  3. Node without radio
Node without radio
10 Posts 2 Posters 2.6k Views 2 Watching
  • G Offline
    G Offline
    Gumers
    HI, I'd like to prepare node on mega+ethShield5100 without radio. Arduino 1.6.9; mysensor 2.1.1.
    So I commented in the sketch line #define MY_RADIO_NRF24.
    At the moment system startup with IP, but halted o the:
    0;255;3;0;9;MCO:BGN:STP
    0;255;3;0;9;MCO:BGN:INIT OK,TSP=NA
    After that system restart startup procedure.
    What I should change?
    • G Gumers
      @Gumers that depends on what you have ;-) Did you use the ethernet gateway sketch? or something else?
      What typ of sensor do you want to create?
      Could you post the entire log?
      • G Offline
        G Offline
        Gumers
        I try to prepare GW sketch for node with relays.
        I'v got problems with NRF (a lot of transmission problems) but I can use LAN for communications.
        All log from node:
        0;255;3;0;9;MCO:BGN:INIT GW,CP=R-NGA--,VER=2.1.1
        0;255;3;0;9;MCO:BGN:BFR
        IP: 192.168.0.172
        0;255;3;0;9;Eth: connect
        IP: 192.168.0.172
        IMHO it's a problem with initialize radio and sketch halted before Presentation procedure.
        But why?
        • G Gumers
          All log from node:
          IP: 192.168.0.172
          IP: 192.168.0.172
          But why?
          @Gumers could you post your presentation function?
          • G Offline
            G Offline
            Gumers
            Sure
            Part of relay code, same I use now with NRF:
            #define RELAY_1  22
            #define NUMBER_OF_RELAYS 8 // Total number of attached relays
            #define RELAY_OFF 0// GPIO value to write to turn off attached relay
            void before()
                pinMode(pin, OUTPUT);
                digitalWrite(pin, RELAY_OFF);
                //digitalWrite(pin, loadState(sensor)?RELAY_ON:RELAY_OFF);
              sendSketchInfo("Mega_eth", "1.0");
                present(sensor, S_BINARY);
            • G Gumers
              Sure
              #define RELAY_1  22
              void before()
              @Gumers looks like the node resets itself, so we'll need to figure out why/when.
              If you comment out the pinMode and digitalWrite statements, does it still reset?
              Could you add a serial print at end of before() and at start of presentation, to check if the code reaches those lines?
              Do you have a setup function? If so, could you post it?
              How is the mega powered?
              • mfalkviddM Offline
                Could be a similar problem as in https://forum.mysensors.org/post/72423 - maybe check your Arduino AVR board version?
                • G Offline
                  G Offline
                  Gumers
                  This node is controled by Domoticz. I saw this hardware in controler without presentation name and childrens. When I turnoff this hardware in Domoticz, node doesen' reset. Log in Domo with hardware up:
                  2017-08-19 23:38:37.109 TCP: Reconnecting...
                  2017-08-19 23:38:38.109 MySensors: connected to: 192.168.0.172:5003
                  2017-08-19 23:38:46.940 (ethGet1) Humidity (SOL 2 Hum)
                  2017-08-19 23:38:47.037 (ethGet1) General/Voltage (SOL 2 Vcc )
                  2017-08-19 23:38:47.110 MySensors: Connection reset!
                  2017-08-19 23:38:47.110 TCP: Reconnecting in 30 seconds...
                  2017-08-19 23:38:54.939 (ethGet1) Temp (STA Temp)
                  IMHO connection reset concerning presentation problem.
                  But still I don't understand why node doesn't present name and relay childs in Domo.
                  Version of motherboard 1.6.19. powered by ac adapter.
                  At the end of before() serial printed text to debuger - befor() is ok.
                  I commented all lines. Save only presentation sketch name.
                  Setup and loop are empty.
                  Still the same. I'm going creazy...
                  All of source:
                  #define MY_GATEWAY_W5100
                  //#define MY_W5100_SPI_EN 4
                  #define MY_PORT 5003
                  #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEE, 0xEE, 0xED // zarezerwowane na 192.168.0.172
                  // Enable inclusion mode
                  // Set blinking period
                  //#define MY_DEFAULT_LED_BLINK_PERIOD 300
                  #include <Ethernet.h>
                  #define RELAY_1  22
                  void before()
                  • G Gumers
                    All of source:
                    #define RELAY_1  22
                    void before()
                    @Gumers 1.6.19 is the same version as in the thread I linked. Downgrading seems to solve the problem for people.
                    • G Offline
                      G Offline
                      Gumers
                      OMG, thats it.
                      Downgrade to 1.6.11 solved problem.
                      Thanks for your time. Y'r great!
