  3. Can't detect Interrupt on Arduino Mini Pro or can't wake MySensor ?
5 Posts 3 Posters 1.7k Views 3 Watching
  • ghislainG
    ghislainG
    ghislain
    wrote on last edited by ghislain
    Hi everybody,
    I spent several time trying to detect interrupt on arduino mini pro 3.3v 8mhz with Atmega328 with button but without success. I tryed to downgrade compiler in 1.6.9 but it doesn't work neither.
    If i remove sleep function it's working, but i need sleep because it a battery node for the mailbox...
    Each time i press the button, i can read that in the log in the serial monitor :
    2369 MCO:SLP:MS=0,SMS=0,I1=0,M1=1,I2=255,M2=255
    2375 MCO:SLP:TPD
    2377 MCO:SLP:WUP=0
    2379 MCO:SLP:MS=0,SMS=0,I1=0,M1=1,I2=255,M2=255
    2383 MCO:SLP:TPD
    2385 MCO:SLP:WUP=0
    2387 MCO:SLP:MS=0,SMS=0,I1=0,M1=1,I2=255,M2=255
    2394 MCO:SLP:TPD
    But nothing else.
    Could someone helping me ?
    Thx,
    Ghislain
    This is my code :
     * Simple binary switch example
     * Connect button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND.
     * http://www.mysensors.org/build/binary
    #define MY_NODE_ID 8
    #include <Bounce2.h>
    #include <Vcc.h>
    #define CHILD_ID_MAIL 0
    #define CHILD_ID_MAIL2 1
    #define CHILD_ID_VOLT 2                  // Child id for battery reading
    #define BUTTON_PIN 2  // Arduino Digital I/O pin for button/reed switch
    #define BUTTON2_PIN 3  // Arduino Digital I/O pin for button/reed switch
    #define SLEEP_TIME 1 * 60 * 1000UL
    // Variables' declaration
    const static uint32_t COUNTER = 60;  // en secondes
    unsigned long sendTime = 0;
    unsigned long time = 0;
    Bounce debouncer = Bounce();
    Bounce debouncer2 = Bounce();
    int oldValueC1=-1;
    int oldValueC2=-1;
    boolean gwSend = true;
    const float VccMin   = 3;           // Minimum expected Vcc level, in Volts.
    const float VccMax   = 4;           // Maximum expected Vcc level, in Volts.
    const float VccCorrection = 1.0/1.0;  // Measured Vcc by multimeter divided by reported Vcc
    float batteryV = 0;
    int batteryPcnt = 0;
    Vcc vcc(VccCorrection);
    MyMessage msgMail(CHILD_ID_MAIL,V_TRIPPED);
    MyMessage msgMail2(CHILD_ID_MAIL2,V_TRIPPED);
    MyMessage msgVolt(CHILD_ID_VOLT, V_VOLTAGE);
      // Setup the button
      pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);
      pinMode(BUTTON2_PIN, INPUT_PULLUP);
      // Activate internal pull-up
      //digitalWrite(BUTTON_PIN,HIGH);
      //digitalWrite(BUTTON2_PIN,HIGH);
      debouncer.attach(DIGITAL_INPUT_SENSOR);
      debouncer2.attach(BUTTON2_PIN);
      debouncer.interval(5);
      debouncer2.interval(5);
        #ifdef MY_DEBUG
          Serial.begin(115200);
      batteryV  = vcc.Read_Volts();
      batteryPcnt = vcc.Read_Perc(VccMin, VccMax);
    void presentation() {
      sendSketchInfo("BAL", "1.0");
      present(CHILD_ID_MAIL, S_DOOR);
      present(CHILD_ID_MAIL2, S_DOOR);
      present(CHILD_ID_VOLT, S_MULTIMETER);
      debouncer.update();
      debouncer2.update();
      // Get the update value
    uint8_t  value1 = debouncer.read();
    uint8_t  value2 = debouncer2.read();
      if (value1 != oldValueC1) {
         // Send in the new value
          gwSend = true;
         #ifdef MY_DEBUG
            Serial.println(value1);
         oldValueC1 = value1;
        if (value2 != oldValueC2) {
          gwSend = true;
         #ifdef MY_DEBUG
            Serial.println(value2);
         oldValueC2 = value2;
     // **** Re-send value every X minutes ****
        time = millis()/1000;
    //    if(time - sendTime >= COUNTER) {
    //    batteryV  = vcc.Read_Volts();
    //    batteryPcnt = vcc.Read_Perc(VccMin, VccMax);
    //     #ifdef MY_DEBUG
    //        delay(2000);
    //        Serial.println(batteryPcnt);
    //     #endif
    //    gwSend = true;
    //    sendTime = time;
       if (gwSend == true) {
         send(msgMail.set(value1==LOW ? 1 : 0));
         send(msgMail2.set(value2==LOW ? 1 : 0));
         send(msgVolt.set(batteryV, 2));
         gwSend = false;
      else {
    sleep(0, CHANGE, SLEEP_TIME);
    dbemowskD 1 Reply Last reply
    • ghislainG ghislain
      Hi everybody,
      2375 MCO:SLP:TPD
      2377 MCO:SLP:WUP=0
      2383 MCO:SLP:TPD
      2385 MCO:SLP:WUP=0
      2394 MCO:SLP:TPD
      But nothing else.
