  3. Using Solar Powered Night-Light Housing? (2v...)
10 Posts 3 Posters 3.1k Views 4 Watching
  • Bogus ExceptionB
    Bogus ExceptionB
    Bogus Exception
    Has anyone had any luck with the 2vdc solar powered night-light things you can pick up for a few bucks? They are listed as 2vdc with one to several LEDs. The draw for me is a nice housing, integrated solar cell, making a nice place for sensors...
    I'm running MCUs at 3.3v, so I might need to use 2 together, or add on another panel, but curious what you think for a sensor platform if you've thought about or tried it...
    Here is an arbitrary example, one of many housing styles...
    Thoughts?
    "If you drop it and it breaks, it was good." ~ Mr. Lehr, my Electronics Vo-Tech teacher, on testing vacuum tubes...
    -Arduinos (UNO, Nano, Pro-Mini, Mega, ...)
    -ATTiny, ATMega, STM32
    -Geek Channel: https://www.youtube.com/TheSalesEngineer
    • Bogus ExceptionB Bogus Exception
      Thoughts?
      @Bogus-Exception the first two of these seem to have been successful:
      https://forum.mysensors.org/topic/3107/chinese-solar-lipo-powered-pir-led-lamp
      https://forum.mysensors.org/topic/4045/solar-powered-soil-moisture-sensor
      https://forum.mysensors.org/topic/7141/garden-solar-light-booster-esp32-moisture-sensor-likely-to-work
      • Bogus ExceptionB
        Bogus ExceptionB
        Bogus Exception
        Sorry. I feel like an idiot now...
        pat
          pat
          @Bogus-Exception no worries, everyone hasn't been hanging in the forums for as long as I have ;-)
          • NeverDieN
            NeverDieN
            I was intrigued by this at first too, but then I realized that Lipo's and heat don't go together too well. I just imagine something that's built to the lowest cost possible going up in flames and torching whatever its attached to.
            • NeverDieN NeverDie
              @NeverDie lipo is way too expensive themselves, and require charging circuits with also has a cost. So these cheap lights all use nimh.
              • NeverDieN
                NeverDieN
                Well, maybe the $8-10 ones use lipo. I'm pretty sure I've seen a teardown that showed the presence of a small lipo in those:
                  @NeverDie you're right. Sorry.
                  • Bogus ExceptionB
                    Bogus ExceptionB
                    Bogus Exception
                    I thought they might be a value for a sensor housing, with the bonus of having a weather-ready solar panel. I bought a few garden lights with this same thing in mind (posted as a reply here). I see the platform as the hardest part, since the guts can be more easily replaced.
                    Great discussion!
                    NeverDieN 1 Reply Last reply
                      Great discussion!
                      NeverDieN
                      NeverDieN
                      @Bogus-Exception said in Using Solar Powered Night-Light Housing? (2v...):
                      I do think that's reasonable. If you can find an attractive housing that has the look you want and which has a good mini solar panel and is also truly weather and moisture proof, then that's a good find.
                      Do let us know if you come across something like that.
