least switch off my mediabox via IR. It would be nice if it is possible to also controll some functions on my television ( Samsung) as well , like switching on.
    For this project I have ordered a Arduino nano and this IR shield http://www.ebay.de/itm/400602576265?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    And offcourse a 2,4 Transceiver Module.
    Next week when I am home I will put this together on an Arduino UNO for testing.
    When it is working , it will be nice to also include a temp sensor on it , a humidity sensor, I read somewhere , someone is working on a air-quality sensor.
    But first the IR-bit.
    This is the sketch from the "build" area of this website:
       // Example sketch showing how to control ir devices
      // An IR LED must be connected to Arduino PWM pin 3.
       // An optional ir receiver can be connected to PWM pin 8.
       // All receied ir signals will be sent to gateway device stored in VAR_1.
       // When binary light on is clicked - sketch will send volume up ir command
       // When binary light off is clicked - sketch will send volume down ir command
       #include <IRLib.h>
       int RECV_PIN = 8;
       #define CHILD_1  3  // childId
       IRsend irsend;
       IRrecv irrecv(RECV_PIN);
       IRdecode decoder;
       //decode_results results;
       unsigned int Buffer[RAWBUF];
       MyMessage msg(CHILD_1, V_VAR1);
               irrecv.enableIRIn(); // Start the ir receiver
         decoder.UseExtnBuf(Buffer);
         gw.begin(incomingMessage);
         gw.sendSketchInfo("IR Sensor", "1.0");
         // Register a sensors to gw. Use binary light for test purposes.
         gw.present(CHILD_1, S_LIGHT);
         gw.process();
         if (irrecv.GetResults(&decoder)) {
           irrecv.resume();
           decoder.decode();
           decoder.DumpResults();
           char buffer[10];
           sprintf(buffer, "%08lx", decoder.value);
           // Send ir result to gw
           gw.send(msg.set(buffer));
         if (message.type==V_LIGHT) {
            int incomingRelayStatus = message.getInt();
            if (incomingRelayStatus == 1) {
             irsend.send(NEC, 0x1EE17887, 32); // Vol up yamaha ysp-900
            } else {
             irsend.send(NEC, 0x1EE1F807, 32); // Vol down yamaha ysp-900
            // Start receiving ir again...
       // Dumps out the decode_results structure.
       // Call this after IRrecv::decode()
       // void * to work around compiler issue
       //void dump(void *v) {
       //  decode_results *results = (decode_results *)v
       /*void dump(decode_results *results) {
         int count = results->rawlen;
         if (results->decode_type == UNKNOWN) {
           Serial.print("Unknown encoding: ");
         else if (results->decode_type == NEC) {
           Serial.print("Decoded NEC: ");
         else if (results->decode_type == SONY) {
           Serial.print("Decoded SONY: ");
         else if (results->decode_type == RC5) {
           Serial.print("Decoded RC5: ");
         else if (results->decode_type == RC6) {
           Serial.print("Decoded RC6: ");
         else if (results->decode_type == PANASONIC) {
           Serial.print("Decoded PANASONIC - Address: ");
           Serial.print(results->panasonicAddress,HEX);
    Serial.print(" Value: ");
                else if (results->decode_type == JVC) {
            Serial.print("Decoded JVC: ");
         Serial.print(results->value, HEX);
         Serial.print(" (");
         Serial.print(results->bits, DEC);
         Serial.println(" bits)");
         Serial.print("Raw (");
         Serial.print(count, DEC);
         Serial.print("): ");
         for (int i = 0; i < count; i++) {
           if ((i % 2) == 1) {
             Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
           else {
      Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
    Serial.print(" ");
         Serial.println("");
    But how does it work??
    If I understand correctly , when I point my ( original) IR-transmitter of the mediabox to the IR reciever ( which is connected to pin 8 , the signal will be stored somewhere on VAR_1 , I expect I can see this somewhere on the GUI of my vera3
    This IR-code has to be copy-paste in the sketch.
    Here:
      irsend.send(NEC, *0x1EE17887, 32*); // standby
     } else {
      irsend.send(NEC, *0x1EE1F807, 32*); // switch on
    How am I doing so far??
    Cor
    • Dan S.D
      Dan S.D
      Dan S.
      Check out comments here:
      http://forum.mysensors.org/topic/124/ir-remote-control/1
