  3. NodeManager
  4. Integrating NodeManager with Sketch Generator
26 Posts 3 Posters 10.6k Views 5 Watching
  • U user2684
    @rakeshpai I think you're right, making it compatible with too many versions can become challenging. The only remarkable difference between 2.1.1 and 2.2.0 is the RF69_868MHZ turned into RFM69_868MHZ. MY_RFM69_NEW_DRIVER if set in 2.1.1 has no impact and the radio signal level child id I've just introduced is not enabled unless MY_SIGNAL_REPORT_ENABLED is defined (only in 2.2.0). So the issue apparently is only on RF69_868MHZ which is probably minor since the user can add or delete a single letter. So we can definitely target 2.1.1.
    Just a note on the MAX_SENSORS: what I wrote before is wrong, MAX_SENSORS defines the maximum number of child ids, not the maximum number of sensors so if you want to set it up, you need to take into account for each sensor how many child ids are created (which is static but to take into account). Thanks!
    rakeshpaiR
    rakeshpaiR
    rakeshpai
    How can I know how many child ids exist in total? Is there a way to arrive at it from the sensors? Sorry for my ignorance.
    Fixed most of the other bugs you pointed out. Thanks!
    U 1 Reply Last reply
    • rakeshpaiR rakeshpai
      U
      U
      user2684
      @rakeshpai not your fault, it is just not easy to see :) When you register a sensor this could create one or more child IDs. How many, depends on the sensor. If you have a look at https://github.com/mysensors/NodeManager/blob/development/NodeManager.cpp#L3139 you can see for each sensor_type how many. As a rule of thumb, add 1 every time _getAvailableChildId() is called. If you need a summary table I can make it for you.
      Defining MAX_SENSORS is not mandatory but since we may risk to have precious storage wasted, better to address this at the first run I think :)
      • U
        U
        user2684
        Hi @rakeshpai, I'm finalizing v1.6 and I was wondering if you had any other issue with NM along the way so I can fix it timely. Also, are you still experiencing the gateway issue (https://github.com/mysensors/NodeManager/issues/187) which I couldn't reproduce? Thanks!
        rakeshpaiR 1 Reply Last reply
        • U user2684
          rakeshpaiR
          rakeshpaiR
          rakeshpai
          @user2684 Sorry, I'm not at a computer. IIRC, the issue I've been facing is that when I used the latest version of NodeManager with the latest version of MySensors dev branch, with signing and encryption, the gateway would crash on startup. This has been preventing me from proceeding.
          Sorry for the lack of detail - I can't verify things at the moment. Looking forward to 1.6!
            U
            U
            user2684
            @rakeshpai no hurry thanks! The gateway issue sounds like a show stopper to me though but maybe I've been able to reproduce it: with both encryption AND signing enabled I got 94% of storage utilization on a pro mini hence causing the crash. If I eg disable debug so saving some storage I get no issues. Whenever you can this is probably something you can test: if this is the issue we would need to find something else to disable in order to have the gw running fine.
            Also I'd recommend to disable repeater mode by default otherwise I guess you can get some issues if every node is acting as a repeater on the network
              I'm trying to compile a serial gateway, no sensors, against the development branch of NodeManager, which works fine. However, when I open the serial monitor, I get the following output:
              $ pio device monitor --port /dev/ttyUSB2
              --- Miniterm on /dev/ttyUSB2  9600,8,N,1 ---
              --- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
               __  __       ____
              |_|  |_|\__, |____/ \___|_| |_|___/��
              ...and it hangs.
              Any idea what the issue might be?
              PS: As a self-confessed connoisseur of ASCII-art, I tip my hat in your general direction. Well done, good sir.
              R
              R
              ru64
              @rakeshpai I've got the same problem. Occasionally found out that this reproduces if DEBUG is off (#define DEBUG 0). As soon as I turned it on - it works.