      Thx,
      Ghislain
      This is my code :
      #include <Vcc.h>
      int oldValueC1=-1;
      int oldValueC2=-1;
      float batteryV = 0;
        // Setup the button
          #ifdef MY_DEBUG
        debouncer.update();
            gwSend = true;
           #ifdef MY_DEBUG
            gwSend = true;
           #ifdef MY_DEBUG
      //     #ifdef MY_DEBUG
      //        delay(2000);
      //     #endif
      //    gwSend = true;
      //    sendTime = time;
           gwSend = false;
        else {
      dbemowskD
      dbemowskD
      @ghislain Am I missing something? I don't see anything having to do with an interrupt, just 2 debouncers. An interrupt would use attachInterrupt() and call an ISR (Interrupt Service Routine) which is a separate function in your sketch that would get called when the button gets pressed. On the Pro Mini boards, only pins 2 and 3 can be tied to interrupts, which is the two pins you are using. What did you want the interrupt to do?
      Nca78N 1 Reply Last reply
      • dbemowskD dbemowsk
        Nca78N
        Nca78N
        @ghislain your node is waking up. To understand the log, select the "Build" menu item on this website, and chose "Log Parser" in the left column, then you can paste the log and get some full text descriptions of what is happening.
        Do not use debouncer if you are using sleep, instead at the beginning of the loop() method (so it will be called just after the sleep() ends) use a wait(value in ms) command that is long enough to allow the bouncing of the button to finish. Then you can just read the value of the input.
        You also have a problem with your sleep function, you are setting only interrupt 0 (the one that triggers the wake up in your log) but interrupt 1 is not set so the second button will not work.
        @dbemowsk said in Can't detect Interrupt on Arduino Mini Pro or can't wake MySensor ?:
        It's called by the sleep function of MySensors that he calls at the end of his script.
        • ghislainG
          ghislainG
          ghislain
          Thank you both for your answer.
          To resume what i want to do, i want to watch when mail is arrived in my outdoor mailbox, i will do that with 2 "door sensor".
          @Nca78 if i well understood that you say, interrupt was catched and wake up arduino but value1 (the status of the "door sensor") wasn't updated and so my code doesn't do anything and it fall asleep again. Is that correct ?
          I know, i just have one interrupt else i'm using 2, but it was for test with one firstly.
          I will try to do in another way as you say.
          thanks
          • ghislainG
            ghislainG
            ghislain
            This is my change and it is working, thank you for your help.
            //#define MY_DEBUG
            #include <Vcc.h>
            int oldValueC1=-1;
            int oldValueC2=-1;
            float batteryV = 0;
              // Setup the button
              pinMode(BUTTON_PIN, INPUT);
              pinMode(BUTTON2_PIN, INPUT);
                #ifdef MY_DEBUG
              wait(100);
            uint8_t  volet = digitalRead(BUTTON_PIN);
            uint8_t  porte = digitalRead(BUTTON2_PIN);
              #ifdef MY_DEBUG
                    Serial.println(volet);
                    Serial.println(porte);
              if (volet != oldValueC1) {
                  gwSend = true;
                 #ifdef MY_DEBUG
                 oldValueC1 = volet;
                if (porte != oldValueC2) {
                  gwSend = true;
                 #ifdef MY_DEBUG
                 oldValueC2 = porte;
                 #ifdef MY_DEBUG
                    //delay(2000);
                 send(msgMail.set(volet==LOW ? 1 : 0));
                 send(msgMail2.set(porte==LOW ? 1 : 0));
                 gwSend = false;
              else {
            sleep(0, FALLING, 1, FALLING, SLEEP_TIME);
