  3. Serial gateway problem after upgrade from 1-5 to 2-1-1
10 Posts 5 Posters 2.7k Views 3 Watching
  • pihomeP
    pihomeP
    pihome
    Hi all,
    i have my four nodes running and serial gateway running on version 1.5 and all works fine, but after upgrading to version 2.1.1 my serial gateway stop working i haven't changed any wiring so its not hardware, if i flash this gateway with 1.5 it works without even changing radio. so it must be some config/software change from 1.5 to 2.1.1 that is causing this failure. i m just lost here, all forum posts seems to end without any final conclusion
    0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSF:WUR:MS=0
    0;255;3;0;9;RF24:write register, reg=0, value=14
    0;255;3;0;9;RF24:write register, reg=3, value=3
    0;255;3;0;9;RF24:write register, reg=4, value=95
    0;255;3;0;9;RF24:write register, reg=5, value=76
    0;255;3;0;9;RF24:write register, reg=6, value=35
    0;255;3;0;9;RF24:write register, reg=16, value=115
    0;255;3;0;9;RF24:write register, reg=29, value=6
    0;255;3;0;9;RF24:read register, reg=6, value=255
    0;255;3;0;9;RF24:read register, reg=5, value=255
    0;255;3;0;9;!RF24:INIT:SANCHK FAIL
    0;255;3;0;9;!TSM:INIT:TSP FAIL
    0;255;3;0;9;TSM:FAIL:CNT=1
    0;255;3;0;9;TSM:FAIL:PDT
    0;255;3;0;9;RF24:write register, reg=0, value=12
    0;255;3;0;9;RF24:PD
    PiHome - Smart Heating Control
    YveauxY 1 Reply Last reply
    • rejoe2R
      rejoe2R
      rejoe2
      Maybe there could be more reasons but at least these two are known to cause troubles:
      The newer nRF lib:
      • Causes higher power consumption: So make sure, there's enought juice.
      • Check the PA-level used (standard is already low, so this may have been different in the past also).
      • In some rare cases, there may occur strange things with fake nRF chips. If possible, try an other nRF module from differen source.
      Second: use latest board-definition within the Arduino IDE (board manager). Some "in between-versions" cause regular reboots of the arduino.
      • scalzS
        scalzS
        wrote on last edited by scalz
        Hello.
        I don't think new nRF consumes more juice. it process faster than in 1.5 lib though, so it can send faster consecutive packets sure.
        @pihome
        • please post your gw+nodes sketch
        • and your gw+nodes logs.
        That will be easier for helping you. (you can use "Insert code block" tool in your message toolbar for inserting stuff. Easier to read ;) )
        • Are all your devices updated to same version ?
        • Decoupling capacitor, like 10uF, on radio ?
        • finally, if anything above work, not sure, but maybe try with a fresh a node, or radio, or try a clear eeprom.
        Else it could be in your sketch defines..
        Not enough infos for the moment :)
        • pihomeP pihome
          Hi all,
          0;255;3;0;9;RF24:PD
          YveauxY
          YveauxY
          @pihome did you update all nodes and gateway to 2.1.1, or only the gateway ?
          • pihomeP
            pihomeP
            pihome
            all nodes are powered off now, and only gateway is on 2.1.1 now.
            • pihomeP pihome
              YveauxY
              YveauxY
              @pihome Make sure all nodes and gateway use the same version; 2.x is not compatible with 1.x !
              • S
                shabba
                I had huge problems with ack on so I turned it off on my whole network. Otherwise a node presenting would reset the controller over and over.
                • pihomeP
                  pihomeP
                  pihome
                  wrote on last edited by pihome
                  here is my gateway sketch. i have no other sensors powered on so having sensors on same version doesn't apply here.
                  * The ArduinoGateway prints data received from sensors on the serial link.
                  * The gateway accepts input on seral which will be sent out on radio network.
                  * The GW code is designed for Arduino Nano 328p / 16MHz
                  * Wire connections (OPTIONAL):
                  * - Inclusion button should be connected between digital pin 3 and GND
                  * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
                  * LEDs (OPTIONAL):
                  * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
                  // #define MY_RF24_PA_LEVEL RF24_PA_LOW
                  //#define MY_DEBUG_VERBOSE_RF24
                  // RF channel for the sensor net, 0-127
                  #define RF24_CHANNEL     125
                  //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
                  #define RF24_DATARATE 	   RF24_250KBPS
                  // Enable serial gateway
                  #define MY_GATEWAY_SERIAL
                  // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
                  #if F_CPU == 8000000L
                  #define MY_BAUD_RATE 38400
                  // Enable inclusion mode
                  // Set blinking period
                  #define MY_WITH_LEDS_BLINKING_INVERSE
                  // Flash leds on rx/tx/err
                  #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
                  #define MY_DEFAULT_RX_LED_PIN  6  // Receive led pin
                  #define MY_DEFAULT_TX_LED_PIN  5  // the PCB, on board LED
                  • pihomeP
                    pihomeP
                    pihome
                    after making following changes my gateway seems to be working fine.
                    0;255;3;0;9;TSM:INIT:TSP OK
                    0;255;3;0;9;TSM:INIT:GW MODE
                    0;255;0;0;18;2.1.1
                    0;255;3;0;9;MCO:BGN:STP
                    • pihomeP
                      pihomeP
                      pihome
                      Basic Temperature sensors sketch
                       * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
                       * http://www.mysensors.org/build/temp
                      //#define MY_DEBUG
                      #include <OneWire.h>
                      #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
                      //PiHome Node ID
                      #define MY_NODE_ID 25
                      unsigned long SLEEP_TIME = 150000; // Sleep time between reads (in milliseconds)
                      int oldBatteryPcnt = 0;
                      int numSensors=0;
                      bool receivedConfig = false;
                      bool metric = true;
                      MyMessage msg(0,V_TEMP);
                      void before()
                        sensors.begin();
                          analogReference(INTERNAL1V1);
                      #else
                          analogReference(INTERNAL);
                      // void sendSketchInfo(const char "Temperature Sensor", const char "1.1", bool ack);
                      void presentation() {
                        sendSketchInfo("Temperature Sensor", "1.1");
                           present(i, S_TEMP);
                      // get the battery Voltage
                      	#ifdef MY_DEBUG
                      		Serial.println(sensorValue);
                      	#ifdef MY_DEBUG
                      		float batteryV  = sensorValue * 0.003363075;
                      		Serial.print(batteryV);
                      		Serial.println(" V");
                      		Serial.print(batteryPcnt);
                      		Serial.println(" %");
                              // Power up radio after sleep
                              oldBatteryPcnt = batteryPcnt;
                        sleep(conversionTime);
                          float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                          #if COMPARE_TEMP == 1
                          #else
                            send(msg.setSensor(i).set(temperature,1));
                        sleep(SLEEP_TIME);
                      these message are received on serial gateway...
                      0;255;3;0;9;TSF:MSG:BC
                      0;255;3;0;9;TSF:MSG:FPAR REQ,ID=25
                      0;255;3;0;9;TSF:PNG:SEND,TO=0
                      0;255;3;0;9;TSF:CKU:OK
                      0;255;3;0;9;TSF:MSG:GWL OK
                      0;255;3;0;9;!TSF:MSG:SEND,0-0-25-25,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
                      0;255;3;0;9;TSF:MSG:READ,25-25-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      0;255;3;0;9;TSF:CKU:OK,FCTRL
                      0;255;3;0;9;TSF:MSG:GWL OK```
                      its looking for hardware ack, any idea why this is happening?
                      only happens if sensors is restarted,
